Question about Sony Ericsson W-950i Cellular Phone
Phone will not start
Hi Guys i connected mky w950i to the usb port and it went off and did not start again. tried to flash it but no go. it does not go beyong 70% any idea if this can be repaired or where it can be repaired
  • 48 Answers
Take it to te sevice centre....chances are with u
Posted on Mar 15, 2009
My mother board gigabit 61pme s2p series mother board.with amd althon 3ghz processor.the problem is when i connect the usb pendrive to back of the usb port...if i send data 1 or 2gb data to pen drive.the...
your problem is kind of complicated. Check if you have a defective usb flash drive or an usb connector by doing so:
  1. Try other usb flash drive. If it solves the problem you have a defective flash drive
  2. Try to plug in to other usb port. Observe each port. If you see that you have a problem with your usb ports, buy a new usb port card
Aug 01, 2011 | Intel Motherboard
Have downloaded a driver for mustek 600cu but still not recognising scanner
First install software driver if finish, connect your scanner USB cable to USB ports of CPU(make sure that your USB ports working good, test also using your USB flash drive).then you can see on screen automatic detect your scanner. if not detected try to change your USB scanner data cable. then try again connect to USB ports of CPU.
Just let me know if not yet working.
Thanks for using Fixya.
Jul 13, 2011 | Mustek Plug-n-Scan 600 Flatbed Scanner
Good Morning! Please help me how to restore the function of my laptop USB port, when i connect even flash drive, printer, scanner to my usb port it dosn't work properly, its hang then when i remove and...
Have you tried to shut down your computer and re-start it up again ? (to see if your USB port starts to works again ?)
One thing you should (must) do before you remove / detach a USB device (e.g. flash drive, camera, etc.) from the USB port is to make sure you properly "dismount" (eject/disconnect) the device first (e.g. use its Property menu option) before you physically remove the device (i.e. take it out - remove it from the USB port). If this is not done, you'll get the problems you're experiencing.
Jan 02, 2011 | Computers & Internet
My computer is not reading my USB port. It's connected but does not show up on My Computer. I am trying a USB storage device.
hi,if it's a flash drive it may have broken or went bad.does anything else work with your usb ports? does the storage device work on any other system?will help to narrow down the problem.
Nov 08, 2010 | Computers & Internet
Hi Guys I posted a problem with a Macally BTmouseJr where it would loose its connection to my portable each time the portable went to sleep. I just found the answer in the dim reaches of the web: Hold down...
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the software program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 01, 2009 | Computers & Internet
Jvm error 547 blackberry 8320
try running app loader again but before you connect your phone up to the computer pull the battery out, then connect the phone, then put the battery back in. A lot of times it will force the connection to get established and then you should be able to run app loader.
Nov 16, 2008 | RIM BlackBerry Pearl 8100
Won't scan
Hi there, this problem was posted over a year ago so I boubt you will check this but the best help I ever get is from discussion boards so I think its time to return the favor. I spent 3 hours on this one and finaly figured it out. After following all the steps on solutions.brother.com you need to fully uninstall all brother drivers and reinstall the correct drivers based specifically on your model. In this case mfc 8500. I did this and even went as far as downloading (from above website) the official uninstall tool. I then tried it again and still my driver install would bug at the "click next when connected" But when i connect my printer it doenst let me click next.
Anyways for me the answer to my problem lay in the simple answer of the usb cable i was using. I had a labtop connected to a USB connector conected to a paralell port adapter connected to the printer. I had a theory that the parallel port and usb werent communicating. Keep in mind that the before all this the printer worked fine but the scanner and email fax did not. I then diconected the paralell port from the printer and found a usb entry (weird shape not sure of the term) at the back of the printer. Looked through my cables and sure enough had the usb/weird shape usb cable. Once i connected that to the labtop like a flash everything worked. This was grueling but i hate to admit defeat to computer problems. if you read this..i hope it helps.
Get official uninstall
decompress and use it.
restart. (will not work if you dont)
Get updated driver and software package
Only Connect Usb to labtop now
Only now Turn printer/plug in printer now
Complete instalation
DONE!
Dec 12, 2007 | Brother MFC-8500 All-In-One Laser Printer
FActory reset went horribly wrong
try www.supportspace.com
100% free, but 100% qualfied experts to help you.
Oct 25, 2007 | NetGear WGR614 Wireless Router
Power failure after connecting the mouse
Hi sambi,
If you are currently, working on PS2 mouse port which is the error occurred as stated in your problem. Try to used other PS2 mouse which working on the other pc maybe there was a short circuit on your old mouse. If the problem persist, You can use the alternative way by using USB port to plug your optical mouse.
Try to look for ps2 to usb port converter in the computer stores maybe you can still used your old mouse.
Hope this will be helpful to you.
Best Regards,
Philip
Oct 24, 2007 | Computers & Internet
Sony Ericsson W-950i Cellular Phone Logo
49 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
