Question about Sony KP-61V90 61" Rear Projection Television
Color yokes for KP-53XBR45
Does anybody have the parts numbers for the Color yokes for Sony KP-53XBR45 TV. Also is it the same yokes as the KP-61XBR48.
Thanks!
  • 6 more comments
  • du13 Dec 19, 2008
    Yes - I am asking for the yoke coil on th CRT. Last night my TV went back with a red oval on the screan. A few seconds later the picture turned back on with the colors out of balance and a red hue on the screen.
    I would imagine this is caused by one of the CRT guns failing.
  • du13 Dec 20, 2008
    Picture did not come out well - best way to describe - it seems that all whites on the picture is now magenta. The hole screen has a magenta hue.
    Thanks
  • du13 Dec 20, 2008
    More than anything - the whites appear magenta - pink.
  • du13 Dec 29, 2008
    I opened the back of the unit - all 3 colors light. it just seems that the red is overpowering. When the initial problem occured - the TV went black and then a red oval appeared on the black screen. The TV then booted with a magenta tone throughout. It also looks like all the whites in the picture are replaced by the magenta.
    Thanks
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    So, you are missing green color in TV?
    Yoke is / are OK in your TV.
    Problem seems in convergence out area and I can advice you with better understanding if you can post image of TV here showing its problem. You can post image up to 150k of jpeg format.
    Are you asking Yoke Coil that fits on neck of each CRT (3 CRTs) in rear projection TV?
    Green gun is not working in your TV, you can confirm it by opening back cover of TV where you will see 3 lenses. Red-Green-Blue.
    Let me know do you see green lens is bright?
    Problem Solver:
  • 10 Answers
1-451-441-11 for the Red and Green tubes
1-451-441-21 for the Blue
Posted on Dec 19, 2008
Need part # KP-53XBR45, convergance IC
The convergence ICs are STK392-010, the locations are IC1601 and IC1602.
Apr 18, 2010 | Sony KP-53XBR45 53" Rear Projection...
Tip
Sony KP-53XBR45 Service Manual Download
Download Sony KP-53XBR45 Service Manual
Would you like to download a free Sony KP-53XBR45 Service Manual?
Have you lost your Sony KP-53XBR45 Service Manual?
Would you like a digital, searchable, pdf version of the Sony KP-53XBR45 Repair Manual?
Follow this link (& click FREE) to download a pdf version of the Sony KP-53XBR45 Service Manual documentation.
I hope that helps.
___________________________________________
on Jul 04, 2010 | Televison & Video
Tip
I hope that helps.
on Jul 04, 2010 | Sony KP-53XBR45 53" Rear Projection...
Sony KP-53XBR45 i have a bad convergence board. Do I fix it or replace it. Where is the part available
Replace convergence out ICs to get it fixed.
You can replace these chips if you can replace parts in circuit board with proper tools or ask local tv tech.
Required ICs are available with Part Store.
Thanks.
Mar 19, 2010 | Sony KP-53XBR45 53" Rear Projection...
Stand by on my sony kp-53xbr tv is blinking steady
That can be caused by lots of different things going wrong. You will not be able to repair that yourself, and will need to have a technician look at that kind of a problem.
Dec 04, 2009 | Sony KP-53XBR45 53" Rear Projection...
My kp 53xbr45 will not turn on, the stand by light only flashes
Ck Blue capacitor next to hori out out transistor 2Kv high voltage cap. then where your STK ICs they are big black ics will have part number on them most of the time one of them is bad and will shut tv off always replace both ics and CK all pico fuses around ICs they look like resistors but are fuses they are Green or yellow.
Aug 07, 2009 | Sony KP-53XBR45 53" Rear Projection...
Pip
Please download user manual of Sony KP-53XBR45 and get reply of all your questions about tv.
Regards,
Sep 19, 2008 | Sony KP-53XBR45 53" Rear Projection...
KP-53XBR45
yeah, they only keep parts for so long which makes it much harder to find anything, if that number falls through, I suggest calling a tv repair place and asking them for help. I bet you will find the part but if not, everyone could use the exercise right? have a good day.
Mar 29, 2008 | Sony KP-53XBR45 53" Rear Projection...
KP-53XBR45
If you buy the service manual, you can check that for the part otherwise I would just call Sony at 800-488-7669 and they should be able to send a new one to you. Good Luck.
Sony projection blue double vision KP-61XBR48 mod #
Joe, did you have a tech confirm it`s the yoke? Not a common problem to have a yoke failure, maybe yoke return resistor(s) or possibly bad convergence IC`s, poor signal from DCU (digital convergence unit).
Nov 29, 2007 | Sony KP-53XBR45 53" Rear Projection...
Sony KP-61V90 61" Rear Projection Television Logo
155 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
