Yamaha P200 polyphony issue - played via midi-notes clip
Yamaha digital piano - P200
- played via midi file/windows media player
Issue:
- notes clip/cut short when I play some midi files - one channel - one instrument
example - Beethoven sonata
- I have a Casio Priva
- same scenario doesn't have a problem
- Both keyboards have 32 note polyphony (P200 with best piano sound)
Help
Steve
2 Suggested Answers
robotek
  • 1512 Answers
SOURCE: yamaha kx88 keyboard midi controller problem.
Hi there, check over all your MIDI leads also. MIDI is a current operated system and is very prone to misfiring if all connectivity is not A1.
Posted on Mar 21, 2008
Tip
Stream Sony XR550 AVCHD from PC to Panasonic TC-P50G25 via DLNA with PS3
PS3 DLNA Video-Play MTS/M2TS Videos from Computer to Non-DLNA TV with PlayStation 3 <br />Full Guide to Setup Windows 7 for PS3 with DLNA Streaming to HDTV <br /> <br />The HDTV in my living room is non-DLNA compliant. It is the 50-inch Panasonic VIERA TC-P50G25 Plasma HDTV. Even though my PC is running Windows 7 with WMP 12, the videos could not be streamed to the Plasma TV via DLNA. It is quite inconvenient for home sharing. <br /><br />When looking for the solution for <b><a href="http://www.aunsoft.com/final-mate/">playing videos from PC to non-DLNA TV</a></b>, I got to know that I could download my Sony XR550 videos from camcorder to PC, connect PlayStation 3 to HDTV via HDMI cable as the media player - <b><a href="http://sony-mts-converter.com/2011/07/play-mtsm2ts-videos-from-computer-to-non-dlna-tv-with-playstation-3/">Stream Sony AVCHD from PC to Panasonic via DLNA with PS3</a></b>. The PS3 is generally used as game console. I also use Aunsoft Final Mate to join the AVCHD files from my XR550 to manage the clips for certain occasion and events. <br /><br />The first thing I do is to make sure PS3 can read the videos from PC. As Windows 7 is DLNA compliant, I just need to make sure the "Windows Media Player Sharing Service" is enabled automatically. Get the clips to the shared folder for video. <br /> <br />Note: The "Windows Media Player Sharing Service" is available in the Service section. Just right-click on My Computer &gt; Manage &gt; Services and Applications &gt; Services, and you can find "Windows Media Player Sharing Service". <br /><br />Wait for a while, and PS3 would read the video files from PC. Then for playing <b><a href="http://www.aunsoft.com/final-mate/">AVCHD files flawlessly via DLNA</a></b> with PS3, we join clips from Sony XR550 into one large file. Run Aunsoft Final Mate, and go to the Resource tab to browse the folder with the .mts files from XR550. Click the Create New Movie button, drag and drop files from Resource tab to the movie ID. Click the Export button and the files will be joined seamlessly for DLNA sharing. <br /> <br /><b>Tips:</b> <br />If the PS3 does not display the PC as source folder, we shall allow the access to Windows 7 as media server. <br /><br />Control Panel &gt; Network and Sharing Center &gt; Change Advance Sharing Settings, and you would face the window like below: <br /> <br />Make sure the "Network discovery" and "File sharing" are selected as turn on. Go to the Media streaming section and click "Choose media streaming options..." to make sure you allow PS3 for streaming. Then <b><a href="http://www.aunsoft.com/final-mate/">PS3 would read video files from PC</a></b> for HDTV playback.
on Jul 06, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
How to solve midi connectivity issue with Yamaha keyboard?
You will need to send it in for repair is my assessment.
Mar 03, 2017 | Yamaha Audio Players & Recorders
Midi-USB cable providing wrong data (notes) to pc? I have a Yamaha YPT 220 / PSR E223 keyboard, and a "generic midi usb" cable wich is actually an Agptek midi usb like cable, (Treble cleff logo ;) ). My...
Make sure that you have the correct midi mapping for your Yamaha. There should have been a software program, called a mid map editor (MME), that came with your keyboard. If you are unfamiliar with this, it is used for changing the values that are sent through the midi cable into your computer (for example, you can change the C0 to be C#0, or any other value, including a numeric value instead of a tonal value). If you bought it used there may have been values changed on midi-trigger presets, which would cause this. If you do have the program, use it to at least investigate that all of the values are in the right places. Often times when someone who is unfamiliar with an MME installs it they open it to see what it is. They change things (not realizing they have done that) and then can't figure out why there is a problem.
Also, make sure your midi cable has the same connections as your keyboard. Some brands make very slight variations to avoid patent issues that may make some cables and instruments incompatible. I have two cables that work fine with certain midi controllers, but when switched they both fail. It's good to make sure the plug ports are clean of dust/dirt, too.
If you are familiar with these problems and they are not yours, you may need to get a different cable. Try to borrow one from a friend to see if the cable is the problem before you buy one. If that still doesn't fix it you may have an internal software or hardware issue. Good luck! I hope I could help.
Aug 27, 2013 | Yamaha Ypt-220 61 Key Personal Keyboard...
My P85 digital piano have not a good trasmission with midi cable USB, in particular when press the sustain pedal trasmit a note to pc. Thanks
It is IMPORTANT to realize that the SUSTAIN is NOT attached to a note, but is an independent MIDI message. Hence it is up to the external MIDI device to associate the sustain with whatever notes are still active.
