PLasma tv TV has no RF entry and don't have an adapter to connect tpo the stellite TV. any solution?
  • dedeachante Dec 26, 2008
    The only entries it has is hdmi and the db15... after some search could find that its maybe a only digital tv! ever heard of that?
  • 2,326 Answers
I believe that your satellite receiver should have video/audio output, if so; connect a yellow, red and white cables from there to the input on your plasma monitor and select video on the plasma to get ti to work.
Let me know if you need further assistance.
Posted on Dec 19, 2008
How to connect sega master system 2 to lcd plasma tv
If your TV comes with a composite video input then this may not be an issue. You need the RCA AV cable. Sega outputs only mono audio so put Yellow in TV video In and White in TV audio In (white connector).
If you still have the RF box for the Sega then you should be able to put RF from Sega and TV antenna to the RF box and connect RF box to TV antenna in.
If TV is only HDMI input then you need a converter like this
Composite Video to HDMI Converter
Sep 04, 2014 | Video Game Consoles & Games
I just got Atari 2600 trying to get it to work on my plasma don't know how to hook it up?
Hello Jamie,
I understand how annoying it is to connect an older game console, such as the Atari 2600, to newer TV's. Do not fret, all you need is an adaptor to connect between the Atari's RF cable, and the coax jack on your TV.
For example (image curtesy of google search):
You can usually find these at store that specialize in electronic parts, such as Radio Shack here in the United States. The image above is actually from Amazon's site so if it doesn't show properly you can go to:
May 09, 2012 | Atari Video Game Consoles & Games
I dont know what chords to use to hook up a dvd player to the pfm-42v1 tv. the tv doesnt have a yellow, red or white connection
Hello bobbylanetra,
if your tv does not have the composite connection (the red, white and yellow), I am going to assume that you have a coax in though. So what you should do is get an RF modulator. Connect your dvd player OUT to the RF modulator IN with the composite cable, then use a coax cable and connect the RF modulator OUT to the coax IN of the tv. That should solve your issue. I hope this helps or if not give me a feedback, good luck.
- Joe
Aug 31, 2011 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Instructions for the Nintendo, model number NESE-001. 1985. how can I connect it to a tv and start playing on it.
You hook to RF adapter up to your TV, then you hook the existing cable into the RF adapter, put your TV on 3 and start playing!
Jan 15, 2011 | Nintendo Video Game Consoles & Games
I don't see the cable connection on the TV. Is there an adapter for this?
This TV doesn't have a tuner and thus no RF (coax) input. It should be connected to a set top box by component, composite or S-video cables. Component video (with three RCA video plugs on each end) will provide the best signal (a separate cable with two plugs on each end carries the audio).
I wish that I could be of more help.
Sep 30, 2010 | Sylvania 6842PE 42 in. HD-Ready Plasma...
NES system doesnt work with my t.v.'s. i have plasma samsung and a symphonic 20" older t.v. that it doesnt work on either can you tell me what to do?
NES to TV Hookup
Installation Steps:
Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
Disconnect the existing cable wire from the TV's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the NES (labled RF Out).
On the back of the NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Press the Power button on the front of the Control Deck.
Turn on the TV and set it to the appropriate channel (3 or 4.)
The game image should now be displayed on the TV screen.
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Aug 06, 2010 | Nintendo NES Console
may be your tv systems don't have an accessory for audio video input. but you can hookup that by using an RF modulator adapter, this is a converter from audio / video to RF signal and connected directly to your antenna connection. you can purchase that RF modulator adapter to an electronics store.
Apr 18, 2010 | Sylvania SRT2319 TV
I can't find UHF channle 36
Turn plasma to analoque tv tuner auto search while xbox is connected and turned on. Auto tune will pick up uhf 36 channel .Flick chanelstill xbox chanel is viewable
Apr 19, 2009 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
Audio problem with NES
try switching both the tv and the rf switch to ch.4, if that doesn't help make sure that there is nothing connected to the in port on the rf switch and try it again, also make sure the connector of the rf switch has a straight pin and not bent too badly, also make sure the pin does not look tarnished/corroded in any way, also check the connector at the end that connects to the nes, i would try changing the rf adapter before the console, if the power cord is in good shape everything else should be easy to find a replacement for. if you hae a snes try changing the rf adapters, or try using rca type cables, the out ports are on the side of the nes and most likely on the back or front of your tv.
Feb 27, 2007 | Nintendo NES Console
Vertical muliticolor lines
The output freq of the vcr is sitting to close to an rf signal from a digi broadcast i guess,cross modulaion is the term.the rf can be moved away in freq to another bit of band width or if not using rf connection it can be switched off rf output altogether.find online vcr manual and find rf change section
Jan 07, 2018 | JVC PD-42V31 42 in. Plasma Television
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
