Question about Samsung HLP5685W 56" Rear Projection HDTV-Ready Television
Samsung HLP5685W Screen Replacement
Both screens on the Samsung were broken. Does it make sense to buy new screens and install them myself? Where would be the best place to order them cost wise?
    Novelist:
  • 192 Answers
The screens for your television come together for easy replacement. Part number BP91-01812A. They are easy to replace. Call 1-800-Samsung for the parts. When replacing the screens, be sure not to scratch them and keep off lint.
Posted on Apr 15, 2007
SOURCE:
LCD screen damaged due to pressure on screen
Are the stripes like pixely (sharp stripes) or blurry (from background)?
You might have damaged the edge of the screen where the connections are and broke connections. These types of problems are impossible to fix. You need replacement panel witch can cost a lot. Cheaper is to buy new model. You can re-sell the screen motherboard, PSU as those are sometimes valued replacement parts for screens that have working panel but broken circuits.
Another tip for you is to find a exact same screen with broken circuits and replace those. I have found myself broken screens just for cents.
May 11, 2016 | LG Televison & Video
Problems with internal speakers of the Samsung LN32A450 TV
Problems with internal speakers of the Samsung tv Can I buy replacement speakers and install it myself.
Apr 30, 2010 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Broken lcd screen on my samsung s1030 digital camera
LCD are very easy to change out once the back of the case is off then all you have to do is carefully lift up the hold down and pull the cable out the LCD can be obtained off of ebay or i think I might have one in stock. once you have the new LCD reverse the steps.
May 27, 2009 | Samsung S1030 Digital Camera
Broken screen
I replaced mine myself. I bought a lcd screen brand new off ebay and they gave me a few simple instructions and I replaced it myself, and I'm a chick!!! It really was easy and cost about $40 otherwise I was told around $90. Just had to buy a real small phillips head screwdriver! Good luck!
Mar 31, 2009 | Pentax Optio A30 Digital Camera
Canun digital camera powershot A630 lcd screen blank
I also cracked my Canon Powershot A630 lcd screen by dropping the camera. I saw a suggestion to buy a new replacement lens and either have it professionally replaced or try it myself. I ended up doing the replacement myself following instructions I found online. Now it works. Total cost US $63.
I would not recommend trying the replacement yourself, however. There are a few very delicate plastic parts in there which I ended up damaging. Luckily the camera and lcd screen are working great now. But it is probably worth having a professional camera repair shop do the whole job or insert the screen you've purchased. Good luck!
Jul 11, 2008 | Canon PowerShot A630 Digital Camera
BROKEN LCD SCREEN
I have seen this with cameras, and pocket TV sets.
It is best to send the unit back for factory service. Ask for an estimate before servicing.
The parts in your GPS are not generic parts. You can buy the screen from the manufacture and find that the circuit board under it is also broken or damaged.
You may also find that the cost of the screen replacement may approach the cost of a new unit. I have seen this on many small devices. In some models the screen module comes as part of a complete matched assembly.
Jerry G.
Jul 01, 2008 | Navman NavPix N60i GPS Receiver
Samsung DLP HLS5086W - spider crack
You will need to get the screen from here:http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP67%2D00261A&search%5Fmodel=HLS5086W You should also get the service manual for this TV set, as that will show you how to disassemble the TV set. Good Luck
Jul 05, 2007 | Samsung HLP5685W 56" Rear Projection...
Samsung HLS5086W - spider crack on outer screen
The outer screen is called a Lenticular screen, it may come as a set with the Fresnel (the inner, and the way I would actually go) the screen is very hard to replace usually on a DLP as they have a somewhat sealed upper side and alot of screws.
Open Questions:
Samsung HLP5685W 56" Rear Projection HDTV-Ready Television Logo
222 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
