Question about Canon PIXMA MP600 all-In-One InkJet Printer
Mp600 error 6000 and wont print
  • frewil4 Mar 26, 2009
    When I am trying to print, "error 6000" pops up, and it wont print.
    Problem Solver:
  • 10 Answers
If you remove the transformer block ( the one in witch you insert the power cord... is secured with two plastic restrains ) you may see a small electric drive... engine name it as you wish with two blue wires ..
those two blue wires are the positive power coupeling on it ... if they are removed you get error 6000. The removal of the two blue wires may occur when moving the printer or if you remove the transformer block from the printer. put them back to the electric engine, and you will resolve the canon mp600 6000 error and possible other serie two ( the error is standard for most MP series and even IP). Be shure to unwind the blue wires around the small ring or else the wires will pop off the couppeling when you put the transformer block back. It is a pain in the back to recoupple the blue wires into the elctric drive but it can be donr without opening the whole printer(witch is a huge pain in youre back side).
I reffer to the transformer block as the ac\dc block witch feeds power to the printer. For any problems adress me at alexmi88@yahoo.com
Posted on May 29, 2009
Error 6000
If you're gettting the message "Canon printer error 6000," it may be related to a LCD error, so to fix it reset the printer by pressing the ON/OFF button.
It can also be related to a paper jam, so check for that and if you have had one and cleared it, make sure there is no paper left inside. Once this is done, again reset the printer
Jun 05, 2014 | Canon PIXMA MP600 all-In-One InkJet...
Shows error message 6000
You should try to reset the unit.
To reset first switch off the unit then Disconnect the unit from power supply/batteries then disconnect any other units connected to it, after that Leave it disconnected for 30 minutes. It should reset itself then start again.
Try this:
1.Press ON/OFF switch to reset the multifunction device 2.Removing paper jams MP600 3.The MP600 may require repair
Oct 27, 2010 | Canon Office Equipment & Supplies
Error message 6000
6000 is a paper jam or jammed sensor.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#ServiceAndSupport
Click service and support, then enter error 6000, then click Error LCD ... 6000..., then click Removing paper jams mp600. Sorry, but they use javascript so I can't give you a more direct link.
Sep 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Printer wont feed paper through to print on
there are a lot of steps that u need to follow.. I tried to get the detailed link but it didnt seem to work properly.. so try this link below.. http://tinyurl.com/2kdp28 once on this page.. go to support & service.. and search for FEED PAPER... and select the second answer there.. and follow steps there.. let me know if this was helpful to u.. regards, guru
May 05, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Cannon Mp600. I have an error code 6A00
Try
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Jan 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
What does error 6000 mean on Canon MP630? It keeps telling me it's printing then the paper runs through without anything being printed on it. Thanks for any help.
Error 6000; Fehler 6000.
"Error 6000 is a mechanical problem of paper-input." (Hotline)
Remove paper-tray and check the rail inside as deep as you can see. (look for stuff!) Then try again. All other atempts are hopeless and send it to service.
Ich habe die abstrusesten Antworten im Net gelesen:
z.B. "Fehler 6000 bedeutet, dass die maximale Anzahl der Drucke erreicht ist und das Gerät wegzuschmeißen ist!"
Ich habe beim Service angerufen. Die meinten, es liegt ein mechanischer Fehler im internen Papiereinzug vor.
Das Gerät muss eingeschickt werden. Reparatur von eigener Hand aus nicht möglich.
Papiereinzug? Ich habe dann die Schublade einmal ganz rausgezogen und nach Störteilen auf der Schubladenbahn gesucht.(und gefunden!) Tatsächlich ging die Schublade danach sehr leicht wieder rein und der Drucker lief wieder. Alle anderen Recherchen sind m.E. vertane Zeitverschwendung!
Nov 26, 2009 | Canon PIXMA MP600 all-In-One InkJet...
What is error 6000
I the paper is jammed. Purge unit is jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Jun 26, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Difficulty printing
First of all, delete all the copies of that printer in the folder and try again. If possible delete them all and reinstall the printer.
Apr 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP600R
Hi Are you Running Lavasoft Spybot? I have been informed this causes the error 6000
Hope this helps
Regards,
Tony
Jun 18, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
656 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
