The music coming out of the speakers is high pitched and echoing a little bit.
    Problem Solver:
  • 82 Answers
Go to equilizer funtion & reset to default ................Sameeraryan
Posted on Jan 14, 2009
What is causing a continual high pitched squeeling sound when the amp is turned on with nothing plugged in?
The speaker resonates with itself, reabsorbing the, little as it may be, and then amplifies it, spits it out, reabsorbs it... It goes on as long as no other input is connected.
Jan 17, 2016 | AMP Music
Will not turn on, instead makes low pitched noise from speakers
Would you please explain a little bit more such amp brand and model? The more the info you provide the more accurate the help i will give to you...
Oct 28, 2013 | Yamaha Music
High pitch noises.
It sounds like feedback hum. Most likely caused by the settings on your computer. Try adjusting all the sound settings. Especially record settings.
Sep 01, 2017 | Numark ttUSB Turntable
There is a horrible echo whenever i try to record and then there's a loud noice that sounds like a very high-pitched whistle and i don't know what to do.
This type of audio feedback loop can happen on any mic if you are playing back audio at a loud volume on speakers that are close to the mic while the mic is on - which tends to happen on Skype calls. Try lowering your speaker volume or using headphones to hear the audio, then speak into mic, and the feedback should be reduced.
Apr 12, 2012 | Labtec Microphone Microphone
PYLE PT2001X 3300 Watt Professional DJ Power.just had question about running this amp in bridged mode 4 ohms, here's some amp info 3300 watts total power bridged in 1 ch only.1650 each ch in stereo mode...
In bridge mode the minimum load will be 8 Ohm.
If you are using 4 Ohm speakers, it will mean you will give each side of the amplifier a 2 Ohm load.
Thats to much for this model.
Kind regards,
Gerard
May 13, 2010 | Pyle PT-2000 Amplifier
Original circa 1982 Kurzweil Ensemble Grand upright, has been working just fine until today. At first the (grand piano) sound had just become very distorted or seemed to have messed up sustain or echoing....
Given its age, this unit needs a little TLC. Units of that vintage used some capacitors that may have dried out a bit and need to be replaced. There are also op-amp ICs internally that may be defective. I would suggest a visit to a service shop that works on keyboards as not all do.
Keep us posted.
Dan
Dec 08, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Air cond cutting on high pressure
Sounds like there is insufficient cooling through the condenser, either airflow or the refrigerant may be restricted through the condenser due to clogging of refrigernat oil / contaminates. Try spraying cool water from a garden hose over the condenser while the A/C is engaged and monitorthe pressures, if they drop you know there is a problem at the condenser. If you're confident about the operation of the fans / airflow then replace the condenser.
Aug 21, 2009 | 2003 Toyota ECHO
Awful High-pitched Noise and Echo Feedback
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Jan 17, 2008 | Microsoft LifeCam VX-6000 (68C-00001)...
High pitched noise coming from the speakers
Hi, this might me a problem of the sound driver. just uninstall the present sound driver and reload the new driver. then check the sound is comming properly
Sep 27, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
29 people viewed this question
Alun Cox
David Payne
David Payne
