Question about Koss KS3101 System
My power light keeps flashing.
My receiver no longer works. The power light keeps flashing and won't turn on. It sometimes will work but then the next day the light will flash again.
  • raddar242 Nov 30, 2008
    I find I can reset it by unplugging power cord for at least 5 min. However, upon playing a DVD the player turns itself off and the power light starts to flash and stays flashing.
  • 64 Answers
Diagnostically this isn't a signal that the company lists. This therefore must be a short. Bring this in for service and let them know that your device wont power up. I'd say it need a nes switch or power supply. Hope this helps! Thanks!
Posted on Jul 27, 2007
SOURCE:
Clicking sound when you turn the tv on but won't work until a few minutes sometimes longer .
The clicking sound is an indication that the power supply is trying to start but is failing
Apr 16, 2013 | Televison & Video
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
Remote will no longer power on Onkyo HT-S3500. Once I turn it on manually, the rest of the functions work properly.
I just had this same issue. I tried to change the batteries for the factory remote that came with the Onkyo HT-S3500 (remote: RC-799M). Still no luck. It would not power on with the remote, despite the light flashing and the and all other remote function working. If I powered on the receiver manually, everything worked (except power on/off).
I just pushed a button on the remote labeled "REMOTE MODE RECEIVER" and viola, the remote now powers the device on and off and works just like usual. Not sure what the heck happened, but I would suggest pushing that button on your remote.
Dec 19, 2012 | Onkyo HT-S3500
Car won't start, seems to have power, all lights working. when I turn the key nothing happens. this only happens sometimes
Could be a bad alternator.. It may not be holding charge. Or your starter could have failed.
Though I've had the same problem and it was a dead battery in my vehicle. Had enough power, but to keep the car on..
Oct 22, 2012 | 1997 Saturn SL
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
My Panasonic SC-HT995W keeps on flashing W and the rear speakers wont work. Ive tried turning off all other wireless devices but it still persists
I had exactly the same problem. My unit worked fine until a loose power cable resulted in the receiver being turned on and off a couple of times in quick succession and then after this the a/c in light on the rear speaker was lit but the wireless link light would not come on (and the 'W' on the main unit flashed constantly). The solution for me was basically a reboot. This is what I did;
- unplug the wireless receiver
- unplug the main unit
- remove the digital transceiver unit from its slot in the back of the main unit
- plug the main unit back in and turn it on - the 'W' won't flash as the transceiver has been removed (not sure if you if it's necessary but I made sure it was producing sound to the front speakers)
- unplug the main unit again
- reinsert the digital transceiver
- plug the main unit back in, turn it on and set it to produce output/sound (the 'W' will be flashing)
- then plug the wireless receiver back in again
...presto the link is made, the 'W' stops flashing and the rear speakers work again.
Hope this elaborate reboot works as well for you as it did for me.
Aug 08, 2010 | Panasonic SC-HT995W System
Receiver issues- VSX-816 K
the speaker is not broken, its the receiver, cuz i have this model, and now it just flashes a blue light on the power button and it wont turn on. I had the same problem as you before it did wat is doing now. i ran the speakers on my vsx-3900s, and they didnt mess up at all, they only did it on the vsx-816
Apr 06, 2010 | Pioneer VSX-816-K/S Receiver
Power switch wont turn on,keeps clicking
The fault is not a relay, the clicking sound is just the protection circuit that prevents the TV from starting because a fault had been detected.
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
May 21, 2009 | Samsung Televison & Video
Won`t turn on
Try leaving it unplugged for longer period of time. Look on the remote for any possible reset function. Try power button without the remote. If any ot these doesn't work there is a power supply module inside that malfunctioned. If under warranty contact where you purchased it. If not under warranty if you can get the module it is a simple plug up procedure.
Dec 31, 2007 | LG 42LC7D-UB Television
Tv does not turn on
When TV does not start, and sometimes you hear a clicking noise, that means that the TV is on protect mode.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Aug 18, 2007 | Zenith L13V36 13" Flat Panel LCD Monitor
Koss KS3101 System Logo
392 people viewed this question
Top Koss Audio Players & Recorders Experts
Steve Allison
Steve Allison
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
