Question about Sony KV-27S40 27" TV
My sony KV-27S40 tv does not output sound. I have checked my TV Speakers (on) as well as the stereo system through which I normally send sound signal. When I change channels the code SAP appears on screen temporarily with the new channel number. I do not recall seeing the SAP code in the past. Is this a function that has been turned on accidentally, and which blocks sound output signal? Other suggestions?
    Top Expert:
  • Sony Master
  • 12,962 Answers
Make sure the sap is turned off. When turned on only a sap audio signal will appear at outputs. If no sap signal you have silence.
Posted on Jun 28, 2017
  • 3 Answers
SOURCE: Can't set up the channels on my TV
Some models require two buttons to be pressed together for menu access - usually at the bottom or side.
Posted on Feb 12, 2008
SOURCE: My Sony Trinitron TV does not respond to remote control commands
the tv wont come on the standy timer light is on
Posted on Jan 02, 2009
  • 4234 Answers
SOURCE: SONY TV MODEL kv-27s40 BLINKING RED LIGHT 2 BLINKS
The 2 blinks usually mea an over current problem. Perhaps the most common cause of this is a shortde Horizontal Output Transistor (HOT). If you can solder, you should be able to repair this yourself. Realize that there are potentially dangerous high voltages present inside the set even when unplugged. Look for a 3-legged ransistor attached to a heatsink close to the flyback (part with large red wire coming out the top). The part will be marked C5438 or something similar. Post that marking here nad I'll confirm the entire part number.
Keep us posted.
Dan
Posted on Feb 23, 2009
welcomejee
  • 10594 Answers
SOURCE: how to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Posted on Jun 09, 2009
cactus bob
  • 267 Answers
SOURCE: Sony KV-32s40 (picture flashes in and out)
YOUR CRT (PICTURE TUBE ) IS GOING BAD . this is the most common way a sony tv crt fails . the tv is to old to make it worth a crt . but if your handy and carefull there is a way to get a little more time out of it . start with the tv cold , remove the back and look on the little board connected to the neck of the crt . there is a control marked "SCREEN " plug in the tv and cable and start it , with it flashing adjust that control , one way will make it flash more and one way less , adjust this no more than you need to , just enough to stop the flashing .NO MORE ! just be carefull the voltages in a tv can KILL . dont touch anything else in there and use a little inslated screwdriver to make the adjustment good luck .... if this answer helped please leave me 4 stars rateing , this high rateing will keep me in the paid answer department , thank you
Posted on Jun 21, 2009
I connected my Sony stereo system to the philips
Make sure you turn the tv audio outputs on, use the menu on the tv to do this. Make sure you connect the audio out of the tv to the audio in on the stereo system.
May 01, 2010 | Televison & Video
Sound
You should be able to do so through the menu on the TV. Look for a "MENU" button of some sort on the TV/Remote, then scroll through the settings.
Mar 24, 2008 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Just bought a Sony KV-27ts20 second hand. Great
There might be another solution beside the trash can. You see often with audio problem the fault is the audio output i.c that is gone. Also in the tv menu you may have speaker on/off, make sure they are on. If it still doesn`t work then you may want to try the audio out connectors at the back of the set,there may be sound there. What you`ll need is and audio system with aux/cd/tape input and a rca/phono stereo cable. Just connect the tv out to any free input and turn up the volume .
By the way the tv audio out may be variable(option in the audio menu) which means that any amplified speakers(computer speakers) could be used as long as you have rca connectors on the end of it.
Hope this will help. Good luck
Dec 04, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Good picture, no sound. you can turn the tv on and off and eventually the sound will come on? tried bypassing the hd digital box, still didn't work.
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...thank u!!!
rate me
Jun 11, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Keep us posted.
Dan
Feb 23, 2009 | Sony KV-27V42 27" TV
Power on-off
hi it could be from moving it, you have disrupted the refresh rate, every time ur tv has to change the image it needs to refresh!t is a internal problem that needs to be repaired.
Feb 05, 2009 | Sony KV-27S40 27" TV
TV Sound through stereo speakers while watching tv.
All the above connected method is correct. Need to change the option in the stereo system as md or auillary depends upon the model. Go through user manual for stereo system.
May 27, 2008 | Sony KV-35S42 35" TV
Component Video Connection
what you have done is you are sending a component video signal from your system to your tv and the sound i assume comes through the 5.1 surrond speakers. The DVD's you play the sound would naturally come from the 5.1 surround speakers, unless your instruct the dvd player to send the sound to the tv in which case will only be played as stereo. you will need inputs on your dav system to take sound from your tv outputs or digital box by way of red and white phono leads or a digital/optical input if you have them; so as to play the sound from cable tv or sattelite tv through your 5.1 surround speakers.
Sep 04, 2007 | Sony DAV-SC5 System
Speakers on Sony KV-36FS100
if you could find replacement speakers for this unit, which is probably not an easy task in itself, it would take some know-how and safety measures before you could likely do this yourself. Televsisions deal with Extremely high voltages internally and if you do not know what not to touch, you could find yourself very injured in no time at all... better bet is to simply purchase a small stereo of some sort that allows aux inputs and use this for your speakers instead of the tv speakers. probably cheaper than buying a tv, and hey, may even be worth the upgrade to a surround system of sorts...
Aug 15, 2007 | Sony KV-36FS100 36" TV
Televison & Video Logo
52 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
