Question about Kenmore 33078 Bagged Upright Vacuum
Vacuumstps working while using the vacuum for about 5 mnutes the machine stops working. after sitting for 25-30 minutes it will restart but only run for 2-3 minutes. checked for clogged bag-ok al power hook ups are fine. all visual inspections are ok. what to do? thanks snobbig
    President:
  • 1,462 Answers
There is an overheat stat which cuts out motor if insufficient air flow. there must be a blockage you hav'nt found - probably in the air path from the brush roll to the fan
Posted on Apr 01, 2007
Pump stops after about 5 minutes use
We know how frustrating it can be when the steam stops when you're trying to clean.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=18994&cid=ccsocial
Feb 27, 2013 | Bissell 3 in 1 Steam Mop Deluxe Hard Floor...
Tip
Miele vacuum cleaner suddenly stops
So this is a problem I identified in Miele's mid size ranged canister cleaners. Not only the S318...
If you go about cleaning on the highest power setting the engine will overheat after 5-10 minutes. It then will need around 20-30 minutes to cool down before you can use it again.
Tip: Don't run the machine on 100% power, instead turn the setting to around 80-90% and then you can enjoy good suction un-interrupted.
on Jan 28, 2010 | Miele S318 Bagged Canister Vacuum
It was working fine and them just stopped it is not that old and was not making noises HELP!!
Vacuum cleaners have electric motors in them that require proper airflow to pass over them to keep them cool. Many vacuum cleaners have a thermal (heat) sensitive shut off mechanism built in. This mechanism should prevent the burn out of the motor. If you run a vacuum too long with a clogged hose or clogged filters (especially bagless vacuums) or clogged bags, that is essentially choking the vacuum for air and not allowing it to breath properly. This will cause it to overheat and shut down. Most of the big box store purchased vacuums have very thin wires in the motor windings and can only do this a few times before the motor completely fails. If your vacuum has been shutting down, then cooling off and restarting after about 30 to 45 minutes, then shutting down after only a few minutes of use, your machine is probably clogged up or the filters are compacted.
Jul 05, 2011 | Vacuums
The vacuum stopped working while i was using it...did all the troubleshooting tips.. still not working.
Sometimes the vacuum will overheat, if this happens the vacuum will shut down to protect it from damage.
Unplug the vacuum, and let it sit unused 30 minutes.
Please let me know if this has solved your problem.
Mar 11, 2011 | Electrolux EL7020A Oxygen 3 Ultra Canister...
After using the vacuum for a while it would stop running. After sitting several hours it would run again. Now it won't run at all. It was just a couple of months old and I haven't been able to use it...
If you would take the machine all apart in little pieces, you should find it is clogged with dirt or hair or whatever you have been vacuuming up.
Different brands of machines will last longer or shorter periods of time because of plugging up.
Most all of them can be cleaned, but some will just clog again quickly.
I personally use "Consumer's Report" to find good machines.
God bless your efforts.
Dec 07, 2017 | Dirt Devil M130000 ''i'' Dual Cyclonic...
Stops after a few minutes
Its overheating, so the TOC (thermal overload cutout device) is cutting the power to the motor to protect it.
Thats why it works when it has cooled down.
Check for blockages and make sure the filters are clean, if it still happens take to an approved engineer to check the TOC
Sep 20, 2009 | Hoover U6630-900 WindTunnel Bagless...
Dusty smoking smell, stops working, trips out power in house.
you forgot to say if it is a 3 phase machine
if it is 3 phase then a phase in the unit is overheating and that will stop the machine then blow the breaker as all phases have to draw equal current
if it is a single phase then the start/ run capacitor or centrifugal start run points are not breaking at speed and so the start windings are overheating and causing the breaker to trip
Take it to an electrical motor rewind shop and have it properly tested with test equipment
Oct 21, 2017 | Hoover F6212-900 / F6215-900 SteamVac...
Dyson dc07 animal
This is from the Dyson web page:
Get expert help Thermal cut out Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting.
Any non- domestic use may adversely affect the filter performance such as vacuuming up plaster dust.
Sounds like your vacuum is overheating. Check the above.
Lou
Aug 30, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover Mach 5 sweeper
Hey all...
Had this same problem with my Mach 6 (same as Mach 5)
It would shut off after 15 min of use. What is happening is the secondary filters, HEPA and the canister all need to be cleaned. This is vital. What the vacuum repair people are keeping from you is that tidbit of wisdom. This particular vacuum is picky about airflow. Pull the canister, and on the body of the vacuum on top of where the canister sits are the secondary filters. There should be a sticker explaining how to remove them. Clean them throuougly, mine was filthy. Make sure you clean the canister by unlocking it and cleaning out the micro holes and the cone end. Mine was completely plugged. Now brush the dirty side of the HEPA filter with the combo tool. Let the secondary filters dry completely (you can blow dry them on cold) Re-install everything, and the vacuum will run like brand new. I vacuumed the whole house after I completed this maintainence and it works like a champ. Don't return this vac until you clean it completely.
Jan 28, 2008 | Vacuums
Hoover u5720-900 quits running and restarts again after some time
There is one more filter under where the collection tank & Hepa filter sits -- there is one screw that holds the cover down - remove that filter and clean it that will help. I also find I need to vacuum the hepa filter as well- it is too expensive to replace all the time. The Hepa filter can be placed inside a plastic bag and shaken really good to get the dust off of it
Jul 27, 2007 | Hoover U5720-900 WindTunnel Upright Vacuum
Kenmore 33078 Bagged Upright Vacuum Logo
304 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
