Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
HP Pavillion zd 7000 (model zd7058cl) does not turn on now
Verified power supply cable and battery came out good (troubleshooting).
Removed battery and waited about 30 min and connected directly to ac wall plug, no luck. Power button turn on for a few seconds and then shut off. Display is black always and no noise coming out of the fans.
Removed & reseats ram memory card (1gb) and without battery reinstalled plugged it to ac connection, no luck either.
Heard there was a service alert by HP about this problem, can´t find any web site to verify it. (not on hp.com) It is true there is a class action because of this problem? Please inform web site of plaintiffs´ attorney.
    Sergeant:
  • HP Expert
  • 278 Answers
Don't try again and again,,, if not running well protection circuit will turn off. therefore test for short circuit, need to remove unwanted parts and try, also need to test the circuit for short circuit with multi meter.
specially mosfets need to check.
Posted on Apr 03, 2017
  • 50 Answers
SOURCE: Laptop HP Pavillion zd7000 (model zd7058cl) does not turn on
go on www.hp.com and contact them
Posted on Dec 23, 2008
SOURCE: HP Pavilion Laptop zv5000 wont power on. NOT power cord problem.
Do you have Vista? If so, you should contact HP directly. I had the same problem which occured 3 months after my warranty ran out. I called HP and was told(after they tried to sell me another laptop) that I installed the wrong antivirus program but since I never used my warranty, they would do me a BIG favor and fix it for free. I then waited 14 days for my new laptop and was very happy when it was returned only to find out 3 months later that there is a RECALL for HP laptops with the Vista program that was a MANUFACTURERS defect. THEY HAVE TO FIX IT AND FOR FREE!!!!! I hope this helps you. Good luck.
Posted on Feb 28, 2009
lincen
  • 6 Answers
SOURCE: My HP Pavillion entertainment laptop shuts down
this you power outlet is abnormality inside..need change a new.
Posted on Jun 20, 2009
SOURCE: HP ZD 7000 wont power up. Will plug in, power
I had a similar though somewhat different problem. My zd7000 was plugged in but it was oscillating between charging the battery and running from the battery. In the past I'd adjust the jack position and life was good - this time nothing mattered. I turned the laptop off and noticed that the charge light came on and stayed on - I guessed something was freaky with the battery so I switched to my spare - the charger light came on, I turned on the power I had a brief power on followed by zzzzttt then everything died. I could smell the stench of electrical burning. I disassemble the whole laptop and removed the motherboard - the back of the power jack is burned. A new jack is $10.
If I had to guess, I"d guess you have a bad jack. I've seen offers to repair this on the net for $100. If the offer is legit, I'd rather pay the bucks - theres only 5 billion screws in the laptop - plus the risk of static discharge damaging to boards or the pain of getting the processor heat sink out without damaging the processor and then getting heat conducting "grease" between the processor and the heat sink when you put it all back together again. I figured my unit was dead anyway, might as well see if I could find the issue. Now I need to get a new jack - and see if I can get it all back together again...
Posted on Dec 13, 2010
  • 269 Answers
SOURCE: hi, hp pavillion zx5000 will
I would try the following steps, then contact HP (if these don't work, chances are it's hardware related).
1) Remove the battery and power cable. 2) Hold down the power button for 3 seconds. 3) Reattach the power cable and battery. 4) Try to boot again.
Posted on Mar 01, 2011
Why is my hp invent pavillion a1700n wont turn on
you need to check the power supply of the computer, it may need to replace
Dec 19, 2012 | HP Pavilion a1700n PC Desktop
I have a hp 6735s laptop. Its just out of warranty. When plugged into the mains adapter it is no longer charging the battery. This means it only works when plugged in. Have i inadvertantly set the...
best way is to just try out the battery on another laptop, or try another battery on yours. If the laptop is not very old, and I suppose yours isn't more than 2 years old, your battery shouldn't be dead.
Aug 16, 2010 | HP Compaq 6735s Notebook
My zd 7000 turned off and it wont turn on anymore i removed a battery and strated againg it just flashing buttons
HP dv series laptops are notorious for motherboard problems. I'm sorry to say your's sounds like what I've seen to often. Contact HP as they have extended the warranty periods on a lot of the models and your's may still be in affect.
Mar 31, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
Problems with hp pavilion zd 7000 lights are blinking but it won't turn on
First check to make sure the power is actually on by seeing whether or not the power button lights up or not. If the light isn't on and you have no power try this.
1. Try a simple power cycle. This will correct the problem most of the time. All you need to do is take out your laptop battery. Connect the power adapter and have your computer off. Hold down the power button for about 1 minute. This is done to clear any static electricity that might be building up. Turn on the power button again and the power should come back on.
Apr 14, 2009 | HP Pavilion zd7000 Notebook
May be this sound crazy, but helpful to me in many cases.
Unplug all easily detachable parts and press turn On key for 20 to 30 seconds. Again resemble it and try to turn on. I hope it will work fine. if not don't waste your time and contact to local or online repair center.
Cheers
John
For any Tech Query: +1 (844) 355-5111 (toll-free)
Apr 17, 2017 | HP Pavilion zd7000 zx5000 zv5000 presario...
OPENING THE CASE FOR HP PAVILLION ZD8000
Hi all
I have made another guide than the one that was removed from the net.
cleaning your hp zd 8000 in 9 easy steps... with photos and detailed a description.
how to clean a zd 8000 notebook
here is the link : http://www.realsancristobal.com/myguides/how_to_clean_a_hp_pavilion_zd_80.htm
hope it helps someone out there
Peace
Nov 10, 2008 | HP Pavilion zd8000 Notebook
Hp pavillion desktop will not power up. Blinking green light at power supply
Step 1 : Turn off the system by pressing the power button for 5 - 10 sec until the power LED is off. Removed all cables including the power cable (Exclude monitor cable and KeyBoard/Mouse).
Step 2 : Press power button for 5-10 sec again to drain fela power.
Step 3 : Reconnect the power cable at the back of the tower/computer and power on the system.
**If the same problem exists, Call HP tech Support (800-474-6836) because there is a high possibility that you have a bad Motherboard or Power Supply on the system.
Oct 28, 2008 | HP Computers & Internet
Loud fans and Shutting down
This Could be a System Processer failure...
Try to Remove everything from the PC, Including Battery or Power surge f you have connected in between te Power socket & PC.
then Try to turn it on.
If the Problem Exists then the comp needs Serviced at the service center.
Jul 17, 2008 | Computers & Internet
HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
102 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
