Question about Hotpoint Aquarius WF220 Front Load Washer
The drum bangs on the spin
Wf240 3years old springs-shockers and bearings seem ok the banging seems to be inside the drum between the plastic outer casing and the inner drum hope you can help thank you gordon
  • 135 Answers
Two possibles for this are aloose balance block or cracked drum spider.The front block is most prone to coming loose.
To check spider rotate drum little by little and pull towards you to check for movement.
Post back if further help needed.
Thankyou
Posted on Dec 19, 2008
Whirlpool Duet Washer Model WFW9400SZ00 bangs only during spin cycle.
Yes you are exactly right, these bearings have failed & are causing the noise very common problem with whirlpool front loaders. very expensive to repair worth while looking into replacing instead of repairing as it will just happen again.The new LG machines are the best in my opinion.
Feb 06, 2012 | Whirlpool duet Washing Machines
My Kenmore model # 20642 991 leaks water when it spins (mostly with large loads) and the barrel inside seems to be loose or something because it bangs hard against the inside - sounds like the whole...
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub. The banging noise is due to being unbalanced. You may need to replace the balance ring on the top of the drum inside the washer. Watch this Video to see if this is how your machine is acting.
Nov 26, 2010 | Kenmore Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Makes a loud banging sound when spinning clothes
check springs and shock absorber.try to put more laundry.
Feb 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Front loader making loud noise with spin cycle
It may be something that was in the wash and fell thru the holes in the inner drum. Check all the plastic agitators and make sure they are all secure and an attach bolt has not backed out of one and rubbing the outer tub. It will wear a hole in it fast if it is.
Usually when the bearings go bad, it gets very loud on the spin cycle, like a loud roar and sometimes clothes will have rust or grease stains on them.
I just replaced my tub bearings on my Frigidare and spent about $60. They are all pretty much the same. On mine they only list the complete rear outer tub assembly with bearings, but you can knock the old bearings and seal out and match them up at a bearing supply house or you can buy online. Online seems much cheaper. If you buy bearings, make sure you get ones with a -2rs on the end of the part number. ex. 6308-2rs. They are sealed and hold up much better in water environment.
I would give it a try, the junk man doesn't care if it comes in pieces or one big piece.
There are a couple online articles that can probably help you. Do a google search for 'washer rear tub bearings"
Jan 29, 2009 | GE WPXH214A Front Load Washer
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
Tub bangs and seems to be spinning out of round
One of the support arms on the back of the spin basket (stainless steel tub) is broken and causing it to spin in the fashion you describe. The only fix is to replace the spin basket. Using it in its current condition will cause serious damge to the outer tub shell. Let me know if you decide to replace it or need assistance locating a replacement tub. I can assist you in how to disassemble the washer and how to reinstall a new tub. Sorry...I wish this was better news.
Oct 03, 2008 | Kenmore Elite 45986 Front Load Washer
Machine banging when in fast spin
if the noise is coming from inside the drum then it will be the bear ings if this machine is less than 3years old then this is what bust hotpoint they changed the bearing setup and put a spring on it which its the spring that is the complete failure u need to take the complete drum out strip this put the new bearing set in but without the spring this wil put at least 2-3years on the bearings its a big job and costs about £120 to fix u r accually better off buying a completely different washer no good are hotpoints anymore m8
Jan 26, 2008 | Hotpoint First Edition FEW12 Front Load...
or the three legged spider that attaches to the drum. its made of cheap metal and one or more legs can crack or break letting the drum loose - seems like bearing but isn't! cost about £40
Sep 28, 2006 | Indesit W 123 Front Load Washer
Hotpoint Aquarius WF220 Front Load Washer Logo
448 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
