I have a Sony Triniton 36" purchased in 2003. When it was turned on in the morning, the color was in tints of green and red or pink. I have tried adjusts, nothing worked and no one had touched them so what could be my problem. Is it worth fixing and are their people that some to your home? Thanks Joyce
  • mrgorilla2 Dec 20, 2008
    What are crt and I tried a whack - didn't work.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, the general fault is one of the colors is missing, most probably blue. This would indicate that:
  • if it is a standard TV, then most likely that one of the 3 color drive transistor or IC power pack is faulty and/or loose (cold solder) and would require attention/replacement;
  • a possibility of course still exist that the picture tube itself is faulty.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 21, 2008
    Scholar:
  • 145 Answers
Your TV's CRT has three deflection coils which are deflecting coils.These coils are(in layman terms) responsible for mixing of appropriate amount of color on the screen. Now over a period of time two things may happen:-
1. Dirt accumulates in the contacts of the connections of your TV's circuitry. This can be easily solved for just cleaning your TV internal circuitry with a brush and/or IPA
2. The deflection mechanism has gone bad and hence it need to be repaired.
I believe Sony has a very very high quality of workmanship so the 2nd possibility is very remote. But in any case you must remember that carrying out these procedures need utmost care and only a qualified technician should do as the voltages inside can be fatal. I recommend you consult with a qualified technician for carrying out above procedures.
Please rate me if you are satisfied with my answer and get back to me if any clarification required.
Posted on Dec 20, 2008
    Master:
  • 479 Answers
Crt is the part of the tv which adjusts the colours in the tv.if that goes bad then its necessary to replace the crt as it damages the colour quality of the tv. and yes it is worth reparing.as this is common problem which gets solved easily and the tv works properly after that.but manually replacing the part is not very easy as the technician help is much advisable. u can get the required parts at www.partstore.com thanks.
  • 19,396 Answers
It can be one of the CRT gone, or a fault or n open contact on the CRT board, do you get any error message?
Posted on Dec 19, 2008
  • Ginko
    Ginko Dec 19, 2008
    Outputs to teh CRT tube are individual imputs from RGB board on red , green and blue, when you get reddish color, the blue is gone. Probably a bad solder joint on the board, or a component had blown.
    Try hitting with the palm of your hand the side of the TV, so to whak it a bit, and check if colors change, if they do , it is a bad contact.
    Do not exaggerate with strenght hitting the TV on whack test.
My hitachi 43fdx20b has a pink tint to it. I have noticed that if i move the tint slider one way or the other it will turn the screen green, but now it doesn't. Does this have something to do with my...
My 43fdx20b had a pink tint to it also. The picture was clear otherwise. I found, on mine, I needed to adjust the Red Screen control. It was located behind the front panel. I removed the two screws on either side of the front panel and was able to remove the panel. Then I adjusted the Red Screen control. I found that if I tuned in an old Black and white movie I could adjust the color fairly accurately. Good Luck.
Jan 02, 2010 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi Projection Color TV 43FWX20B - COLOR OFF
Check all cables,replaced all cables if more than couple years old.After that the same,ur tv have one dead color gun,require service.
Jan 01, 2010 | Hitachi 43FWX20B 43" Rear Projection...
I just replaced the bulb in my Sony 55'' Grand Wega. the picture looked fantastic the first day. turned on the TV the next day and everything that should have a ''white color'' looked pink. the blues...
Please adjust TINT control of Video Settings in Menu that will adjust color tone of TV. I do not think this problem is related with Lamp because TV screen does not have any color blobs or spots.
Above solution is for Sony KDF-55WF655 model TV, if your model number is different, let me know.
Thanks.
Nov 29, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
I have a 60" SONY VIDEOSCOPE KP-53V15 the person that i received it from said that the picture sometimes turns pink tinted (the best wasy I can explain this) ... Where things on the screen should be white...
In the back of set you have a red green and blue gun.
two or three problems with sony on this.
sum times the green gun will go intermit.
by gentely taping the neck of green gun while set is on, and you see corection, you need to replace green gun.
in others we have found bad soldier in the HV section of the flyback.
and sumtimes its due to louse conectors going to the HD input in back of the set.
hope this is of help to you.
regards,
daniel.
Jan 15, 2009 | Televison & Video
We've been experiencing problems with our Sony Triniton Wega TV
The 7 blinks usually mean a high voltage shutdown has occurred. This can be a simple repair or more involved. If you are comfortable working inside the set where there are potentially dangerous high voltages, and can solder, you can try and repair this yourself. Let me know if you wish to attempt this and I'll supply additional details and instructions.
Dan
Jan 13, 2009 | Sony FD Trinitron WEGA KD-36FS130 36" TV
PROBLEMS WITH COLOR NOT PRINTING
pictures are coming out with a green tint
Aug 01, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Color problems
if you have hd cable or satellite box make sure the component cables are properly connected(green red and blue) and matching same color in source (cable box or satellite and tv as well)
also make sure in tv menu that color and tint are 50%
Jul 03, 2008 | Sony KP-57WS500 57" Rear Projection...
Color sudden change
Good day.
Your unit is still worth. It may be a caused of loose contacts along the circuitry. It can be remedied by resoldering the terminals particularly the chroma section and the crt circuit.
chris
Mar 25, 2008 | Toshiba 36A61 36" TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
