Question about Jandy Laars Lt 250,000 Btu Heater
Heater will only heat spa water to luke warm.
The Laars LT heater will only heat the spa water to a luke warm temperature, no where near the 102 C preferred temperature. Backwashed filter to make sure that it was not a high pressure problem and still no performance to heat the spa water above luke warm.
Water temp governor on the water temp dial setting is set so that you should be able to heat spa to 105 C or so.
  • 1 more comment
  • verypgrandma Dec 22, 2008
    Thank you. I replace the temperature sensor thermistor and the hot tub returned to nominal operation and heated the spa water to a much warmer level. However, doesn't seem to heat the spa water to 104 F, but still much better than luke warm level experienced prior to temp sensor replacement. There does not appear to be a bypass mechanism on the heater, however, the manual does refer to a very complicated water flow adjustment procedure.
  • ifixpools May 11, 2010
    Its probslby still a small failurein the bypass. You should have it looked at by a pro.
    Does the heater actually turn off before getting hot or it is continually running and not getting to the desired temp? If it shuts off well before 102, you have a bad temp sensor. It is basically recognizing the water at 104 and shutting down. If the heater keeps running and you can say it has slowly taken longer and longer to heat, you have a broken or stuck internal bypass assembly. with this condition, there is more water bypassing the heater than actually going through it. Symptoms of that would be a popping or knocking sound while running as the heater is acutally boiling what little water is in it.
The water in my arctic spa hot tub took 2 weeks to get to 102 should it take that long ?
Posted on May 02, 2009
  • 125 Answers
Sounds like it may be the thermostat on the heater. You are correct to check the filter first. if it is clean then it is probably the thermostat
Posted on Feb 26, 2009
4 Suggested Answers
  • 22 Answers
SOURCE: My Heater is leaking water from underneath.
yes you can replace the core but you should check all the other components to be sure the chlorine hasn,t destroyed them.
Posted on Feb 21, 2009
PartsCenter
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
  • 10 Answers
SOURCE: I have a Jandy Laars LX Pool/Spa Heater...when I
If the unit is lighting then shutting off then repeating it isn't rectifying, means not sensing the flame. May have a bad flame sensor or ignition control. I'm guessing your AGS is indicated on the GUI also.
Posted on Mar 07, 2010
I have a laars jandy 250 lt gas pool heater that only heats luke warm. The heater cycles normally then heats up but stops before reaching operating temp. No service lights and thermal switches are g
I do not have a handy but mine has a temperature setting at the heater and one on the remote. it is possible that one of the settings is low. the pool or spa temp is sensed at the heater and with the water temp located in the pool lines. so both the control board and the heater are sensing the water temperature.
Oct 09, 2014 | Jandy Laars Lt 250,000 Btu Heater
Hayward hd100id blower works water luke warm
It sounds like the thermostat is turning the heater off before it gets the water to temperature. It is probably the sensor, as that is the most common cause, but may be otherwise.
Nov 28, 2013 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Pool heater won't heat water
How big a pool? You normally will not notice a temperature rise immediately. On average, swimming pools will see a one degree rise in temperature every 45 - 90 minutes.
Jan 22, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy LAARS LT pool heater blows out the fusible link. What could be the cause?
check for a heater that is leaking current to the water jacket and this would be a ground and if enough current leaks to ground it will open this link you can check this by undoing the heater,then if its ok then you know its the heater or by checking with an ohmmeter
Mar 23, 2011 | Jandy Laars Lt 400,000 Btu Heater
Laars LT - "red" light
means calling for heat if heater doesn't come on check safety circuits
Feb 12, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My heater ignites and blows really hot exhaust
The water is mixed on the back side of the heater and will exit the heater at 7-11 degres hotter than it came in. This will keep people from being scalded at pool side. So what you have sounds normal.
Apr 05, 2010 | Hayward H Series Pool & Spa Heater 400k...
Power light blinks after blower turns on. Water is barely coming out luke warm after 30m of running. No other status lights lit.
The water is mixed with cool water as it leaves the heater and will only be eight to ten degres hotter than when it goes into the heater so as to avoide scalding. You need to ck the total heat rise of the water after about an hour in a spa and after about three or four hours in a pool.
Nov 21, 2009 | Jandy Laars Lt 400,000 Btu Heater
Laars Lt spa heater service light
replace temp sensor its by the plumbing inlets or mounted to top of heat exchange
Feb 22, 2009 | Jandy Laars Lt 250,000 Btu Heater
Jandy Laars Lt 250,000 Btu Heater Logo
1,734 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
