Question about Kenmore 63672 Convection/Microwave Oven
Bulb broke away from its screw base in oven
Was cleaning the oven, bulb was hot, shattered when I hit it with my cleaning rag. Now the element base (the screw-in part) is broken off in the socket. What to do, what to do? I need to replace said bulb now.
  • Kenmore Master
  • 9,098 Answers
Please unplug the oven's power cord first!
This is pretty common and can be a pain. It's sometimes tacked in place with hot glue, and sometimes there may have been enough moisture to corrode and seize up.
You could heat it up (hair dryer, maybe?) then use needle nose pliers. Be careful if heating so you don't burn anything.
You may be able to put the tips of needle nose pliers inside the broken bulb's socket, gently but firmly force the pliers jaws apart and then rotate the pliers to loosen it.
Another cool trick is to put a big glob of hot glue on the end of a stick or dowel, then shove it into the broken base and let it cool about 5 minutes, then turn the stick.
I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
Posted on Dec 21, 2008
The cover for the oven light has broke leaving the screw part inside cannot get it out.
If you mean the glass dome of the bulb has broken leaving only the metal bulb base, you will need a medium size long nose plier to grip the edge of the bulb base, you can then gently rotate counter clockwise to remove.
ENSURE THE APPLIANCE IS ISOLATED FROM THE MAINS SUPPLY BEFORE ATTEMPTING THIS !!! PULL THE PLUG !!!
Apr 21, 2018 | Microwave Ovens
The bulb broke in my Roper oven and I can't get the rest of it out.
* Call for service! High voltage(s) present!
*** The following is for information only. ***
* Remove oven and unplug. (Yes, you could trip out the breaker. But do you know enough to turn off the right one? Remember, you will be sticking something is a live socket.)
* Following is very dangerous! Use the back end of a rubber handled screw driver. Wear a glove and don't touch the metal parts of the oven with your other hand. Use dry towels if needed, to place around the oven door if you have to lean in. Remove all metal shelves. A small wooden handle (from a plumber's helper) can also substitute as well (if it's dry!)
* I'm guessing the bulb cracked or broke off the metal screw In base. With power OFF (you will be smashing the wires to the bulb that will probably short out.) Insert the blunt end (Handle side) into the light socket. Use a smaller handle if it does not fit. A broom handle should fit perfect. Press hard enough to get a grip and twist counter-clockwise to loosen the base. You may need to twist slowly back and forth to get the handle to 'bite' into the base. Be careful as the base comes out that you use a gloved hand to unscrew the base the rest of the way.
* This method works most of the time. Though it will not work on shorted/melted bulbs. This is caused by a bulb that was not seated properly and 'arced' welded the base to the contacts of the socket. This requires a complete replacement of socket and bulb.
* Final; Check your warranty as working on the oven may void it. Warranty periods may last years, so check first. Be safe and call your vendor for service.
Aloha, ukeboy57
PS; Though I don't think they use LEDs lamps INSIDE the oven as the heat will destroy them. But if it is an LED lamp then this method will not work. Call for service and replacement.
Feb 21, 2018 | Roper Microwave Ovens
The bulb broke in the oven and I can't get the rest of it out
* Though I don't think they use LEDs lamps INSIDE the oven as the heat will destroy them. But if it is an LED lamp then this method will not work. Call for service and replacement.
Aloha, ukeboy57
Feb 21, 2018 | In Microwave Ovens
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
Lite bulb broke.
This is pretty common and can be a pain. It's tacked in place with contact cement or hot glue, and sometimes there may have been enough moisture to corrode and seize up.
Jan 08, 2013 | Frigidaire PLMV168 Microwave Oven
Do the lighbulbs underneath the microwave screw in or pull out- in the process of trying to change the burnt out bulb- i broke the bulb off of the base.
Most moderately new microwaves have a two prong pin type connector that is simply pushed strait in and pulled strait out. I presume the you tried turning it out when it broke?
Oct 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I cannot tell how the 2 bulbs (surface light(s)) detach. One of them broke when I was trying to remove after it had burned out, and the glass part of the other bulb turns freely and is very loose and...
Unplug the microwave oven and get a needlenose plier and a flashlight. Wear some hand protection since you are working with broken glass.
Most of the bulbs I have seen are screw thread mounts.
For the bulb with the broken glass, use the needlenose plier and try to find the screw thread for the bulb. It should be screwed in to the lamp socket of the microwave. Carefully grab a hold of the outer edge of the bulbs screw thread and turn it counterclockwise to loosen it from the base. You may only be able to turn it a quarter turn before letting go of the bulb's thread and getting a grip on a new position to continue turning. Inch your way to remove the broken bulb's thread.
If the other bulb still lights up, I'd leave it alone.
Aug 09, 2010 | Hotpoint RVM1325BW Microwave Oven
I have a light bulb that broke and I cant get it out, does it push in or screw in?
Chances are it is a boyonet base bulb. Unplug or turn off the power to the microwave. To remove the bulb, press in lightly, turn the base of the bulb counter-clockwise about 20 degrees till it stops, then it should pull straight out.
May 08, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
BROKEN GLASS COVER UNDER NIGHT LIGHT
SAME PROBLEM FOR ME...I REMOVED THE BOTTOM COVER AND FOUND THAT ONE LIGHT WAS NOT FIXED AND WAS LOOSE AND WAS TOUCHING THE GLASS. THIS HEAT WAS WHAT BROKE THE GLASS COVER. CLOSED INSPECTION SHOWED THE LIGHT SOCKET WAS TOO LARGE FOR THE CLIPS AND WERE NOT SECURED WHEN PURCHASED. I GOT SMALL SCREW AND NUT, BENT CLIPS SO THE SOCKET HOLE MATCHED THE HOLE MADE BY THE CLIP AND SECURELY ATTACHED THE SOCKET. THIS WILL SECURE THE LIGHT AND KEEP IT FROM TOUCHING THE GLASS..........IF I CAN EVER FIND A GLASS REPLACEMENT....MAY JUST HAVE ONE CUT. NOW THE PROBLEM IS TO REPLACE THE LIGHT AND MICROWAVE FUSE WHICH WAS BLOWN WHEN THE GLASS BROKE.
May 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 63672 Convection/Microwave Oven Logo
71 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
