When turn on ht-tz212 it shows protect and turnes off again
Protect
  • dtkh1000 Apr 25, 2009
    the main unit will turn off after display show PROTECT. Can anyone help to troubleshoot this problem? Thx in advance
I the same problem. When I opened the system up I find that I have a burnt out resistor on the power supply board. Can anyone tell me the value of Resistor number SWR60, which is located fairly central on the board.
Many Thanks
Posted on Jan 26, 2009
My aiwa dvd player HT-DV90 won`t stay turned, in the screen shows PROTECT and turns off ...
Check the speakers one by one, maybe one of them are damaged and make the device going on protection
Aug 26, 2011 | Aiwa HT-DV90 System
Samsung HT-TZ312 Stereo System flashes protect and turns off
Turn the unit off.....reseat connector at the power board (supply).After reseating, turn it on again and the protect error will disappear....I have this problem after repairing the optr16 power supply that accidentally plugged into 220v...only the 5q1265rf (power switch)and 9v zener diode connected at optocoupler being damaged. Hope this helps! Mhar fernando from the Philippines
Nov 26, 2010 | Samsung HT-TZ312 Theater System
How to take protect mode off HT-TZ212 samsung dvd player
The protect mode as it means is the safety cut off due to a possible error or shortin in the DVD.
You must have to identify the fault before we can conclude on the position of the fault.
So start from the power supply chek votages, if the main voltages are present. Remove leads to the DVD drive and check, if OK then the drive section is faulty. But fault can vary from the AV section to the decorder stage and to the drive.
The microprocessor control is however working as it indicates the fault.
So proceed by elimination
Sep 08, 2010 | Vacuums
I have a samsung home cinema ht-tz212 keep saying protect and not working
its most likely over heated. Try removing the plug and moving it away from the tv and any heated areas for atleast a day, then try turning it on and it should work..
If it only goes into protect when you put a dvd in then change the regional code.
Feb 26, 2010 | Samsung Audio Players & Recorders
Samsung HT-TZ312 shows "protect" and it turns off
A short on the speaker wires can cause this but most likely your amplifier bias is off or you have a shorted transistor.
First unplug all connections, even the power. Let it sit for a minuit then power it back up.
If it clicks off them it needs professional service.
If it turns on inspect all of your speaker wires for shorts them reconnect them one at a time.
Hope this helps,
Cheers
Feb 03, 2010 | Samsung HT-TZ312 Theater System
My samsung home cinema ht-tz212 wont play discs, just says loading, then open or disc error??? ive tried cleaning fluid lense cleaner with no luck ???
Try resetting the system turn power off then press and hold stop button on Main unit for at least 5 seconds this is main system reset it may well do the trick for you
Jan 31, 2010 | Samsung Audio Players & Recorders
SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Nov 14, 2008 | Samsung 500w Rrss Rear Reflecting Surround...
Samsung ht-tz212 protect!
resistor smr60 is 470r / 470 ohm
Nov 08, 2008 | Audio Players & Recorders
I want unlock my samsung HT-TZ212 to multi region
Aug 09, 2008 | Samsung DVD-V90K Multisystem DVD/VCR
376 people viewed this question
 Grubhead
Grubhead
