Question about Logitech Traveller (980399-0403) Wireless Headset
Bluetooth hi i was wondering if it is possible to listed to music through a bluetooth headset
0 characters
1 Points
Bh-503 audio cutting while listing music on my mobile
  • well i had an experience the same as you before, i think it's defend to your headset if your using a bluetooth headset or a cabled headset because if your using bluetooth headset and you're walking while listening you will hear the music cutting
Jan 24, 2013 | Nokia BH-503 Bluetooth Headset
Playing music through car audio system
You mean you wanna connect your bluetooth to your car stereo system JBL 99 toyota solora.
If yes then i am sorry because that's not possible.
May 09, 2008 | Motorola Mobility Bluetooth Hands-Free...
Music player through my bluetooth
Hi Mike Cronk,
I see that you have a Bluetooth Headset and that you are tryingto connect it to your BB.
You mentioned it will not play or you cannot hear Audio From it from your BB?
Did the Bluetooth Headset sync to your BB? you need to make sure that the headset is sync properly on your BB and that the BB is dectecting your Bluetooth Headset. make sure that the BB is also set to be detected by any device for the Bluetooth to detect your BB as well for proper syncing of both devices.
try your Bluetooth headset on another devices as well see if it will sync to a different device just to see if the Bluetooth headset is working fine.
I hope this helps,
Dec 25, 2011 | Jabra BT2080 Bluetooth Headset
I have a samsung hm1100 Bluetooth device but i cant hear music from music player ........ what to i do
Hi ranjit975896,
This happens sometimes for this bluetooth dongle , what you can do now is follow the below steps:
1 ) Switch off the bluetooth
2 ) Delete the bluetooth pairing from your phone
3 ) When you delete the bluetooth pairing , restart your phone.
4 ) Then switch on the bluetooth in your phone and your dongle
5 ) Pair the bluetooth , start the music player and check if it works.
Hope this helps ...:) Let me know in case you have any queries.
Sep 09, 2011 | Samsung HM1100 Bluetooth Headset
Hi can I listen to music thankyou
Plantronics Explorer 240 does not support the Bluetooth profile Advanced Audio Distribution (A2DP). Your Bluetooth device and your phone both need to support A2DP, without this Bluetooth profile your devices are not capable of streaming music.
Good luck from Headsets Direct!
Sep 04, 2011 | Plantronics Explorer 240 Bluetooth Headset
How do I listen to music through the bluetooth
Listen to music with the Plantronics Explorer 220:
Unfortunately the Explorer 220 was not designed for music, it does not have the technology built in to stream audio. Headsets must have the Bluetooth A2DP profile and technology to be able to stream music. Like the Plantronics Voyager Pro+ and BackBeat models. Here are the links for these below.
Good luck from Headsets Direct - 800-914-7996.
Aug 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How I can listen music through headset
Your Plantronics Voyager Pro Plus is equipped with A2DP which makes the streaming of music in the headset possible. However if the phone you have does not have that application it won't happen.
May 26, 2011 | Plantronics Voyager PRO Bluetooth Headset
Blackberry 8530 cannot find / pair with bluetooth Samsung stereo headset. Tried putting both into discoverable mode, no help. This headset will pair with my Blackberry 8320 phone, but the music speeds...
1. Turn on Bluetooth headset and Blackberry hand-held.
2. Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
3. Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window
4. Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list
5. Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically
Use your Bluetooth Headset with your Blackberry
1. Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset 2. Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
3. Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Dec 03, 2010 | Insignia Bluetooth Wireless Headphones...
My backbeat is paired and working with my sprint evo. but the music will not play at all through the headset? calls are fine but no stereo music . it was working fine before i got a jawbone and paired it...
I wonder if Adroid has some issues with its A2DP stack. You see, I have 3 different stereo headsets paired with my WM6.1 phone, and all of them (one at a time, of course) stream music without any flaws.
Anyway, you could try to delete the Backbeat from the list of paired devices on your phone, and, then, pair them again.
Just my 2 cents...
Hope you are able to sort your problems out soon.
Regards, Carlos
Oct 12, 2010 | Plantronics Backbeat 903 Bluetooth...
Music trouble
Not all bluetooth headsets can play music. If you hear music on your headset when you close your phone then your bluetooth is set for it. If not, you are unable to use that bluetooth for music.
Mar 18, 2009 | Motorola Mobility H550 - Bluetooth Headset...
Logitech Traveller (980399-0403) Wireless Headset Logo
42 people viewed this question
Top Logitech Headsets Experts
Brian Sullivan
Brian Sullivan
Jazz Boyce
Jazz Boyce
Level 1 Expert
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Logitech Headset Expert? Answer questions, earn points and help others
