Changed DSL service today, printer will not work, we think the tech did not set the printer to the right ip
    President:
  • 2,692 Answers
Your printer,software and driver has nothing to do with your DSL internet service. Go into control panel and see if you printer is still installed,and has a driver.Look to see if the printer cable has be accidently disconnected.
Posted on Dec 19, 2008
My hp office jet 7310 will not print from my wireless network. I had a tech guy here reset my d link router and now my printer does not work with it
Did you change the SSID, encryption or password on the router? These are all things that would need to be updated in the printer settings in order for it to function correctly. Another thing to consider would be if the printer had a static IP address assigned to it and you had a reserved IP address in the router for the printer. If this was the case and you reset the router, that reserve would also be cleared, the printer would still think it has rights to that IP address and the router may have already issued it to another client.
I would double check the IP addresses and printer network settings.
Jun 27, 2011 | Computers & Internet
I have a powerbookG4 (old mac laptop) and i'm trying to connect wirelessly to the new printer. it wanted me to change some settings and i didn't know where to do that. i thought i had the right IP address...
Check the prnter's config, and try to set the IP to manual, since DHCP keep changing the IP each time it goes offline or off power. Then delete the printer and create a newone based on the new Fixed IP, or check the IP config assigned to the printer port and see if it lets you change it manually.
Jul 10, 2017 | Apple Computers & Internet
No internet through router
you should refer to your ISP or to the Router manufacturer on how to access the GUI of the router. problem could be both devices are using same IP. there is a collission issue there. you should change the gateway IP to one of your devices.
Apr 01, 2010 | Linksys Wireless-G WRT54GS Router...
When trying to install gets message cant find internet trying to hookup to embarq 660
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi there! This are some steps on how to setup your modem/router
New DSL Modem Available
Embarq is now shipping an updated version of the DSL Modem called the "660". It is smaller than the older model (645) and is much easier to setup.
A few years ago, Sprint/Embarq changed the way their servers communicate with the DSL modems. The new method is called DHCP, which is how the 660 modem works. The older 645 Modem used "PPPoE". So it's best to have the new 660 DSL modem.
The older 645 modem also had the same default IP address as the Linksys Router (192.168.1.1) - so you had to change one of the addresses to make them work together.
The new 660 DSL modem uses 192.168.2.1 as the default IP address. This does not conflict with the default IP address of the Linksys Router (192.168.1.1). Note that if you had changed the Linksys Router IP address to 192.168.2.1, then you will first need to reset it back to the default address 192.168.1.1.
If you call Embarq and request the new 660 DSL modem they will sent it to you at no cost. When you install the 660 DSL modem, you need to be sure that you power down the old 645 modem amd leave it off at least 1 hour before you plug in the 660 DSL modem. The Embarq server needs to "forget" the old 645 modem. After an hour, all you should have to do is plug in the new 660 modem and everything should start up properly.
Call Embarq Tech Support 1-877-646-3282 if you have problems setting up the modem. If the Internet Lights does not come on after a few moments - then call Embarq Tech Support.
Aug 15, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Recently I subscribed ATT DSL Service conflict IP Address
the motorola modem that att is using uses 192.168.1.x subnet. log onto your router and change it to 192.168.b.x where b is any number between 2 and 254 (just not 1). You should also log onto the modem and change the setting that allows it to share the external ip address with the router. You will need to do this if you plan on accessing your network from the internet.
Apr 25, 2009 | Motorola Computers & Internet
Ip configuration
Does your friend and yours IP settings the same?To clarify you would have 2 types of connection from your ISP.The 1st type of connection is that the authentication happens in the modem through the PPPOE UN/PW and the IP configurations are done in the modem and as such wont require to configure the IP settings when the windows is reinstalled.However the 2nd type of DSL service is that the IP settings are done in the windows and does not require any PPPOE username and password to authenticate.You would have to verify with your ISP which type of service you have and if you require any change order to make it the same way your friend has.
Please let me know any clarification you would require for this issue.
Apr 14, 2009 | Gateway Wireless-B Router (wbr-100)
Belkin DI-604 router connection problem
Change the router's IP address to 192.168.10.1, The Qwest modem like Action Tech have the same IP address with the router.
To change the router's IP address you might needing to access the configuration page of the router, then proceed to the LAN settings.
Mar 24, 2009 | Belkin (F5D5231-4) Router
I am trying to connect my D-Link router to my PC. I changed providers from DSL to CAble, and now it doesn't work. When I try to hook up the router to the cable modem, I no longer have internet service....
First, you have to directly attach to the cable modem whichever computer the instal tech used to establish your account. Make sure that connection works. Then re-insert the router and clone the MAC address of the instal computer to the router. Then check your DHCP settings. Make sure it's set to get a new IP from your new provider. You may then have to then release your IP and resubscribe.
Feb 19, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Hi any one there to help me ?
you have contacted the service provider?????
i think your DSL device and wirelss is using two separate Ip segments and this is the reason that they are unable to communicate with each other..
Solution:
COnect your system with DSL device via cable.....
then go to Start Menu >> RUN >>>type "CMD" ..Press Enter>>>
DOS window will come on the screen.. here you can type "ipconfig" to get the IP addresses of DSL device...
Just configure your Wireless acording to DSL Device's IP series,
n m sure it will start working...
best regards,
Dec 05, 2008 | D-Link AirPlus DI-524 Wireless Router
Connection dropping every 2 hours and router resets
For these commands, Start, Run, CMD to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
If that doesn't get the job done after a reboot, set it to automatic IP addresses, reboot, then post this:
Start, Run, CMD to open a command prompt:
IPCONFIG /ALL
Right click in the command window and choose Select All, then hit Enter.
Paste the results in a message here.
Jun 25, 2008 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
