Question about Nintendo Professor Layton & the Curious Village Games for DS
Shops cant get them
Cant get hold of it every wear is sold out help
  • 5 Answers
I got mine on ebay impoted from hong kong, works fine on uk DS and only cost about £17 inc delivery.
Posted on Dec 28, 2008
    Problem Solver:
  • 4 Answers
If you go online to currys or argos and maybe comet you can quickly search a lot of stores for stock and then reserve the game for you to collect. Or if you are desperate / not so bothered about paying over the odds try amazon or play.com
Window 10 had to reinstall windows cant find print shop can i reistall it from broderbund site
Windows 10 hides software it can't work with in a special folder. Go into the Windows 10 system files and see if you can find it that piece of software.
I don't know if Broderbund still operates. The software was generally sold on a disc, not a download.
Dec 13, 2015 | Broderbund The Print Shop 3.5 Deluxe -...
How can I get hold of manual for supanova convectionair oven.
I can only suggest you contact the maker whom I do not know GOOD LUCK tho
Jan 26, 2015 | Ovens
How to change timing chain for 2004 5 cylinder engine?
need a service manual fro complete details--haynes are sold in autozone etc--library has chilton/mitchell shop books--in ur case the engine may hav to be risen--make sure u change tensioner, waterpump etc while in there--a new chain quickly wears out any old mechanicals----inspect from engine seal also
Sep 01, 2014 | 2004 Chevrolet Colorado
I need a 12 amp 125 volt ceramic fuse cant find one what can replace it
Those are hard to find, usually sold at stereo shops specializing in competition woofers. I don't believe you can substitute that fuse. If you can't find one at a local stereo shop, you will have to look online. They are usually around $20.
Dec 11, 2011 | Car Audio & Video
I have 4 pairs of Skechers Shape-Ups. 3 of these have worn out the lining and the cushioning in the back of the shoe where it covers the back of my foot (just above the heel). Is there a way to fix this? I...
They can be fixed. A shoe repair shop can help you with that. Since Idon't know where you live, Ican't tell you whee is the nearest one to you. Relining the insides would cost about $10-15 and fixing the sole is more depending on what they have to do.
Jul 02, 2011 | Skechers Clothing Accessories
Window just stopped working one day. Rolled it down on the way to store, got back home and the window just stopped working..Is it the motor?
there is a contraption called a regulator in the door. it has a motor in it which wears out like all other motors. get a new regulator, not just the motor. these are sold on eBay and at parts stores. pay a glass shop to install it. there are special tools and fasteners needed and you do not have them.
Apr 10, 2011 | Saturn LS Cars & Trucks
RN45B secquentail trip will not work; contract trip will work only when slam hard on work. I do not know what to replace. small air leak .Can you help?
Remove roll pin holding trigger. Examine trigger for wear. A loose/ worn trigger can cause problem that you describe. Also examine the roll pin that holds trigger, if it is worn where trigger rides replace pin. If trigger and roll pin look ok then problem most likely tva6 valve. This valve has a pin that wears out. Order from ebay for under $20.00. If the gun leaks air, remove head and clean orings in the headvalve. Pull cylinder and clean orings to cylinder seal. Remove fine scratches on body of gun where orings contact metal. Use 400 grit paper. Lube all orings with silicone paste (sold at lowes in the plumbing department for faucet orings). To remove tva6 valve remove two pins in body of gun and apply air pressure to pop out valve. Use glove when you catch tva6. Use caution because the valve can come out with force (lower pressure ). Good luck
Nov 05, 2010 | Stanley Bostitch Rn45b1 Industrial Coil...
I cant get vista home prem to reconize my rockchip mp4 player
You should go back to the shop that sold you that thing!!! It might be a fake brand!! It happens a lot in my place.
Hope this helps!!!
Jun 26, 2009 | Audio Players & Recorders
Violent shake while cornering at lower speeds
hello and welcome
a couple of things that need to be inspected. the steering head bearings. with the bike supported you can check for free play with the steering stem and its holdings.
another is the rear tire. seems funny but vibrations and handleing i have seen do transfer from the rear at times. and if the tire may be out of balance it can throw the front tire wear off as well.
and another of course is the fork freeplay. as you r the dealerships should have inspected is the fork bushings. they have a teflon coating and if they wear down they can develop a clearance that results in bad front end handleing and tire wear. between any of those items you should be able to find the culprit. thank you.
Mar 21, 2009 | 2002 Honda VT 1100 C2 Shadow Sabre
Nintendo Professor Layton & the Curious Village Games for DS Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
