Question about Sylvania 6626LCT 26 in. LCD Television
My LCD TV has X-ray-like image on the half of the screen.
This following link is my webpage showing the photos of the LCD TV.
http://sites.google.com/site/yoofamilysite/Home/photos
As you see, my LCD TV has X-ray-like image on the half of the screen. Do you have any ideas or suggestion to fix it? Thanks for any helps.
Dongchul
  • Sarah Burns
    Sarah Burns Dec 27, 2008
    I have a very similar problem with my Sylvania 66265lct. The left side of the screen doesn't look like an xray (like yours), but there is a "shaded" area that started out as a slim black line about a year ago, but has now grown and develped into a triangle-like shade that occupies nearly half of the screen.
    I tried to contact Sylvania on several occasions just for some advise, but have never received a response.
    I am now on the market to purchase a new TV, but will never buy a Sylvania lcd hdtv (or any Sylvania product) and would NEVER RECOMMEND it.
    Problem Solver:
  • 10 Answers
Looks like you have a bad Display Drive Board which drives the LCD display. Bad news is the Display Board is sold With the Panel.
Posted on Dec 19, 2008
My 42 inch tv when it turns on half is black then color lines show up and down then I'll just tap it slow on top and picture comes on like something is loose inside some times it doesn't work
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Feb 04, 2015 | Televison & Video
MY FLAT SCREEN WAS WHACKED WITH THE Wii REMOTE, NO MAR KS ON EXTERIOR, BUT SUPPOSEDLY THE SCREEN NEEDS REPLACED, HOW MUCH WOULD COST OF THIS BE, WOULD I BE BETTER OFF THROWING TV AWAY?
If your screen shows symptoms like those seen in the images at the following links then your LCD display panel is permanently damaged:
http://www.gantonit.co.uk/image/broken-lcd-screen.jpg
http://www.edwud.com/photos/cracked_broken_lcd_monitor_screen.jpg
http://squarehe.com/images/0604/cracked-screen.jpg
The cost of replacing a damaged LCD display panel in a modern flat screen TV is almost always about the same as buying a whole new TV. However since all the internal circuit boards (Power Supply board, Main board, LCD Controller board, Inverter board) are likely undamaged and still functional, there is still some significant value left in the set which could be salvaged. Depending on the exact model of the TV, each of the working circuit boards inside can be worth up to $50 each on Ebay.
If you are going to get a new TV, I would recommend buying a new one of the exact same model. That way if you ever have any problems with the new set down the road after the warranty expires, you will still have a bunch of perfectly good spare parts on hand to help you fix it.
Good luck, I hope that was helpful.
Joe.
Sep 14, 2011 | Televison & Video
Only TOP half of picture shows, rest is black???
No,problems u discribing the LCD screen panel some how it shorted and dead.Replacing the LCD screen panel is not an option,because LCD screen panel are 90% of the tv,so replacing it.LCD screen panel will cost the same as a new tv,because LCD screen panel are limited produced by the tv corporations.It time to buy a new tv.
Jul 31, 2010 | Toshiba 32AV502R LCD TV
Can hear photo/movie being taken, but won't diplay on LCD. Black screen.
Hi Amritraj,
                 This problem is related to a component called CCD IMAGER, And you have to replace the CCD IMAGER,
                 As far as concern about, you heard that sony providing free of cost services regarding CCD IMAGER problem this is true, Therefore contact any nearest SONY SERVIC CENTRE for the replacement of CCD IMAGER free of cost.
Thanks for using fixya.
May 31, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Its known issue of ccd imager in DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
May 30, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Question for My LCD TV problem.
Usually this problem is associated with the LCD Screen. The screen is made up of many layers in a matrix form. If there is any separation, no mater how slight ....it will cause the mastic in the screen to break connections. This can be caused by manufacture defects...which is hard to prove. Common causes is someone unaware what happened pushed the center of the screen causing it to flex a minute amount there by breaking the mastic or matrix if you prefer.......replaced screen and corrected problem. That is the most common cause, however as with any problem; other issues can cause the same effect.
The cable (data) comming off the logic board to the screen can have a loose or dirty connection; there by giving the appearance of a broken mastic. In which case unplugging and replugging the cable in and out several times should clear this up.
Last but not least is the logic board. There is no need to try and repair this. Replacement is the way to go. Why most of the logic and data chips have so many connections that special equipment is need to facilitate repairing the board.
Hope This help.
Tom Miller (Masters Degree in Electronic Design)
Broadcast Communications of Alabama
Dec 25, 2008 | Sylvania 6626LG 26 in. LCD Television
LCD screen only has flashes of light
Does the camera really not take photos, or are the photos black or distorted? If black or distorted photos, then it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jan 20, 2008 | Canon PowerShot SD110 / IXUS IIs Digital...
PSCAN shows up on my tv screen when I try to watch movies. How do I delete this?
The solution to the PSCAN! (half screen cut image) is just as suggested, turn off the progressive scan switch in the back of the DVD player to get the full image and enjoy your movie.
Dec 26, 2007 | Memorex MVD2040 DVD Player
Problem is with nokia 6600
1st try to change the smal 6link ic under the display filter,f same result change display filer
Sep 02, 2007 | Nokia N70 Cellular Phone
Problem for taking photo
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
May 30, 2007 | Canon PowerShot A310 Digital Camera
Sylvania 6626LCT 26 in. LCD Television Logo
352 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
