Question about SanDisk Sansa Clip MP3 Player
I charge it then when i take it off it says low battery??????
I charge it and everything on it does the normal thing but then when i take it off it refreshes the data base and after that says low battery.....i dont know what to do HELP!!!!!
  • gfreddy33 Dec 19, 2008
    Ya my does the same exact thing
  • SanDisk Master
  • 1,800 Answers
Battery is become dead the chemical substance of battries is exausted.
in english try to replace the batterie.
plz do rate this post.
Posted on Dec 19, 2008
Hi. My vax blade won't charge. The battery icon keeps flashing red and White any ideas?
flashing red just says turn it off because the battery is getting low. i guess thats cos it wont charge. wait 1 hour for temperature to become normal. wash filters and wait 24hrs til they are dry.check and clean battery contacts. those are the things the manuals list to try.
Dec 14, 2017 | Icon Cameras
My aviator won't start and its not the battery what can be it was working fine
I had a similar problem. My battery was new, charging at 14.5 volts when running, 12.4 volts static. Checked all battery connections and grounds, all good. Checked started and found it loading the battery with over 250 amps, normally about 75 amps. BINGO! time for a new started. Test your circuits with a voltmeter and ensure low resistance. Make sure your battery is charging.
Nov 21, 2014 | 2005 Lincoln Aviator
Hi we have just bought a Disability scooter and when using the battery indicator is moving from right to left - full charge to low charge is this normal?
Yes that is normal. As you move, the meter shows the amount of voltage being drawn down. If it drops too low or doesn't recover to the full right side, its a clue that it needs charged or the batteries are too low and should be replaced.
Sep 18, 2014 | Health & Beauty
2006 pursuit g5 car won't start sounded like starting motor so changed it still doing same thing
Yes battery could be low enough to not be able to start the car but still work everything else
Mar 03, 2014 | Charging & Starting Systems for Pontiac...
I just want to know the formatting password for my samsung SGH L700 mobile, because it infected by virus
If you wish to know the default password code for samsung,it is 00000000 , regarding on virus infection,I don't think virus affects this type of model,if you experience hanging or sluggish thru your phone,this may due to phone memory low that's why the phone encounter the said problem,if you wish to format your phone,just type *2767*3855# on your home screen,a message pop up of formatting,wait until the phone restart, now your phone is refresh and back to default settings.be sure your battery is fully charge and should back up your important data before doing this,everything will be erase after...you're DONE.
Jul 30, 2011 | Samsung SGH-L700 Cell Phone
My 2005 durango want cran over
What happens when you attempt to start the engine? If nothing happens when you turn the key,you need to check the battery to determine its state of charge. Many starters won't do a thing unless there is at least 10 volts available from the battery. A low battery does not necessarily mean the battery is the problem, though. The battery may have been run down by prolonged cranking while trying to start the engine. Or, the battery's low state of charge may be the result of a charging system problem. Either way, the battery needs to be recharged and tested. If the battery is low, the next logical step might be to try starting the engine with another battery or a charger. If the engine cranks normally and roars to life, you can assume the problem was a dead battery, or a charging problem that allowed the battery to run down. If the battery accepts a charge and tests okay, checking the output of the charging system should help you identify any problems there.
Jun 25, 2011 | 2005 Dodge Durango
Phone says searching for base continueusly
I assumed that phone was working before,and recently doing this...
this warning normally comes when the battery is too low to be connected to base.
.please charge it couple hours ,than it should be corrected.
If it gives the same warning after charge,you might need to replace the battery..
Regards
Jan 16, 2011 | Vtech i5866 Cordless Phone
I noticed my run time was getting shorter and shorter, within the first 6 months. I checked my charger and base with a V.O.M. okay. About 4.4 volts on the base about 14 volts on the direct line. I bought...
To extend Roomba's battery life and keep Roomba cleaning at peak performance: • Always keep Roomba plugged in when not in use. • Recharge Roomba as soon as possible. Waiting several days to recharge Roomba can damage the battery. • For storage off the charger, remove the battery from Roomba and store in a cool, dry place. • Blue or black batteries should be stored after Roomba has been used. • Yellow batteries should be stored after being fully charged.
16-Hour Refresh Charge If Roomba has been left off the charger for an extended period, Roomba will initiate a special 16-hour charge cycle. This extensive charge refreshes Roomba's battery and extends the battery life. While charging, Roomba's "Clean" button will pulse quickly. Note: For best results, do not interrupt this Refresh Charge.
Happy Holidays The FixYa Team
Dec 18, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
2006 Bonneville America electrical failure
To start with, your battery was probably already low. You have to be at about 4000 rpm for the charging system to kick in and put out 14v or so. So if you just sit and idle, you will eventually run the battery down. If it is already low, you may have run it down below where there are enough amps to start it again. I know my 2002 BA started having what appears to be charging or regulating problems and the batteries won't stay charged. Try charging the battery with a good trickle charger to begin with. Then, when it is fully charged, run the bike and see if the charging system is keeping things up.
Mike
Feb 22, 2010 | 2006 Triumph Triumph Bonneville
SanDisk Sansa Clip MP3 Player Logo
121 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
