Question about Dynasty DGRSC 36-6 Gas Kitchen Range
Cannot remove oven pan
According to the manual the oven pan lifts out of the oven by pulling forward and lifting up. I have worked on this for hours and cannot remove the pan. I'm trying to replace the ignighter.
  • dan3112 Mar 20, 2009
    cannot remove oven pan to replace igniter. I can lift the front up, and then the back, but it will not slide out, and I can't remove the oven rack guides to give it more room to lift.
We had this problem a few years ago. It is a design defect, and it was fixed under warantee. The welds broke on the piece that was attached to the bottom of the pan.
Posted on Mar 01, 2009
How do i remove oil pan for 1998 gmc jimmy 4.3?
You will need an engine lift remove engine mount bolts lift engine high enough to remove pan,or remove transmission
Aug 31, 2014 | 1998 GMC Jimmy
How do you put door back onto Electrolux wall oven......Been trying for hours, no success!
Hello paulascor549 - I completely understand that you took the oven door apart to clean it, therefore you must have took the following steps to do so. According from my research you would have to reassemble in reverse order. If you have already tried to do so and it proves to be ineffective, contact a professional to move forward accurately.
Door Removal and Cleaning of Interior Glass
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide? With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Nov 24, 2012 | Electrolux 30" Built-In Single Electric...
I have a GLEF379DQA glass to stove and I want to know how to lift the top to replace the burner.
1) Unplug unit 2) Remove back plate covering controls on back of oven 3) Notice 2 brackets, 1 on each end holding 2 screws-remove the screws 4) On front remove 3 screws underneath front ledge directly above where oven door closes 5) lift top up about an inch, and pull forward towards front of oven 6) You can now lift it to service - beware wires are still connected - dont pull too far forward and up
Nov 29, 2010 | Frigidaire GLEF379D Electric Kitchen Range
If and how do the range eye seperate from the rest of the appliance for cleaning beneathe the eye? It is a GE MO # JV3001AV Serial#: M837357G
Look where the leads for the eyes go under the top of the range. Get opposite of that point, lift and pull the burner away from there. Remove the pan. Do this to all of the burners and pans, then lift the front edge of the top. Most have a rod that will hold the top open after you lift it.
Regards, --W/D-- please feel free to rate this solution---thanx!
Aug 04, 2009 | GE Ovens
How do I get our Sharp Carousel R-1611 off the wall. We don't have the manual and the Sharp site doesn't recognize the model.
You need to remove the hood (the grille cover above the microwave door and above the control panel) by lifting up on the bottom of the hood (the plastic should flex pretty easily) and popping it off. On the far left and right you should see two phillips screws, most likely bronze colored. You need to remove them (they are quite long) completely. The microwave will still be sitting on its support arms (which enter the chasis of the microwave from the rear). Once the screws are removed you need to lift the microwave up and pull forward - it should come off of the supports, but you might have to jiggle it a bit.
Don't forget to unplug the microwave and disconnect any ducting before lifting it off of its supports.
Mar 30, 2009 | Sharp R-1610 Microwave Oven
Unable to close the bottom oven drawer (Kenmore)
Pull the unit away from the wall and in most cases you can reach in the oven pan from then rear. If not.....pull the unit away from the wall and then lift the front about 3 inches away from the floor and let if drop....thus shifting the items in the drawer....If I can help further, I am here
Eric Campion
Feb 23, 2009 | Kitchen Ranges
GE xl1800 active vent bulb replacement
I think the key is pulling the vent to the left.
From page 36 of the online version of the owner's manual, which also mentions the active grille's presence on some models:
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jan 10, 2009 | GE JVM1870 Microwave Oven
KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
Feb 22, 2008 | KitchenAid Architect Series KEBC107KSS...
How to clean an oil spill
All of you are MORONS. the guy is asking "quite clearly", how to remove the bottom pan so he can clean under it. It's quite obviouse he understands how to clean the the main part of the oven. He just want to know HOW TO REMOVE THE BOTTOM PAN.......
Dec 25, 2007 | Hotpoint RGB745 Gas Kitchen Range
Lifting the top of the Maytag MER5770AAW
eliasan, to remove the glass top you need to open the oven door, on the body frame where the top of the door fits under, there will be 2 quarter inch screws on each corner securing the top to the body. Remove these 2 screws. Grab the top with both hands and pull forward. Disconnect the quick connect fittings in the back for the burners and the top will lift off now. Make sure to kill the power before attempting this. Catriver..post back
Apr 22, 2007 | Maytag MER5770 Electric Kitchen Range
Dynasty DGRSC 36-6 Gas Kitchen Range Logo
226 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
