Question about Maytag MMV4205 Microwave Oven
Light socket is dead on my Maytag
I have a MMV4205 Maytag microwave/hood. One day the bulb in the hood part burned out. When I replaced it, the new bulb would not work, though it is fine. Everything works on the microwave, just not the light socket in the hood. When the bulb blew, did it short something out? Can I fix this with a new socket? Thanks
  • Maytag Master
  • 9,156 Answers
Yes, this is caused by not disconnecting the microwave from the power line when removing or installing a bulb or by the filaments shorting when the bulb blows. This is a problem with the control panel assembly, which we repair nationwide for $39.95. If you or a friend decide to send it to us, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Apr 01, 2007
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
How to change the hood light
By hood light I assume that the light you want to replace shines from the bottom of the unit, not the light inside the microwave. If so check out he Disassembly video on this site: Maytag Microwave Light Bulb Not Working
Jan 02, 2015 | Maytag MMV5207BAW Microwave Oven
The microwave isn't working all the power is off
check to see if the power from the wall socket is there. Plug in a lamp or somthing. If it works, then the microwave burned out an internal fuse, or curcuit board.
Oct 08, 2012 | Maytag MMV4205 Microwave Oven
The bulb light inside the microwave went dead with the microwave working perfectly...how do I replace the bulb?
Replacing the cavity light requires taking off the outer wrapper to access the bulb. Nothing easy or magical just an exercise in patience.
Eric
Jul 05, 2010 | Maytag MMV4205 Microwave Oven
When I was unscrewing a burnt out hood lamp on
I would not use the lamps. Sounds like there is a shortage in the wiring for the lamps. They lamps should run together, and if one of the sockets have a short or burned wire it will not let it complete the circuit. This could be a fire hazard, so I would replace the whole microwave. It would be more trouble to tear it apart and find the exact problem than it's worth.
Jan 04, 2010 | Maytag MMV4205 Microwave Oven
Light
did the side with the hole have a clear or frosted cover? If so look up inside the hole to see if the socket may be pushed back up insde.
Aug 24, 2009 | Maytag MMV4205 Microwave Oven
Over the Range Light Bulb
"Appliance Parts Pro's" web-site bet they will have it or can get you the exact thing you need
Jul 18, 2009 | Maytag MMV4205 Microwave Oven
Maytag MMV4205 Microwave Oven Logo
232 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
