Question about Ovens
Oven door won't unlock
I hit clean then wanted to stop it to make sure I left nothing in the oven now it won't unlock. never cleaned.
    Scholar:
  • 111 Answers
It may have heated up just enough to trigger the lock thermostat. I almost bet that by the time you read this, it will have unlocked itself. If not, unplug for 30 minutes and try hitting the clear/off button.
Posted on Dec 19, 2008
What can i do to keep it unlocked and stop the beeping so i can use my oven
Search Results
    Why would my GE range display "unlock door" when the ...
    www.shopyourway.com > Manage My Life > Questions
    If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
    Troubleshooting a GE Oven That Can Not Get Out of Locked ...
    motherhood.modernmom.com > Around the House > Home Appliances
    Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
    Oven is confused - GE unlockdoor lockeddoor ' Ask MetaFilter
    ask.metafilter.com/255547/Oven-is-confused
    Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
    How to Unlock a GE Oven: 9 Steps (with Pictures) - wikiHow
    www.wikihow.com > ... > Microwave Ovens
    wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
    Range - Oven Door Won't Unlock - GE Appliances
Jan 25, 2016 | Ovens
Tip
How to CLEAN a Frigidaire Self-Cleaning Oven Step 1Use a plastic spoon to scrape...
Step 1Use a plastic spoon to scrape away any extra spillovers or burnt-on food from inside the oven. Remove as much of this as you can before running the self-cleaning cycle, because any spillovers left in the oven during the cleaning cycle may cause a lot of smoke.
  • Step 2Wipe off the inside of the oven with a rag dipped in soapy water. Be careful not to get any cleaning supplies on the oven door gasket or to disrupt the position of the gasket at all; having a good seal is critical to the success of the oven's self-cleaning cycle.
  • Step 3Clean any soil away from the oven frame and its door liner with a rag dipped in soapy water. Any soil left on these parts of the oven may become burned on during the self-cleaning cycle.
  • Step 4Pull the broiler pan and grid, any utensils, and any tin foil that may have been left in the oven out of it. They can't withstand the extreme temperatures the self-cleaning oven will reach. It's okay to leave the oven racks in the oven.
  • Step 5Make sure the oven door is completely closed.
  • Step 6Press the "CLEAN" button on the control pad. Use the up and down arrows to select the desired cleaning time; use 2 hours for a lightly soiled oven and 3 or 4 hours for a dirtier oven. The oven will lock itself and begin the cleaning cycle.
  • Step 7Wait for the cycle to end and the oven to cool; it will then unlock itself automatically. Don't try to open the oven door before it has unlocked itself.
  • on Apr 07, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Door won't open after self cleaning and cool down has stopped.
    if you are sure it has cooled down cycle it again to clean hitting the cancel button shorty after it starts
    Dec 09, 2011 | Maytag CWE5800A Electric Double Oven
    H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
    Hello.
    Please apply the solution this way!
    To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
    • Program the oven to self-clean.
    • Wait 20 seconds.
    • Cancel self-clean.
    • Wait 20 seconds.
    To self-clean your wall oven, follow these simple steps:
    • Remove the oven racks.
    • Set your oven control to "Clean."
    • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
    • Select "Start." (To set a delayed start, see your Use & Care Guide.)
    Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
    Thanks for using fixya.
    Sep 07, 2011 | Dacor Ovens
    How do i reset the locked oven door to unlock it?
    I have had that problem once.I turned off the breaker to that oven over night and then in the morning the door opened as it should.I found a GE page that is below.It may help.
    http://www.geappliances.com/search/fast/infobase/10000161.htm
    Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
    May 16, 2011 | GE JTP15 Electric Single Oven
    My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
    Here are some solution on how to unlock the door of your oven ans do self cleaning below.
    IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
    The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
    hope this helps you out please rate this solution it helps get better results for our customers like you
    Here are solution on how to clean up your oven below.
    Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    Cleaning cycle finished, oven cool but still locked
    Since the clean cycle was interrupted by turning the breaker off it may need to be restarted. Start the clean cycle like you normally would, then after it starts and runs for a couple of minutes, push cancel and see if it unlocks. If not the lock would need to be manually moved by putting a flat thin angled tool or stiff cardboard carefully between the door and oven cavity on the top of the door, slowly move this to the left, you will feel resistance when you get to the latch in the center. If you hit it right it will unlock.
    May 07, 2010 | Whirlpool RBS275PD Electric Single Oven
    kenmore selfcleaning oven door will not unlock code f9 appears in window
    Jan 03, 2010 | Ovens
    I cant get my oven to unlock its door
    you will needto let it go through the cleaning process to comeplete the cycle for the door to unlock,thats about the only way its going to unlock now
    Dec 06, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Oven Door Locked
    the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
    Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Ovens Logo
    153 people viewed this question
    Top Ovens Experts
    Marvin
    Marvin
    Sal De
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
