Question about Logitech Cordless Action (9633200403) Game Pad
Logitech Cordless action controller 2.4 ghz is not working
I just bought this product. I inserted the batteries and I put in on my PS2. The PS2 keeps giving the following message: The dual shock 2 analog controller is not detected. Please attach the dual shock 2 analog controller to controller port 1 and press the start button to continue. What am I doing wrong? Thank you?
  • pgalxdnr Dec 21, 2008
    Thank you?
Try Blowing into the peice that plugs into the playstation or whatever you have, after that, blow into the port that you would plug it into, sometimes dust gets in there. Good Luck. -JD
Posted on Apr 15, 2007
  • 3 Answers
My dad got me a ps2 cordless controller and we put battieries in the controller and when u go to press a botton on the controller it does nothing it a logitech playstation cordless what is wrong or what r we doing wrong?
Posted on Feb 02, 2008
SOURCE:
My mad catz dual force ps2 controller wont work
you will need a dual shock 2 ps2 controller. The mad catz controller is probably a dual shock 1 controller. Some games require the dual shock 2. It should say on the back of the game if the dual shock 2 is required. If it says something along the lines of "pressure sensitivity" or "pressure sensitive" on the back of the game case (where it says "1 player" or "2 player") ... then you will need a dual shock 2 controller. If this is not the case and it only says "analog controller" and "vibration" then you won't need the dual shock 2 controller. If the controller doesn't work for any games or even on the console main screen, then it must be the controller that is broken. Try turning the system on without a game in it and see if the controller works. Hope this helped :-)
Oct 16, 2012 | Mad Catz PS2 Dual Force Controller
I noticed that every time I buy new PS2 Dual Shock 2 it only last for 3 months because I play to much almost everyday then when I try to open the black wire of the dual shock the colored wires some...
Hi, This is happen because : 1. You may bought a non original controller. 2. You may always engage the vibration function. Sony dual stick controller ( analog stick) has fine cables inside controller. The imitation ones even smaller. While you use the vibration function for long time, it make some cables apart.
Suggestion :- Use only original dual stick controller ( analog stick). Don't engage vibration function for long time - I believe you can reconnect the wires inside controller ( so just fix it yourself) and play..
Dec 01, 2010 | Sony PS2 Dual Shock 2 Controller...
Im trying to play dragon ballz budokai tenkaichi3 put but my analog doesnt work at all
Have you tried to press a button on the gamepad so that it switches to analog control?
Feb 11, 2010 | Sony PS2 Dual Shock 2 Controller...
Dual controllers not working
Each wireless controller needs its own wireless receiver. Assuming you have two separate receivers and controllers, there are several possible causes to your problem:
- one of the receivers is faulty
- both receivers are using the same channel
Try both receivers with both controllers individually - if every combination works individually, they are working on the same frequency - exchange one.
Nov 18, 2009 | Sony PS2 Dual Shock 2 Controller...
Ps2 dual shock black controllers are not recognized?
1.) i think u r controller pin is bend are broken
2.) or controller wire is cut
its better 2 buy a new controller
peace out >>>>>
Jul 26, 2009 | Sony PS2 Dual Shock 2 Controller...
On star wars battlefront2 my ps2 controller does not work
Do you have the controller that came with the PS2? If so, is it an original Dualshock 2? If it is, then it should work. If it is not, I think that the only thing you can do is buy another controller. There are also others that work. I have a Logitech Cordless Action Controller that works with BF2.
Jul 05, 2009 | Star WARS: BATTLEFRONT II PlayStation 2...
Options menu dead
hi!there,
well! you can't activate what you want because the button "x" and " triangle" are the function key to move on but because of the pads inside your analog controller on "x" and "triangle"are worn out,there is carbon contactor on buttons has fade out,when ever you press x button no connection is conducting your analog controler.you can change setting on analog controller between x and square depend on you,go to configuration then on dual shock controller menu reset function button,you select a key that will change the function key.
or maybe replace your dual shock controller is the best way,
have a nice day,don't forget to rate me,thank's
Apr 27, 2009 | Sony PlayStation 2 (PS2) Console
Logitech Cordless Action (9633200403) Game Pad Logo
940 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Alun Cox
Argospete
Argospete
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