Feb 27, 2011 | Yamaha P85 88Key Portable Digital Piano
I CAN NOT PLAY MUSIC USING MY MEDIA PLAY
windows media does not support all extensions. Below are the examples. if you have the right format and still you are not able to play then best option is to upgrade or reinstall media player. Windows Media Player 6.0 loadTOCNode(2, 'moreinformation');
  • Windows Media formats
    File name extensions: .asf, .asx, .avi, .wav, .wma, .wax, .wm, .wmv, .wvx
  • RealAudio and RealVideo (version 4.0 or earlier)
    File name extensions: .ra, .ram, .rm, .rmm
  • Moving Pictures Experts Group (MPEG)
    File name extensions: .mpg, .mpeg, .m1v, .mp2, .mpa, .mpe
    Note MPEG 2 requires third-party software or hardware decoders.
  • Musical Instrument Digital Interface (MIDI)
    File name extensions: .mid, .rmi
  • Apple QuickTime (version 2.0 or earlier)
    File name extensions: .mov
  • Macintosh AIFF Resource
    File name extensions: .aif, .aifc, .aiff
  • Intel Video File
    File name extensions: .ivf
  • UNIX
    File name extensions: .au, .snd
Windows Media Player 6.1, 6.2, 6.4, 7, 7.1, Windows Media Player for Windows XP, and Windows Media Player 9 Series loadTOCNode(2, 'moreinformation');
    File name extensions: .asf, .asx, .avi, .wav, .wax, .wma, .wm
  • Audio Visual Interleave
    File name extension: .avi
    File name extensions: m3u, mp2v, .mpg, .mpeg, .m1v, .mp2, .mp3, .m3u, .mpa, .mpe, mpv2
  • DVD Video
    File name extension: .vob
    Note DVD playback requires third-party software or hardware decoders and is supported only in Windows XP.
    File name extensions: .mid, midi, .rmi
  • Apple Macintosh AIFF Resource
  • Sun Microsystems and NeXT
  • Intel Video File
    Note Intel Video File support requires the Intel Video 5.x codec.
  • Windows Media Player Skins
    File name extensions: .wmz, .wms
  • QuickTime Content
    File name extensions: .avi, .mov, .qt
    Note Windows Media Player can play back older forms of the QuickTime format only. For additional information, click the following article number to view the article in the Microsoft Knowledge Base: (http://support.microsoft.com/kb/316992/EN-US/ ) Windows Media Player Multimedia File Formats
  • Algebraic-Code-Excited Linear Prediction
  • UNIX
  • Macromedia Flash
    File name extension: .swf
Dec 10, 2010 | Gateway M350CS PC Notebook
How to open 3 demo pieces of Technics SX-PC10 Digital Piano?
Usually you just select which demo BEFORE starting the demo.
If you are meaning to try to DOWNLOAD via MIDI or other those demo pieces that is USUALLY not possible as the pieces are stored in a ROM which is inaccessible via MIDI or USB.
They OFTEN don''t even send them out on the MIDI port when playing them.
Apr 30, 2010 | Yamaha NP 30 76 Key Lightweight Digital...
How can i play BUP 06PK61 frm yamaha I425 on PC
how can i play .bup file in computer?
ok here is the solution!!!!!!!!
    • we should have a mic pin and audio cable as shown in this pic
    connect these cables,and connect big pin to the piano and small pin to the computer (mic or input jack)
    now take windows movie maker (start-all programs-windows movie maker). click on narrate timeline (as a mic icon below windows movie maker).
    now click start narration on the pc and play your song on the piano. you can see input level highlights. now your song is recording. when your song completes click stop narration and save to the pc. walah if you can't understand this say to me. i can add video. sry for my worst english
Jan 13, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
Midi vs. Sound
Think of MIDI like the old time player pianos where you put a roll into it and the punches on the paper roll told the piano what notes to play. MIDI is a way for computers and musical instruments to communicate what is being played. When you plug your keyboard into your computer and enable it in Cakewalk, then Cakewalk records what notes you are playing on your keyboard (makes a piano roll file). Then when you tell Cakewalk to play this file back it communicates to your keyboard and says play these notes just like a person was sitting there playing these notes. The distinction here is you are recording and playing back your performance (which keys you pressed, how hard you struck the keys, how long you held the keys for sustain, etc...). No sound is actually being recorded, just the PERFORMANCE. When you play it back, the keyboard regenerates the sounds on the fly just as if you were actually sitting there performing the music again. Same thing applies to other MIDI enabled instruments (drums, guitar, saxaphone, etc...). This opens up all kinds of possibilities, you can redirect the recorded MIDI file to a completely different sound or instrument. Example... you record MIDI of you playing piano song, then you have Cakewalk play this MIDI back to your keyboard but you change the sound on your keyboard to guitar, it will play the same song, but now you will hear guitar instead of piano. Get it?
Feb 02, 2009 | Cakewalk Music Creator 2 for PC
Midi keyboard sound quality bad
you are likely running it thru a soft synth. Check the help files there is a section in there on "using soft synths" that will explain it more fully. Plus a usb connection can sometimes be problematic (not always). But the tutorial in the help files will tell u how to use the sounds from the piano instead of the MIDI sounds
Dec 17, 2008 | Cakewalk Music Creator 4
37 people viewed this question
 Grubhead
Grubhead
