Question about Acer Computers & Internet
My laptop was messed up.. so i reinstalled windows.. now i can't connect to wireless networks and my sound system doesn't work.. how do i fix this?
    Scholar:
  • 86 Answers
Did you also reinstall the system board drivers?
Go to right click on the My Computer icon and select properties.
Select Hardware and Device Manager
Look for large yellow exclamation marks indicating hardware installed but without drivers
Download drivers from makers website and install
Posted on Dec 19, 2008
Sylvania net book doesn't see available wireless
If it's not seeing wifi networks, more than likely, there is something wrong with the adapter. Try these steps:
1.) Look for a WIFI switch on the side or front of your laptop and make sure it is set to the ON position. 2.) Check Device Manager to make sure the driver is installed and working. If it's not, uninstall and reinstall. 3.) Go into Network Connections and make sure the Wireless Connection is set to Enable. 4.) If none of that works, perform a System Restore to a time when everything was working. 5.) If this doesn't work, you need a WIFI adapter replacement.
I hope this is helpful and thanks for using Fixya!
Sep 23, 2011 | Computers & Internet
My hp laptop 6735s my wireless not working how can it be fixed. my oprating system is window seven
Is the wireless installed and working on the laptop and your just having a problem connecting to your wireless router or is it that your wireless adapter driver isn't installed and working properly on the laptop? If it's not working on the laptop I would uninstall and reinstall the driver. If it's an issue with your router you will need to reset your wireless settings so that you can set up and connect to the wireless network via your laptop. Here is a link to the drivers for your laptop:
Here is a link to the drivers just select your operating system:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3687622&lang=en&cc=us&prodTypeId=321957&prodSeriesId=3687621&taskId=135
thank you,
Lee
Aug 16, 2011 | Computers & Internet
Can't make a wireless connection.
what's the error? if your getting the error Connected with limited connectivity try checking your network key in the router and the wireless settings on your computer if they are correct or just removed your security key, if your getting an error no networks in range or no network available check the router settings if the wireless signal is turned on the router, if you get an error windows could not connect to wireless networks try uninstalling and reinstalling the wireless card driver on your system and set the the router to defaults then try connecting with out changing any settings in the router to see if it will connect, if it connects, then there was/were settings in the router and possibly in the wireless settings in your laptop that was causing the computer and the router to have communication issues, also check for possible applications such as network magic that could cause a wireless signal to degrade or not allow connections at all if such application exists on your system uninstall it Microsoft or windows has its own wireless configuration software built into handle wireless connections in XP it is wireless zero configuration in vista and in win7 WLAN which can be set in network and sharing connection in the control panel window.....
Jun 03, 2010 | Intel Computers & Internet
I reinstalled Windows XP Pro on my Dell Latitude C510 Laptop and now my wireless direct access button does not work. I also cannot see any wireless connection on this laptop. It was working before I...
Hopefully this helps
Try the following: click start, RIGHT click on My PC, click on administration, select services and applications, select Start wireless configuration service, click start service. Close the window
Open configuration of wirless network, flag the option let windows configure my wirelss network
That should let you see and select your wireless device
I have to do this everytime I start my laptop. I would like to have the system make this automatically, but I don't know how.
Oct 15, 2009 | Dell Latitude C510 Notebook
Can not connect wireless network
Have you checked within Device Manager that both you Lan and Wireless drivers have installed correctly during your reinstall of Windows XP?
Sep 15, 2009 | Microsoft Wireless Network Adapter Xbox...
Wireless network connection not working
For some reason known only to Dell, the default setting for the Inspiron 6000 built-in wireless network adapter is 'off' or 'disabled.'
If you used Dell's restore disk to reinstall XP, the radio button is turned off. Go to control panel/system/device manager, find the wireless LAN device, right-click on it and choose 'Properties.' Under 'Wireless radio' check 'on' or 'enabled.'
Go back to Windows network setup wizard and go back through the steps using the 'restore network connection' button. You should be good to go.
There's an EXCELLENT network manager from Cisco named 'Network Magic' that takes all the guesswork out of setting up your internet connection. I highly recommend it. They offer a free trial and I think may even have a 'Lite' version that helps with simple connections without the bells and whistles of the full blown program. I'm not sure about that, but I can't tell you how much time it's saved me troubleshooting and setting up networks for my clients.
Jun 11, 2009 | Dell Inspiron 6000 Notebook
My computer no longer has the wireless info in it
Okay - right click on the "PCI Modem" and select "Update Driver" - and reinstall the Wireless Driver. If that doesn't work, use the Windows Restore function to roll the system back to the last time the wireless worked. If that doesn't fix it, then the wireless function has probably died. You'll need to get a wireless network PCMCIA card for your laptop and use that to connect.
May 25, 2009 | Acer Aspire 3000 Notebook
Cant connect to my wireless network anymore???
NVIDIA nForce Networking Controller drivers may have messed up your network drivers , since your network card is broadcom or intel pro, and it is not there.
Try reinstalling the wireless lan drivers.
You can download the wireless network card driver from link below:
Select software and drivers
In there you find different wireless drivers, download and install them all, the computer will automatically chose the correct ones.
You will have to enter your wireless network key again after reinstalling drivers.
Feb 18, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Wireless does not work on hp pavillion ze 2000 after xp reinstall
Try this to check the wireless.
Click on start> Control panel> network and internet connection> from left pane click on view network connection after that right click on the wireless adopter icon and select enable.
this will resolve the issue if it is not helpful
try to check wireless driver from
1) Go to Start, right click My Computer and then click on Properties.
2) System Properties window will appear. Go to Hardware tab and click Device Manager.
3) Device Manager window will appear, and you can check all hardware drivers' status here. Scroll down and look for Network adapters and expand it, then right click the wireless adapter you want to check and click Properties.
Nov 24, 2008 | HP Pavilion ze2000 Notebook
Wireless fails to work after reinstalling XP SP2
Hey there,
The wireless driver might only work on Vista, try the IT Administrators - Intel® PROSet/Wireless WiFi Connection Utility for Windows* XP and Windows Vista*from here
First uninstall the one you have though..
Hope this helps
Chris (ziraffa)
Sep 10, 2008 | Intel PRO/Wireless 3945ABG Network...
Computers & Internet Logo
21 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
