Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
No picture on monitor when hooking up for the first time
Trying to hook up computer for first time. everything works but
no picture on monitor HELP
    President:
  • 1,996 Answers
There are control buttons on the side of the monitor. Are you sure you have pushed the button to power the monitor on?
If so, this is the troubleshooting step for No Image on that monitor:
No Screen Image
• Make sure monitor is turned on.
• Make sure the video cable is securely connected to both the monitor and PC or
Audio/Video apparatus.
• Make sure you have selected the correct video input source
• Adjust the brightness and contrast levels.
You can view an online copy of the user's guide here: http://www.westinghousedigital.com/pdf/60_User_Manual.pdf
I hope this provides a solution to your problem. If not, please reply with a report of the steps you've taken to work through it, and we'll try to sort it out.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
I hope this help you to
Posted on Mar 28, 2009
Monitor says no signal and will not run a dvd
It could be a couple of things. If this monitor is hooked up to a computer, it could be a bad video card. A video card is easily fixed on a desktop, if you're using a laptop you're probably out of luck.
If it's hooked up to a DVD player, check that the cord to the monitor is hooked up properly (make sure the connection goes from the "Video Out" on the player to the "Video In" on the monitor and that all connections are tight, not barely hanging on). If that doesn't work, try a new cable.
This is probably insulting, but also make sure that the monitor is set to the right channel if it's multichannel. For example, if your DVD player is hooked up to HDMI 2, make sure the monitor is set to use HDMI 2 for signal.
If none of these work, it's time to find a tech-happy friend that can inspect everything visually. Hope that helps!
Feb 21, 2012 | Dell Computers & Internet
I am trying to hook up a 500 mhz computer and use the tv as the monitor. the plud and play driver brings it up on screen, but I can't seem to get the whole normal picture for windows on the screen and...
right click on the background of your destop and select properties. go to the settings tab and change the screen resolution till the picture is normal size. there is a box to select to make my default monitor which will move your windows bar from the computer monitor to the tv.
Apr 07, 2010 | Mitsubishi WS-65313 65" Rear Projection...
My monitor show a picture for about 3 seconds and the n goes blank
Try a 2nd monitor on the cpu and see if the same thing happens. If the same thing happens then the video card is bad on the computer. If you hook up the 2nd monitor and everything is working then you know the original monitor is bad.
To me with the picture showing and then going out like that, that tells me there is a problem with the lcd itself but to replace that would be more then the cost of a new LCD.
Jul 08, 2009 | Advueu Technology ADV175B (Black) 17 in....
I hooked up my new acer p191w to my dell laptop 1525.HELP!
Not sure what the problem is, but I would suggest pressing the Fn+F5? There is a function key that toggles from dual screen, just the laptop screen or just the monitor. Hope that helps..
G'luck
Nov 11, 2008 | Acer Computers & Internet
I DON'T GET A PICTURE WHEN I HOOK UP MY LAPTOP TO MY TV MONITOR.
on your laptop keyboard, press function button & monitor button at the same time .
Oct 18, 2008 | Computers & Internet
Monitor too bright
Your video card (or driver) is probably to blame.
Try hooking a new monitor up to the computer to test this.
If so, try the advanced settings in control panel. Many cards give you the ability to manually alter the picture.
If that doesn't fix it, replace the card.
Mar 14, 2008 | Acer AL1916W 19" LCD Monitor
Hooking up a HP L1755 17
What is the way to get the very best picture quality when hooking up my new HP L 1755 Flat Screen Monitor to my E-Machine W3052 which is about 3 years old.First would it be compatible or the best idea to hook up VGA to VGA.DVI to DVI which means buying a new Video card for my Computer so the DVI could be hooked up to my computer, or hook up the DVI to VGA Connector ? Would a DVI Video card be worth the extra costs if I went that route ?This HP L 1755 only has a response time of 25 ms, is that good enough to watch Music Videos or not ? I do not do any gaming.Can you tell me the best detailed step by step way to hook up this monitor to my E-Machine W3052 Computer and which Connector to use ? If I need a DVI Card what would be the Part number or Card I would need to get ? Sorry about all the questions.Any guidance and input would be greatly appreciated since I have a disability and need some help and to be honest I do not have 50.00 for a DVI Video card. Sincerely & God Bless ! Thanks,Diehard16
Feb 18, 2008 | Computers & Internet
Astar flat screen monitor
i need help getting my astar flat screen tv to power on. the blue light is on in the center of the tv
Dec 24, 2007 | Astar LTV-2701 27 in. HD-Ready LCD...
Yellow hue
My name is Todd and I'm with Dell's online outreach group.  Have you tried hooking that monitor up to another system to see whether it's the monitor itself or the system causing the problem?
Is the color distortion always there, or is it only happening at certain times or with certain applications or programs?
Let me know if you're able to try this monitor on another system, or another monitor with this system.  If not, we can try a few different things to test it.
Thank you,
Todd
Customer Advocate
Dell, Inc.
http://direct2dell.com/one2one/archive/2006/11/19/3648.aspx
Oct 08, 2007 | Balance CM2019 19" LCD Monitor
Everything has a yellow tinge.
Have you tried giving it a good tap on the side? Hey its worked before. Have you tried hooking it to another machine to verify "yellow." Was it yellow on your friends computer? How old is the monitor? Good Luck, Tim
Feb 07, 2007 | Dell UltraSharp 1701FP 17" Flat Panel LCD...
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
156 people viewed this question
Top Westinghouse Computers & Internet Experts
Steve Allison
Steve Allison
Jim Goldsmith
Jim Goldsmith
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
