Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
Water dripping Water started dripping from the bottom of the door.Help
  • abknarr Dec 21, 2008
    I can lay on the floor and watch the water come out of the bottom of the door[ at the front]The leak is not constant.It comes intermittenly..The seal should not be hard.The unit is only 13 months old??
  • abknarr Dec 23, 2008
    THey are on their way to fix.
  • 3,037 Answers
Hello abknarr
If the unit is only 13 months old, then you may still have it under warranty especially if you bought an extended warranty. If you did, please give them a call, Otherwise you may have a crack in the door or seal which only lets out a little water at a time and depending on where the crack is, will depend on what needs to be replaced. Let me know if you need help getting replacement parts.
bestdarngood
Posted on Dec 23, 2008
  • Frigidaire Master
  • 19,396 Answers
If water is coming from underneath you need to check first if there is any loose hose, in that case fix the hose back.
When it is a hose you usually get water in large amounts.
If instead water is dripping from the door , you need to replace the door gasket.
Here is the part.
Dishwasher Door Gasket (GASKET)
Sometimes also the latch is faulty and you need to replace both, see SE 154434101 (LATCH & GASKET KIT)
It is part three on the diagram below:
Posted on Dec 21, 2008
  • Ginko
    Ginko Dec 21, 2008
    If the leak is big but intermittent, and cohincides with drain cycle, you should check the drain pump assembly.
    If the leak is shortly after starts filling, check for leaks in the lines to the inlet valve.
    If leak is massive on start check power supply lines.
    If leak is from the door, check door gasket and door latch.
    Genius:
  • 2,120 Answers
Put some dishwashing liquid on a rag and clean the rubber gasket on the door.
    Genius:
  • 3,422 Answers
If your dishwasher leaks, check these:
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Posted on Dec 20, 2008
Rusty water dripping on the inside of the door after rinse cycle
Pull the screws out of the door check to see if they are rusted run the machine the outer door panel off should be easier to find the leak
Mar 30, 2014 | KitchenAid Dishwashers
KUDS35FXss is dripping from the bottom of the door
Bad door seal drain plug not knocked out of garbage disposal other would be main seal at pump u can take bottom dishwasher off and watch were coming from if it's at door then door seal if still has water when done then check drain and disposal drain plug hope this helps
Feb 21, 2013 | KitchenAid 24 In. Stainless Steel...
Water dripping from the bottom of the door
Hi Iyle Sponheim - From where the leakage is occurring, the washer door needs adjusting done as soon as possible. Either the door gasket is not securely sealing or the door itself is possibly damaged. Connect with a professional to move forward accurately to properly assist with the repairs.
Jan 31, 2013 | Electrolux EW1000i Front Load Washer
Trickling water noise coming from the bottom of the fridge.
It may be nothing to be concerned about. The water produced during the defrost cycle drains into a pan at the bottom of the refrigerator. This water is then evaporated by heat from the refrigerant coils.
You may be hearing this water dripping into the pan from the tubing that carries it from the inside of the refrigerator.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our GE TFX22PPDA started oozing a sticky brown substance from the bottom left corner of the freezer door. We defrosted the freezer and cleaned out the drain. Next we checked the drip pan under the frig,...
I have a GE refridg. and a light, brown sticky liquid periodically drips from the water dispencer panel area. This started after we lost power for 5 days. What to do??
Apr 19, 2009 | GE Refrigerators
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
Water coming out of the front door of the dishwasher
Read the installation instructions and make SURE that you have removed all of the packing material from inside and around the door. If you had the bottom apron off to hook it up, some insulation may have poked up into where the bottom of the door seals. Inspect the area that the door seals really carefully - you often can't see the bottom of the bachine side, due to how the door bottom catches drips, but if there's something that is sticking up into the lip when the door closes, that can give you problems. If you can take the bottom skirt off and run the machine, you may be able to see where the problem is coming from. Good Luck! Jim
Mar 02, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Dripping water dispencer
Dripping problem is from 2 sources.  Faulty water valve or faulty water connector behind refrigerator.  If the dripping is constant and doesn't seem to end, then it's a faulty water valve.  If the dripping stops after awhile, then the water connector is allowing air into the water line causing the dripping.  Have that connection checked to make sure that it's securely in place.
Nov 12, 2007 | LG LFD22860 Stainless Steel Bottom Freezer...
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
105 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
