Question about GE 24.6 cu. ft. Side-By-Side Refrigerator with Integrated Ice System
Icemaker problem ge side by side (model GSL25LGTBS) 24 cu ft refr
Makes ice, delivers water, ice delivery (cubed or crushed) accompanied by loud clunking noise and sporadically delivers ice or not at all, Have replaced plastic drive motor cup last month and it worked well for about two or three weeks and then started to fail more often. Is this an assembly problem or somethign else?
4 Suggested Answers
SOURCE: Haier 1.7 CU Ft. Refrigerator - what is warranty
1 year parts and labor
Posted on Aug 17, 2008
MNTECH
  • 1543 Answers
SOURCE: Ice maker only makes crushed ice
Pull the ice bucket out. Behind it you will see a rectangular hole with a rod in it. The rod should be able to move with your one finger up and down. If it does not, the solonoid attached to it is either frozen or burnt out.
Posted on Nov 25, 2008
  • 4 Answers
SOURCE: ice cube dispenser will only deliver crushed ice
Remove the ice bin, and in the back of the freezer you'll see a square opening with a white plastic piece inside. When you dispense cubed ice this piece lifts up, lifting the long metal rod that runs along the bottom of the ice bin. When that rod lifts it opens the ice flap at the front of bin, allowing cubes to be dispensed. If the flap is not open, the cubes will be ground against the cutters and you will get crushed ice.
Here's what you can do to make it so that you always get cubed ice. Take a wine cork and stand it on end. Using a good knife, I positioned the blade about 1/3 of the diameter from the edge and cut all the way through the length of the cork. Then remove the ice tray.
Now put your finger in the sqaure opening and lift up the white pastic piece. Slide the modified cork under the flap so that it is jammed into the raised position. (This is the position it should be in when you are asking for cubed ice.) Now slide the ice tray back in while using your left hand to push the plastic ice flap at the front of the tray to the left side (again, the position it should be in for delivering cubed ice). Peer under the tray while you're slowly sliding it back in so that you can see if the metal rod connected to that ice flap successfully slides into the square opening at the back. If it can't slide in above the cork-raised plastic piece, you may need to pull the cork back out and trim a little more off it.
This worked for me... I can't get crushed ice anymore, but I've only needed crushed ice once in the 16 months I've lived here so that's not an issue for me.
Posted on May 21, 2010
GE Profile REfrigerator: Model PFSS6PKWASS Problem with loud clicking coming from icemaker every 2-3 seconds. Will do this for 30-60 minutes constatntly, then will stop clicking for the same period of...
i have same fridge with same prob makes 6 cubes of ice in a day with a lot of noise like you discribed also i have water collecting under crisper drawer of fridge i have to clean out water once a month or so still trying to figure out how to take ice maker out to fix
Jan 25, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker only delivers crushed...cube option not working
The control board is probably bad. Replacing it might fix the problem.
Dec 31, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
My GE side by side makes crushed ice when I want cubed.
You might want to call a repairman to correct that problem.
Dec 18, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Can not get cubes from the front, just crushed ice and water?
Hi
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 23, 2009 | GE Hotpoint 25.0 Cu. Ft. Side-By-Side...
Nov 25, 2008 | GE Refrigerators
GE Side by Side Model #TFH24PRSMWW Ice maker
The on and off switch of the ice maker on the ge side by side model has fell off and appears broken. please instruct with a diagram how to reattach.
Oct 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker only crushes
Check this post out- http://www.fixya.com/support/t117589-ice_maker_cube_selection. Different model but same principal...Catriver..post back
Nov 02, 2006 | KitchenAid Superba 21.6 cu. ft. Top...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
