Question about Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440
This machine prints 2 blank sheets and jams on the third blank sheet every time i make a single copy of a LTR size piece of paper. I have just installed a new drum and programmed the paper size as LTR and plain but now sucessIhave the exact same problem. When I try to print or copy something the
Brother MFC-8440D printer prints two blank pages then jams on the third without printing anything on it. when I unjam it redoes the same routine ad infinitum.
  • bourgois Jan 04, 2009
    I tried reloading the software on the cd that came with the printer and yet the printer keeps on printing two blank pages and jams on the third. i also downloaded the software for the printer that is posted on the brother web but it still prints two blank pages and then jams on the third blank page.
    I checked that the proper size paper is selected.
    if the problem were loose rollers feeding the paper that should not cause it to consistently print two blank pages and then jam on the third blank page no matter what order i give it (wether to print or to copy.
  • 1,498 Answers
Hi there Bourgois,
First delete any pending jobs in the print queue so we can start from scratch on a new print job.
Then try putting in a single sheet of paper. This is to check the feed and make sure it will begin the print job.
Tell me how this turns out by commenting. The results will determine the next steps.
Mike
Posted on Jan 04, 2009
  • Justin Case
    Justin Case Jan 04, 2009
    One more thing, did the printer ever work?
    If it did, what happened (if anything) prior to it's current behaviour?
    I'm leaning more and more toward an artifact remaining in the print queue. So make sure it's cleared, shut off the printer to reset it. Then try the job again.
    Please comment with the results.
    Mike
    Genius:
  • 1,142 Answers
Please make sure that the paper reem is not moistened and try a different paper reem still u face the same issue then you need to use a air blower and blow some air to clean the dusts accumulated
  • 4,472 Answers
The charger corona wire is probably broken or not making good electrical contact. The charger corona wire may be part of the toner cartridge. Try uninstalling and reinstalling the toner cartridge. If that doesn’t work, try another toner cartridge. This is what happens when it prints all black like that. If that doesn't work the printer may require repair/replacement.
http://www.brother-usa.com/service/default.aspx?WT.cg_n=Support&WT.cg_s=Service
you can locate a service center at that link. Also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
  • Lee A.
    Lee A. Jan 04, 2009
    sorry I misread and thought you said it was printing black pages, not blank. Here are the possibilities when it prints a blank page.
    A blank page is proof that the printer's mechanical
    mechanisms work, so there's some good news. To get a blank page, one
    of these is missing.
    1. No image on the drum
    2. No toner on the image
    3. No charge to pull the image onto the paper.
    Thanks,
    Lee
    Sergeant:
    Novelist:
  • 327 Answers
1)the gears which pulls the paper r broken/cracked internally
2)get the printer fully serviced/cleaned.
the problem you r facing is very common and it happens when the gear assembly looses its allignment due to any dust particles gets collected in between the gears and the gears worn out due to this after particular usage and needs replacements to solve the problem
thanks.
Posted on Dec 19, 2008
  • 679 Answers
Have you done the obvious like reset and pull the plug wait a few minutes and few minutes before plugging it back in. I will star a search as soon as I determine that you have done this.
  • Brother Master
  • 19,396 Answers
That is because the paper feeding unit has mechanical problem, usually the traction wheels that pich up the paper are lose and do not have enough pressure to pich up paper correctly.
Ensure that you are using the correct paper format , check between letter and A4.
    Genius:
  • 1,199 Answers
Uninstall printer software and drivers then reinstall then(it sounds like your software has been currupted) Also clean peper feed rollers!
How can I remove a paper jam from under the fuser bar in Brother MFC-8440?
sometimes a good long pair of tweezers helps , I use fishing forceps myself . have 4 different sizes from 2 inch to 14 inch
Oct 27, 2015 | Brother MFC-8440 All-In-One Laser Printer
How can i make double sided copies on a brother mfc 7420 printer???
The manual doesn't say it will do double sided copies. it will copy two pages to one sheet of paper or 4 pages to one sheet of paper. you will probably have to make a copy of the document and then reload the paper back into the tray. experiment with it like put it in face down or face up then which is the top of the page. you can use a marker on a blank sheet of paper to see how it prints out.
hope this helps
Jan 28, 2011 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
Printer prints blank pages
The print head is a part of the printer itself and unlike other printers, you cannot remove it or soak it without ruining your printer. So just try the print head cleaning option and perhaps replace cartridges, especially if you are using a third party or refilled cartridge which can clog even if it is full.
Mar 02, 2010 | Brother MFC 240C All-In-One InkJet Printer
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Putting out extra sheets
Do you "fan" your paper when you fill the machine? paper will adhere together, unless you " grab any corner of the fill, pull towards that same corner to allow air to get between the sheets.
Feb 04, 2009 | Brother MFC-8840D All-In-One Laser Printer
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
I have a brother MFC 8440
Have you checked the back paper door?, the paper tray?, and the drum/toner unit? If a paper was torn out of the machine, you may not be able to see the piece that is still triggering the jam signal. You can also pull down the paper guide around the orange fuser roller through the back door by pulling it gently to the left.
Sep 11, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440
Printer thinks its out of paper when its not. Displays messsage "Check Paper - Reload Paper." Have emptied and replaced paper stack several times. No visible jam. Have shut down and restarted. Still not fixed.
Oct 30, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
56 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
