Question about Canon PowerShot A75 Digital Camera
No image The display screen wont show anything. It was working, put it in my back pocket then it quit.
I was having the same problem and this worked for me! thanks! Sally
Posted on Apr 11, 2007
Try using a small pin to trip the micro switch that is located at the top of the card door. This switch is a little dodgey if it doesn't make correct contact the camera will turn on but the screen won't display. Did it woth mine and worked after that.
Posted on Apr 01, 2007
LG Screen M227WDP shows only white screen with a version number
Well as you have only had it a few months, SEND IT BACK ( LG does not mean Lifes Good, in the trade we say LG=Lotta Garbage) There have been quite a few chip failures in this model, It should be recalled. Do a warranty call and get it replaced.
please rate my help++++Thanks for using FIXYA
Jun 22, 2010 | LG 42LC2D 42 in. LCD HDTV
MY IPOD 32G TOUCH JUST QUIT WORKING
you can try and restore it. remember it will clear everything from your ipod but you can resync them later after restoration, to restore:
make sure you have itunes running and have access to the internet.
hold down the power/sleep button and the home button at the same time, the ipod will go dark, once it goes dark release the power button while still holding down the home button, and itunes and a usb cable icon will show up.
you might have to do this several times before those icons show up since your screen does not even light up.
now connect the ipod to your computer and itunes should recognized the ipod and follow the instructions to restore your ipod. it will take some time but it worth the wait.
gODD LUCK HOPE IT WORKS.
please rate.
Feb 03, 2010 | Apple iPod touch
Phone turns on, backlight comes on but screen wont work
frist wash the petrol and assid 2 check the display ok any more sent me mail sameer_mishra1@yahoo.com
Aug 24, 2009 | Cell Phones
After i was working in windows media player . i
First try hooking an external monitor up to it. If you cant get an image this way you might have to do a restore with the disks that hopefully you got with you notebook.
Aug 08, 2009 | IBM Lenovo ThinkPad R52 Motherboard -...
My Dual XDM7510 display quit working and I can't find out what is wrong. Everything else on the XDM7510 works. Help me please. It was working when I went in the store came back out and no display.
try checking the illumination light on the back of the radio if that doesnt work then try looking at the red ignitionswitch wire and make sure it is connected to the 12vt constant (the yellow wire)
Mar 10, 2009 | Dual Car Audio & Video
Screen light wont work on Nokia 6288
Ok, here's what I did. I followed this video on Youtube (it says 6280, it works exactly the same with 6288)to disassemble my 6288 (same problem, backlight on the display wouldn't work most of the time) and I finally found there was some leeway on the metal housing that keeps the display in place (so you only need to take out the display over to sort this out). I solved it by putting some bent paper on top of the lower left corner of the metal housing and putting the front cover back in place. Now it gives me no problem at all. I hope this will help you too.
And, to all of those talking about bringing it to the repairman... come on, 6288 disassembly is quite simple (you don't even need the Torx screwdrivers but to get the main board out). Don't make it something more difficult that it is.
Oct 14, 2008 | Nokia 6288 Cellular Phone
I CHANGED THE COVER (6131) AND NOW MY SCREEN GET OUT FROM ORDER
your screen dosnt display anything?I am not quite sure what your asking but ill take a crack at it anyway.you changed the housing and when you put the phone back together the lcd stoped working,if this is the case you either disconnected your lcd or you damaged the flex cable to the lcd,either way you need to open your phone back up just the top part where the lcd is,you should beable to see the flex cable coming from the phone to the lcd if it looks connected disconect and reconnect and try it if this does not work you may need a new flex cable wich means that you may have to get a whole new keypad cause the flex cable usually only disconnects from one side,well good luck
Sep 23, 2008 | Nokia 6131 Cellular Phone
Help
HI SOUNDS LIKE THE RIBBON/FLEXI CABLE
try www.carradiospares.co.uk
Regards
Mark
Jul 31, 2008 | Sony CDX-M800 CD Player
Problem
Two things to try...
A) If you have a card with some photo's on it then put it in the camera... Will the camera display the photos from the card in view/play mode? If so then the screen is working but the sensor in the camera may have died (the but that captures the image).
B) Try taking a picture with the camera (go through the steps to take one even though you can't see anything on the screen). Then put the memory card in a reader or a friends camera and see if the picture did get taken. If so then the sensor is still okay and the fault may be with the display.
If the display will show images from the memory card but doesn't show anything when in picture-taking mode but the camera does take pictures then the camera has a fault that isn't either the sensor or the LCD. It could then be an electronic failure or a problem with the mode selection switch.
Hope this helps to figure it out.
Cheers,
TS
Jan 04, 2008 | Panasonic Lumix DMC-LZ3 Digital Camera
Motorola V3 display
I just experienced this today. Phone was fine last night, pulled it out of my pocket this AM to find the colors like a negative, and text characters in reverse. I googled this "motorola reverse image" and only a couple of posts like yours exist. I powercycled it and it came back up OK... --Ken
Sep 12, 2006 | Motorola Mobility V300
Canon PowerShot A75 Digital Camera Logo
56 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
