Question about Canon PIXMA iP1800 InkJet Photo Printer
PAPER FEED NOT FUNCTIONING PROPERLY. IT STARTSTO TAKE THE PAPER
AND THEN IT STOPS. YOU CAN HEAR IT ROLLING AS IF IT'S GOING TO PRINT. THEN IT SAYS PAPER JAM, BUT THERE IS NOTHING THERE. HOW DO I FIX THIS?
  • 3 Answers
Its the roller with the rubber maybe. i do not know what that is called but my printer (1880) experienced the same. i found out the shaft of the roller is broken. this i did:PAPER FEED NOT FUNCTIONING PROPERLY.  IT STARTSTO  - 5794815.png
Posted on Jan 14, 2009
My shape XE-A207 cash register won't roll out the receipt paper when a sale is made. It is trying to print a receipt but the paper isn't rolling out.
Usually a broken feed gear in the printer. If you can hear the feed motor whirring but no paper movement, it probably needs a new printer.
Sep 07, 2015 | Retail Supplies
The paper starts to feed , then stops. There's no jam.
the problem is paper feed roller their have a dust. clean it properly. and then print again
Jan 07, 2011 | Samsung ML-2510 Laser Printer
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
Will not feed paper no matter how many sheets are loaded. However, the print head moves as expected, and ink is dispensed.
than as you describe i think the most logic failure that's occuring is that the rolling part that should pick up the paper suffers from a sensor failure, or maybe some grease to make it all slide properly again...
Hope this is helpful, and greetings,
Olivier.
Oct 20, 2009 | Canon PIXMA iP90v Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Not printing
There is probably a paper jam in the tray feed path. The other situation is that the tray paper pick up roller has become hardened/polished, or the paper tray paper is greasy. First step, take the paper from the tray, and fan it out, so each sheet is separated from the next. try it with jut a dozen or so sheets, change the paper.
Thoroughly check the paper feed path.
If not working, then check/clean the rollers.
Jan 20, 2008 | Kyocera FS-720 Laser Printer
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Canon PIXMA  iP1800 InkJet Photo Printer Logo
134 people viewed this question
old marine
old marine
