Question about Samsung LN-R3228W 32 in. HD-Ready LCD Television
Closed Caption My Samsung 32' flat screen Tv will not let me do closed caption on regular TV channels. It will on DVD and VHS recorders. What can I do?
  • 1 more comment
  • rsharris102 Jan 02, 2008
    We have had the exact same problem with our Samsung LN-T3253H LCD television. My parents are both deaf and need the closed captioning, but it keeps going in and out when viewing regular television channels.
    I am almost 100% confident that it is not the TV station's problem because it is happening on multiple channels, and all the other TVs in our house are displaying closed captioning just fine on the same channels that the Samsung is having problems with.
    gj7404, did you ever find a solution to this problem? I just sent an email to Samsung asking for help. We may just have to trade it in for a different brand...
  • Ric Lee
    Ric Lee Sep 04, 2008
    I have a 42 inch flat lcd. Captions have worked great for two years, while watching tv, the captions just guit for all channels. The other tv's in the house work fine. help.
  • Anonymous Mar 12, 2014
    how to scan channel in samsung flat screen tv
I agree that it is a tv issue. I have two tv's and the captioning on my Sony would be on and the Samsung says "captioning not available"
Posted on May 02, 2008
Yeah, I'm now believing it's the tv. The captions on the other tv in the house work great. My samsung is only 2 yrs old. This model was 1080 i...Kinda of costly. Still no solution???? CR. LEE
Posted on Sep 08, 2008
    Problem Solver:
  • 7 Answers
Closed caption depends on your tv stations. If a tv station does not support providng closed captions, then it will not really show closed captions. Closed captions depends really on the feature of a tv station
Posted on Apr 15, 2007
SOURCE:
How do I get closed captioning on a Samsung TV model TXJ2754?
Hello
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
 Different channels and fields display different information, such as additional
languages or supplemental information
Nov 23, 2010 | Samsung TXJ2754 27" TV
2008 Samsung 32" Flatscreen 720p Channels are
The cc has been enabled on your cable box. Usually there is a hidden menu accessed by turning off the cable box. Yes I did say turning off the cable box first. Then immediately pressing the menu button on the front of the cable box. The hidden menu should pop up and one of the menu options will be closed captioning,. Disable it.
Nov 09, 2010 | Samsung LN32A540 32 in. LCD HDTV
I'm trying to get my dvd recorder and vcr hooked up to my new flat screen tv. How do I connect them and what channel do I put my tv on (flatscreens don't have channel 3 or 4) to recognize the dvd recorder...
DVD players do not connect using regular cable connections Your flat screen TV should have separate Audio and Video connections. These are the connections that you should use to connect your VCR and DVD player. If you have a combo unit, that is a single unit that has both DVD and VHS in one box, you might be able to get your VCR to work on the cable connection. However your DVD will not be able to work as the cable connection doesn't allow enough information to pass through. If you go to your local Audio Video store and tell them what you want to connect they should have the cables you need for less than $10.00. Good luck.
Sep 15, 2009 | Televison & Video
Samsung LCD tv no sound from one channel only, no cable box, direct connection to cable, worked ok and then somebody may have fooled around with closed captioning...no closed captioning on now, but no...
First try viewing regular programming and see if you have audio on both channels. If you do not then go to the user menu and make sure that the chim function is turned "on". Then turn off the tv and listen for the down chime coming from both speakers. If you only hear the chime from one speaker then the Aidio circuits are bad on the Main bd and needs to be replaced.
Jul 13, 2009 | Samsung LN32A330 32 in. LCD TV
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Black box keeps poping up in the middle of the tv
your closed captions are turned on and in the text mode. turn them off or select cc1 to view that captions
Jan 06, 2009 | Insignia IS-LCDTV32 32 in. Television
Black rectangle in the middle of my screen
Turn off the text box function of the closed captioning.
Aug 31, 2008 | Sansui LCDWDVD320 32 in. TV/DVD Combo
Samsung LN-R3228W 32 in. HD-Ready LCD Television Logo
1,388 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
