Betamax SL-HF500 VCR Cassette won't load
Loading cycle doesn't energize when cassette is placed in front load basket. At power up (with no cassette), all motors energize and cycle (i.e., motors appear good). Cassette loaded sensor is leaf switch that appears OK. Plastic gears/cams in loader mechanism appear OK. Belt from loader to mechanism is OK. Motors cycle when the ''eject'' button is pressed (no cassette in machine). Machine worked OK a year ago when placed into storage. What happened?
    Top Expert:
  • Televison & ... Master
  • 27,248 Answers
It is caused by components failing due to age. It was manufactured circa 1984 and had a projected life of 20 years. You may find a service centre that will undertake a refurbish but I have no idea where you are so cannot recommend any one.
Posted on Jun 17, 2017
  • 277 Answers
SOURCE: Guide Rollers Won't Engage
hi sorry cant help tou more then before it cant be solved in remote look for torn straps broken wheels look from where the noise is coming from it will give you a hint whats the problem DONT KNOW? take it to a technician good luck
Posted on Feb 26, 2006
  • 4234 Answers
SOURCE: DSR 1500P problems loading tape
Are there any indications on the front panel at all? There should be an error code of some sort there. If not, I'll need to research this a bit. Please update this with any codes.
Thanks,
Dan
Posted on Feb 09, 2009
sodeep
  • 3267 Answers
SOURCE: VCR won't eject tape - timing of loading mechanism is off
Now-a-days most of the gears are made out of plastic(HDPE, if I remember correctly), when the rewinding command is given even if one gear tooth is worn/broken it will throw the entire timing out of 'gear'. Since the problem has already occurred, and, this is the only function that has malfunctioned my advice would be to leave it as it is! ('cos repairing/replacing it is manual & therefore a costly affair plus there is no guarantee that the replacedment will function properly)....sodeep
Posted on May 09, 2009
JULIANFIX
  • 975 Answers
SOURCE: Drive belt for VT-428E VCR
YES !! belts are still available , you have to go to one of these ELECTRONICS PARTS shop , Im sure you will get the belts you need , good luck , AJ
Posted on May 11, 2009
  • 250 Answers
SOURCE: Panasonic video recorder malfunction
It sounds like you need a service manual - it tells you how to remove stuck tapes etc.If you need a service manual for this model, which is helpful for checking things/disasembly/assembly, you can obtain a free one from:-
http://www.reptips.dk/Reptips/NV-FJ620.pdf
Posted on Aug 31, 2010
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
VHS cassette accepts and ejects with kir..r...r sound. I have removed the power cord (Power OFF) and cassette was inserted halfway and then plugged the power cord (Power ON). At this time the VCR ejects...
First of I think you have a K-Deck mechanism. If you do a Google search for "Panasonic K-Deck" you should find the free information. If you can't you will need to E-Mail me.
This sounds like a a timing problem, perhaps caused by some damage to the Cassette Holder. The mode switch could be part of the problem too. They are quite tricky to set up to get the timing right, I do know the Cassette has to be inside the machine to set it up. The good news is that parts are easy to get hold of, so if any thing is damaged it can be replaced. Curry's partmaster is a good place for parts.
Oct 25, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Freeing a cassette stuck in the vcr player with no power light on
This can be due to many faults and need a full check up but I can fill up with few tips.
1. If the cassette is loaded and there is no power then the loading sectionmust be manually removed and the turned to push out the forward loading and eject the tape..
2. use of a 12 volt DC on the loading motor can assist to push out the cassette, make sure the motor connection is removed from the circuit so as not to damage the loading IC.
3. Some cases the capstan also is the loading motor and you can manually turn to release.
4. sometimes a jammed link , broken gear can be the cause and so it must be set free mechanically.
Sep 15, 2011 | Zenith VRA424 VHS VCR
I got an LG VCR GC980NW (MG 64) VHS VCR. I've wrongly pressed both the eject and play forward button at the same time. After that, the VCR shows both the 'EJECT' message and 'No Tape' signal, and then...
It is possible that the mechanism is out of mode as the front cassette loading mechanism and the tape forward loading mechanism have gone out of sync. Now it is important that the MODE of the system control is in the correct parking.
Hence I feel that the VCR must be opened and the mechanism reset-ted. Make sure that the tape loading has come back to the correct parking and also the cassette loading has returned, other wise remove the mechanism and reset.
Apr 05, 2011 | LG MG64 VHS VCR
I change the belt and now, I have a new problem. The cassette won't go inside the vcr. When I push the cassette, the motor won't start. If I shutdown and shuton the vcr, the cassette goes in and come...
It is possible that there is a fault in the INDETECT section of the cassette detection.
Normally this is triggered when the cassette is pushed into and if there is no detection the loading motor does not work nor the lock is moved to let the tray move on into the loading tray.
So when you put the VCR ON/OFF the detection motor works for a small period of time as a pre check which in the process allows the motor the load the cassette into the section but while it is inside the processor does not get the INDETECT or the IR END sensors to work thereby allows the rejection to be ejected out.
You will need to check the loading detect sensors and the IR sensors for the fault described.
Mar 10, 2011 | Toshiba M784 VCR
VCR tape stuck in machine
This could be a loading basket issue, or the tape has become tangled in the machine. Unplug the vcr, remove the top cover, if you see tape spewed in the mechanical section, plug the power and turn on, now try eject! if you see the tape pulling disconnect power and cut the tape with scissors and remove all the bits and pieces carefully not to damage the video head. If luck is with us the machine hopefully will eject the main cassette. If the tape is not the problem it is a loading issue, probably will need a technician.
Jan 17, 2011 | RCA DRC8335
My panasonic AG DV2500 mini dv VCR hates loading and ejecting.
this loading problem in the AG-DV2500 is caused by a defective cassette housing. list price from Panasonic is about $375.00.
Oct 15, 2009 | Panasonic AG-DV2500 DV/Mini DV VCR
Fault F04
F04 is "loading lock". most likely problem is that the timing of the gears in the tape loading mechanism is mis-timed.
Aug 01, 2009 | Panasonic Televison & Video
VCR kicks out cassettes
Sounds as if something got bent in the loading mechanism when you freed the stuck tape. Careful examination of the loading operation with the cover off may reveal the problem, but you may require a service shop, as there are hazardous voltages present inside, even when switched off.
Jul 13, 2007 | Toshiba MW24F52 24" TV/VCR/DVD Combo
Dec 28, 2005 | Panasonic PV-V4021 S-VHS VCR
Televison & Video Logo
201 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
