Question about Microwave Ovens
General electric profile advantium 120 does not heat up food
Micro wave seems to not heat anymore.  No wierd noised, no unusual behavior, the light comes on, the tray goes around, etc., but the food is not warmed.  It started slowly getting  worse.  Now it dose not heat at all.  Any ideas?  This microwave is only a few years old.
  • mguerra May 14, 2009
    i have the same problem. the light is on and the plate is turning inside but it doesnt warm up my food.
  • Microwave Ovens Master
  • 9,098 Answers
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Some manufacturers will send you the magnetron to do it yourself. If nothing else, you can save about $75 by taking it to the shop yourself.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Dec 21, 2008
My GE Profile Advantium 120 microwave sparks when I try to sterlize a kitchen sponge
Wayne,
If your sponge has any metal in it, that would be the cause of the sparking. The only other thing that could cause sparks is grease built up behind the wave guide cover or the magnetron is going bad.
Jun 13, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
GE Advan 120 micro not heating food. Unit runs and turns normal
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 20, 2011 | GE Advantium 120 Convection/Microwave Oven
How do I change the light bulb in my Advantium Micro Wave. Model is a 120 number SCB1001KSS01. Please send me instructions. Thank you. Karl kflorian5@gmail.com
The service manual is here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 01, 2011 | GE Advantium 120 Convection/Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
HOW TO GET SPATTER OFF ADVANTIUM 120. SOAP & WATER DID NOT GET THE JOB DONE
easy stick a bowl of water and stick it in the wave and boil it.. but be careful to let water cool before you open the wave for a minute or two ! the steam from the super heated water will loosen that stuck on mess .. boiling water in a m wave is dangerous the water will explode when exposed to cool air
Jan 31, 2010 | GE Advantium 120 Convection/Microwave Oven
GE Advantium oven (6 y.o.), has hot spots, makes unusual noise
The drive to the carousel is broken...and what you hear is the drive trying hitting the bottom of drive shaft* (cheaper to replace then fix)
Dec 11, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave not heating every time...
You seem to be having a problem with the interlock device. when you close the microwave door it is supposed to hit a series of 3 switches to tell the microwave every thing is safe and able to run. you may want to take the control panel off and make sure those switches are ok. usually out of the 3 switches top and bottom should be open middle should be closed. you could check with the continuity side of your electric meter.
Let me know if you have any questions before rating me.
Nov 15, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
161 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
