Question about Dell Inspiron 8200 Latitude C840 Laptop Keyboard03J247 CD-ROM Drive
C840 will not boot up
When the power is turned on - the led 's come on and the center lite--the little lock with the "A" on it flashes a half dozen times and then power turns off. The other 2 little lock lites don't come on at all. Tried the memory sticks thing but that didn't work. Can anyone please help?/ Thanks.
  • Anonymous Jan 08, 2009
    Mines will freeze after awhile or if the laptop is moved it will freeze or shut down instanly. And wont boot up unless i keep pressing hard on the keys and around the trim around the power button. Will be good for awhile....checked connections under the trim piece around the pwr button. Help?
  • 247 Answers
Quick power off means a hardware fault. Remove the memory sticks and boot the laptop. If you get an error message, the memory sticks are bad. Replace them. If it still doesn't boot to BIOS, your motherboard has failed and needs to be replaced. It can't be "repaired" cost-effectively. And since the Inspiron C840 is a very old laptop, probably not worth fixing. You CAN get your data off the hard drive by slaving it to another computer. Google " hooking up an external hard drive".
Posted on Feb 05, 2018
Demmy
  • 59 Answers
SOURCE: motherboard
One of the greatest factor in intermittent shutdowns is because of heat issues. try to check the fans if they are all spinning. if all fan's are ok then you only need to replace the motherboard. here's a manual that might come in handy http://support.dell.com/support/edocs/systems/dim5100/en/sm/index.htm
Hope this helps.
thanks
Posted on Nov 13, 2007
  • 104 Answers
SOURCE: motherboard
Here is what you need to do. Disconect the module with the usb ports from the motherboard. It took a while for me to figure it out but a damaged usb port will make the computer go nuts.
Posted on Sep 14, 2008
  • 998 Answers
SOURCE: Dell Lattitude C840 Laptop
The 3 LED's (Num Lock, Caps Lock, Scroll Lock) are used by Dell to diagnose no-post issues such as yours. The only error code close to yours is [Num Lock ON, Caps Lock FLASHING, Scroll Lock ON]. This indicates a a memory error. Try reseating the memory modules. If you have 2 memory modules, insert one at a time to determine the faulty module.
Posted on Oct 16, 2008
SOURCE: Dell Inspiron 6400 won't power up...
Most probably the seating of the processor on the motherboard is not proper
check this site and mount the processor properly
http://support.dell.com/support/edocs/systems/ins6400/en/sm/cpu.htm#wp1084976
Posted on Feb 02, 2009
SOURCE: dell 4600 desk top, at boot up lite stays yellow, at same time the 17" dell monitor lite goes from green to yellow in about 2 seconds. thanks-randy
bought a new one. thanks! rg
Posted on May 18, 2009
Why won't my Samsung LCD tv boot properly at startup
Hi Tom,
This is becoming a theme with Samsung TV's, Samsung have extended warranty cover for some customers with this problem, have a look at this post for more info and the link to Samsung:
have 60 Samsung led tv Sound keeps cutting out all night for 3 5 seconds...
Feb 13, 2016 | Samsung 9000 Series UN65F9000AF 65" 4K LED...
DS Lite Will Not Power On
There is a possibility that your battery has developed a short circuit or is so bad that it pulls down the charge voltage on the charger. You are therefore left starved of a power and therefore no function.
If possible, disconnect the battery and run the DS on the charger power alone. If the DS starts to work, I suggest replacing the battery.
Sep 05, 2014 | Nintendo DS Lite
Why does dslite have no power?
Make sure the ribbon cables or the screens are plugged in. one for each screen and one for the touch screen (i think the touch screen is the one thats causing your problem) its small and comes out easily. please wright back if it works
It works intermittenly
3) The LED turns on or flashes red during initial boot up :
When the temperature inside the car is too high or too low, the red LED flashes. In this case,
follow the steps below.
Turn the product power off and ventilate the car to return to normal ambient temperature.
Turn the power on after a little while and observe the LED color.
If the red LED still flashes under normal temperature, contact customer service.
Ref: Plenio VXA3000 Users Manual Pg 5/6 1-4 Troubleshooting
DVSSynchrome_VXA-3000_UserManual.pdf
Download Files At MS Skydrive Email jeffreydrescher@Bellsouth.net For
Login and Password
Dec 23, 2013 | Digital Video Systems Plenio VXA-3000 GPS...
Lite way rascal 3 red light flashes constantly to indicate sleep mode.I have switched on and off but there is no response.Micro switch ok.Happened before and switching off cured it.also leak on axle which...
According with the manual...
LED Flashes 7 times means a Throttle fault. Engager levers must be in neutral (centered) position before venicle is turned on. Paddle fault and speed pot fault. Switch vehicle off center levers and switch back on.
I suggest contact the technical service supoort to solve it.
Hope helps.
Mar 20, 2011 | Electric Mobility Golden Liteway Scooter...
I have a '96 samsung 25" tube tv. model # TXE2546 - series # 3CAG700429. when i turn it on it has always made a click sound a couple of seconds afterwards. the "power & timer" led light flashes about...
This problems the FBT-the Flyback Transformer have cold solders.Must resolders the FBT.The right side wall of the FBT-the "H" horizontal transistor,must be also resolder too.
Oct 18, 2010 | Samsung TXJ2754 27" TV
I have a sharp 37" lcd tv,model # lc37sb24u. no pix or sound, power lite comes on about 10 seconds then power and opc lites alternate on and off. thanks RON
This problems very common in Sharp LCD tvs.The Tuner signal board have problems,every times the power LED,OPC LED lites up,just push the power button on again,wait see if the LCD backlight lite up and works,not the Power lite and the OPC lite LEDS flashes again.You,just have to push the power button again,sometimes u have to push the power button at least 6 or 7 times to get the Power LED stable,and then LCD backlight,come on than the tv work.Not sure,but if the Power and OPC lites keep flashing,after u pushes the power button at lest 10 or 12 times,and the LCD backlight dosen't come on and the tv don't work.I think,it time to change the Tuner board is completely dead.I have a Sharp LCD tv, I do this everytimes pushing the power button at least 3 or 4 than the power LED stable,and the LCD backlight come on than the tv work.Not a plaw in the power supply like those capacitors in many LCD models tvs,but some included Sharp Tvs is the Tuner signal board is not very good in design,use the tv awhile the Tuner signal board have problems recieving the power to it Tuner board components.
Apr 15, 2010 | Sharp LC37SB24U 37 in. LCD TV
I have a dell latitude d820 since 1 year now .yesterday i power on but i get nothing ,just the power led is on and the bluetooth is flashing nothing else just black screen .I hold the Fn key during i press...
Problem wid RAM. Don't worry probably displaced from position due to impact. Go to service centre and get the RAM checked and get it positioned properly. Open the BIOS and check the RAM configuration again. The problem should have been fixed.
Don't worry, already faced this!!!!!!!!!
Mar 28, 2010 | Computers & Internet
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Computers & Internet Logo
49 people viewed this question
Clive
Clive
Alun Cox
