Question about EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18)
Power turns on and off
I have recently changed the power supply as the previous one was shot. So it ran for about a day fine and then afterwards if I turn on the power, power supply fan turns on and colling fan on top of the processor for a brief second and then turns off automatically. What you think problem could be?
Your help in this reagrds will be greatly appreciated ...
  • purechgo Dec 20, 2008
    All the capacitor have flat and clear tops. One thing I should have mention is before replacing the power supply the previous power supply toasted. It smell really bad. So that's the reason I had to replace with the new one.
  • Roberta Smith
    Roberta Smith May 11, 2010
    first thing to try is to unplug the power and feel the tops of all the capacitors.... any have rounded tops ... second... smell inside the case.... any burnt smell ?
  • 1,179 Answers
Sounds like a thermal issue. New power supply might be overheating the cpu causing the thermal sensor in the cpu to automatically shut down so the cpu doesn't fry. You could try adding a case fan or two plus upgrading the spu heatsink/fan. Hope this helps.
Posted on Dec 21, 2008
I have no lights on espresso shot panel?
there is a problem existing in the board (IC) you need to replace the board
May 24, 2015 | Nuova Simonelli Premier Maxi Espresso...
Is this a new problem and this ran fine until now? If so, you want to make sure you have power going to the computer, power at power strip or surge protector, cables all plugged in correctly and tight. If all that checks out then the most likely cause is the power supply has failed. If you have had power surges or electrical storms recently this could be the cause. If not, your capacitors in the power supply could just be at the end of their life and died.
Oct 09, 2014 | Dell Inspiron 531s Desktop Computer
97 chrysler concord. wont turn over, has nothing to do with battery, ran fine stopped at store, did not turn over afterward, all lights worked. Next morning started right up, started the next 10 times,...
When it won't start I'm guessing you can not hear the starter turning the engine over. If so when it is acting up it should be pretty easy to see if there is power on the small wire at the starter with the key in the crank position. If there is power there and there is power on the larger wire at the starter, again with the key in the crank position, than the starter is the issue. These are also known to have corrosion issues at the connections on the battery. It wouldn't hurt to give those a peak or even clean up those connections.
Sep 07, 2013 | 1998 Chrysler Concorde
Ok i have a 1999 hyundai accent wont start changed fuel pump and it started ran very bad very! turned it off wouldnt start back up again checked spark plugs no spark and no power going to fuel pump we are...
Changing the pump doesn't affect the spark so lets start a that the beginning?? Why was the pump replaced and was it running fine before changing the pump? Also plugs could be fouled as well but if it was working fine before the fuel pump it will be fine afterwards if getting gas and the fuel pump was the problem., Also how did you verify no spark??
Oct 10, 2009 | 1999 Hyundai Accent
2001 focus. Replaced plugs, wires and coil pack. Ran fine for a few days. Hot day traveld about 28 mile ran fine. then without notice hesitated, loss of power going up hill around 35 -40 sputterd and...
Have you replaced the timing belt? if not i would highly recommend doing so. these cars need to have the timing belt replaced before it breaks otherwise it can and will cause major engine damage.
Aug 10, 2009 | Ford Focus Cars & Trucks
2002 Jeep Grand cherokee
you really need to get to a dealership and check for trouble codes and go from there
Jun 24, 2009 | 2006 Jeep Grand Cherokee
Turns itself off every time I try to take a photo
I had a similar problem with my Cyber-shot S600. It just turned off every time I tried to take a photo. I bought a Sony recharger + batteries and it fixed the problem. Camera works fine and I'm impressed with the how long the batteries last between charges.
Jan 04, 2009 | Sony Cybershot S650 Digital Camera
Presario S4020wm desktop
You need a new power switch. I am currently working on a S4020WM with the same problem. I cut one wire to the power switch, then used a paper clip to make a jumper to start the machine. It has run fine since then. The only trouble I am having is finding a replacement switch.
Sep 04, 2007 | Compaq (480082-001)...
EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18) Logo
51 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
