Question about Samsung HLN617W 61" Rear Projection HDTV
HDTV Rear Projection
Samsung Model HLN 617W61 DLP Projection . When I switch on TV noise coming from inside set. Sounds like cooling fan problems. Metallic sound sometimes goes away sometimes has a variable pitch.
  • Anonymous Mar 16, 2014
    Faces are green on my Panasonic HDTV DLP projection TV
    Novelist:
  • 192 Answers
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
Posted on Apr 01, 2007
SOURCE:
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Loud noise, then shuts down after seconds , fans look ok
On U_Tube, there is a video that shows the replacement proceedure. I understand it is quite good. My neighbor used it and it went in pretty easy. If you Google the model # it should be able to give you a link to it.
Good luck !!,
Hope this helps,
Skyassoc
Jun 30, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Buzzing noise
COLOR WHEEL OR COOLING FANS
Mar 28, 2009 | Samsung HLN507 50" Rear Projection...
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
My Samsung DLP TV is making a noise that sounds like a bad fan.
This high pitch noise comes from the color wheel. Now is unbalanced and the noise is going to be even hardest with the time. send it to change now. this part is inside the light engine
Dec 26, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
50" Samsung dlp rear projection hdtv
More than likely its the color wheel there is a bulletin from samsung indicating that a loud buzzing is often related to the color wheel.Let me know if you need to know where to get a color wheel and I will post a link, just include your full model number.
Apr 14, 2008 | Televison & Video
Samsung DLP HDTV wide screen
Sounds like the colorwheel (used in DLP projection sets with a single DLP panel) is going bad, either the wheel itself or the bearings on the motor driving the wheel are starting to fail. I would recommend getting a professional to service the TV set.
Jan 11, 2008 | Televison & Video
Samsung HLN617W 61" Rear Projection HDTV Logo
470 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
