Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony trinitron kv-27ts20
My screen has orange circles in each corner and i cannot make an adjustment to correct. it was fine then bam! any ideas? thanks snobbig
  • patrick gibbons Apr 01, 2007
    please advise as to repair or replacement
    thanks
    snobbig
    Sergeant:
    Champion:
  • 326 Answers
Posibbly a PTC assy error. This is used for CRT demagnitesation. Pro will provide efficient cure. If you need more info please advice.
Posted on Apr 01, 2007
SOURCE:
I have a sony trinitron 36in tv, the screen works fine, colours are all great, no flickering or random shapes at all, its just a little blurry around edges, especially small text, its very blurry and...
it is very easy you just need a very small straight edge screwdriver
you should try to adjust sharpness setting with on screen adjustment first
if tv is too old tube might be going "soft" and sharp focus might not be able to be fully achieved anymore
good luck
Mar 13, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony trinitron red green blue circle and distorted screen
have you had a magnet near the screen, it has that effect, it will fade, but most TVs don't have a degauss feature.
Apr 18, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron FV-32FS120 picture has an orange tint
THERE ARE ADJUSTMENTS TO THE VIDEO DRIVE THAT CAN CORRECT THIS PROBLEM/THEY ARE IN THE SERVICE MENU. WITH THE POWER OFF, PRESS MENU-5-VOL+ POWER THE SET WILL COME ON IN THE SERVICE MODE. STEP THREW THE MENU ITEMS UNTIL YOU GET TO RED/GREEN/BLUE DRIVE THEN ADJ. TO BALANCE THE COLORS WHEN DONE PRESS MUTE TO STORE THEN POWER OFF ON THE FRONT OF THE SET OR IT WONT SAVE.
Dec 27, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Just bought a Sony KV-27ts20 second hand. Great
There might be another solution beside the trash can. You see often with audio problem the fault is the audio output i.c that is gone. Also in the tv menu you may have speaker on/off, make sure they are on. If it still doesn`t work then you may want to try the audio out connectors at the back of the set,there may be sound there. What you`ll need is and audio system with aux/cd/tape input and a rca/phono stereo cable. Just connect the tv out to any free input and turn up the volume .
By the way the tv audio out may be variable(option in the audio menu) which means that any amplified speakers(computer speakers) could be used as long as you have rca connectors on the end of it.
Hope this will help. Good luck
Dec 04, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony trinitron TV KV-27TS27 screen remains dark
how do i adjust the brightness if i dont have the controler?
Jul 24, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony TV KV-27TS20
The Flyback is probably shorted (a common ocurrance with this set) get an aftermarket one.
Thanks guy9
Jun 10, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony trinitron 32 " purple area on screen
Check any magnatic device near TV which causes purple color on screen. That device can be Speaker, Electronic toy, Watch like that carring piece of magnet inside. Remove that device and turn OFF your TV for half a hour, then power again. Hope the color will be fine n normal on entire screen.
May 31, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony trinitron kv-27ts20 wont turn on
This problem may come from a bad capacitor in the standby power supply. The part location is C605
This should be an easy fix.
Cheers, CrazyLee
Feb 22, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
95 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
