Question about Kenmore 63942 Dryer
How to get to motor on kenmore dryer
Any assistance on how to get to the motor on a kenmore dryer? thanks!
  • 71 Answers
Remove top then front
Posted on Dec 20, 2008
Kenmore Elite 110.7208201 won't heat up.
Hi
Please check the things that could stop a electric dryer from heating:
- House fuse or breaker (needs two of them), heating element, burnt wire, thermostat(s), thermal fuse (not all models), motor heat switch, timer, selector switch, burnt power cord/plug.
And also check the things that could stop a gas dryer from heating if you have a gas dryer:
- Glow bar igniter, thermal fuse (not all models), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 29, 2009 | Kenmore Dryers
Sears Kenmore clothes dryer 11072812101 noise at startup.
Its either a belt, roller bearings, the tensioner, or the bearings in the motor.
Each is replaceable, but to find out the problem you are having, you will need to remove the panels of the dryer and inspect each one.
hope this helps
Aug 13, 2009 | Kenmore Dryers
Gas dryer - kenmore 110.73932102
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 02, 2009 | Frigidaire FDE336RE Dryer
My kenmore dryer turns on and heats but
Hi, It is most likely the belt. Here are the instructions for the most common dryer. If this doesn't match up to you style dryer, please let me know your model # and I can assist you. UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off.
There should be instructions that came with the belt. I will try and explain how this goes on. The idler pulley fits in a slot right in front of the motor. Put the belt over the drum with ribs touching drum. Now, thread the belt through the idler pulley wheel and bracket and set the belt on the motor pulley. The ribs should rest in the grooves on the motor pulley. I am also sending you a picture of how the belt threads through the idler pulley.
I hope this helps you. If I can assist you further, please let me know.
Thanks
Jul 18, 2009 | Kenmore 60172 Electric Commercial Dryer
My gas dryer isn't producing any heat. If there is a service technician on kine now, can someone assist me with what they think it might be?? It starts and goes the while time, just doesn't dry the...
Hi
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Kenmore 74602 Gas Dryer
Kenmore electric dryer 6681290 runs for about 10 minutes then shuts off
HI, When the dryer stops, can you restart it right away? If it will not start right away, your motor is overheating and will need to be replaced.
Thanks
Vic
May 18, 2009 | Dryers
Blown thermal fuse on Kenmore dryer
I need the serial# to assist you better.
Thank you for trust fixya.com
May 14, 2009 | Dryers
Lady Kenmore electric dryer broken start button
it is time to replace it, that sound and smell is from the dryer motor itself.
Jun 28, 2008 | Dryers
Kenmore Dryer Timer does not advance
Timer resistance is way too low. You may have misswired the new timer. Basically, when the dryer motor is running, the timer motor gets voltage 115 volts.
Apr 14, 2007 | Kenmore 64902 Electric Dryer
Kenmore 63942 Dryer Logo
48 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
