I have an older ge zoneline and one of the locknuts came off a selector switch. when it was turned it turned to far and twisted off five wires. i can put them back on but im not sure what terminals they came off. the model # is AZ31H09DACV1. There was no wiring digram. Is there one i can download
  • 2,692 Answers
I obtained the following statment from the GE web site:
How to Obtain a Wiring Diagram or Schematic...diagram. If you are in need of a replacement wiring diagram, simply call the GE Answer Center with your complete model number. The diagram may be faxed, e-mailed or mailed. You can reach us by dialing 1-800-626-2005. We are available...
Posted on Dec 19, 2008
Why is there a ***** smell?
I worked extensively on GE Zoneline AZ Air Conditioners and Heat Pumps while a Maintenance Superintendent at a Senior Citizen's Apartment Complex. Not knowing what type of smell to which you are referring, I can assure you that other than "burnt electrical" smells, the only smell that could possibly be produced would be that from within the INDOOR SPACE. Perhaps something has made its way into the INDOOR AIR FILTER? Perhaps that INDOOR AIR FILTER needs to be cleaned. To clean the INDOOR AIR FILTER, simply lift both of the filters from the front cover, take to your clean bath tub. Run EXTREMELY HOT WATER from the back of the filter to the front of the filter. Then, fill your bathtub 1/4 way with EXTREMELY HOT WATER. Add 1 cup of Hydrogen Peroxide and 1 cup of Real Lemon Juice. Set both filters in this solution for 30 minutes; then rinse with clear water. Set filters up to dry for at least 2 hours in the sun or an air breeze. Replace filters into the GE Zoneline.
Also, not knowing how OLD your GE Zoneline system is, the COILS may need to be cleaned. To do this, simply turn OFF your GE Zoneline unit and remove the front COVER of the unit. Next, mix in a spray bottle 4 packets of LEMON flavored KOOL-AID (without SUGAR) and water. Shake well. Spray the INDOOR COILS of your GE Zoneline unit with the entire contents of this mixture. Let set for at least 10 minutes. Then turn your GE Zoneline to the COOL position. The citric acid in the lemon kool-aid will be forced through the coils to continue to remove any dirt, dust, debris and effectively CLEAN those coils. This will also provide you a LEMONLY odor within your room. Simple and cheap.
Enjoy your GE Zoneline unit.
Aug 30, 2014 | GE Zoneline AZ55H07D Air Conditioner
What are the setings for the dip switches model az28e12dabm3
We have the 2800 series manual posted online. You can get it at our GE Zoneline page.
Generally, the default settings work best, unless you want to set temperature limiting.
Aug 15, 2014 | GE Zoneline Deluxe Series Cooling &...
Broken selector switch
TURN OFF CIRCUIT BREAKER. Lift out cooktop, remove all machine screws holding the glass frame. Remove plastic knobs and lift glass top straight up. Make sure rubber gromits are not ripped or torn. Unscrew the small screws on the selector switch and then lift up and tilt over the small aluminum chasis holding the switches to expose the wiring connections. Pull off the wires and pull out the defective switch. Replacre switch, connect wires, re-seat switch chasis, and secure switch with screws. Carefully drop in the glasstop lining up the switch shafts and the rubber grommets. Secure the top with machine screws and drop back in the cutout.
Apr 18, 2009 | GE 30 in. Profile JP350 Electric Cooktop
GE zoneline - about 23 years old
theres a heat relay and also the wire used for heat.either could be bad.
Nov 05, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Air conitioner turns on by itself
The GE Zoneline units have small DIP switches inside the unit where you can turn various functions on or off. The units have a feature called Heat Sentinel that turns the A/C on at a certain room temperature, even when the unit is turned off. It also has a Freeze Sentinel that turns the heat on automatically, even when the unit is turned off. You can turn off the heat and freeze Sentinel features with the DIP switches in the unit. There are other features you may want to turn off. Read the owner's manual and it will tell you where the switches are and which ones turn off the features. Hope this helps.
Sep 17, 2008 | GE Zoneline AZ55H07D Air Conditioner
Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
GE Zoneline 2100 heater/ac won't heat/doesn't shut off
well, it's been almost 4 years since this was posted, but it's the selector knob. these things are HORRIBLY designed (the selector knobs) very easy to break if someone pushes it to the side too hard.
ASSUMING when you cleaned it, you didn't get the controller knob wet, which could cause heat and ac to come on at the same time. If after a few days, it's still the same, it's the selector. I've replaced a million of them (ok, not really a million, but, a lot.)
Jan 22, 2008 | Heating & Cooling
Problem with AZ21E15EACV1
if you know how to check these, try to check these, compressor, compressor capacitor and thermostat, hope this would do. tnx.
Jan 22, 2008 | GE Zoneline AZ55H07D Air Conditioner
Jan 10, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
387 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
