Question about Whirlpool GD5SHAX Side by Side Refrigerator
Water is not getting to the ice maker, water is coming out of the dispenser. Water was turned off temporarily to replace a sink. Now no ice.
  • 3 more comments
  • joes490 Jan 19, 2009
    I had similar problem. Water OK, but it went to fill icemaker, water flooded the freezer and when opened,my kitchen floor. Did you get any answers? Thanks,Joe
  • Anonymous Jan 21, 2009
    I pulled the fridge last night because both ice and water were not working and checked to be sure I had a good water supply to the fridge itself. Once checked, I turned the water supply back on, and water dispenser worked again, but no ice is being made. Have to believe that the water supply to the ice maker is most likely froze up. Wondering if I'll need to shut down the whole thing and let it thaw out before it starts making ice again.
  • Tyler Otto Jan 27, 2009
    Can't get the ice maker to produce ice. Just stopped all of the sudden a couple weeks back. Can't figure it out. Tried unplugging the fridge and then plugging it in again. Could ice-maker water line be frozen? Could the problem be else where? I have the type 2 system with the icemaker on/off switch. Anybody have any ideas here? Thanks, Tyler
  • rmdlp2008 Feb 11, 2009
    water pressure in door was low or non-existant. no water getting to ice-maker....changed water supply line to fridge....now water pressure in door is fine, but still not getting water to icemaker....doesn't seem to be frozen at icemaker...anyone help?
  • Carlton Hairston Feb 21, 2009
    Ice maker is not making Ice! Problem started about 2/13/09. This has happened before but it was that the door was not closing tight ( Too many things stuffed in the freezer)
  • Whirlpool Master
  • 8,220 Answers
Get a test cord(lamp cord with 2 spade clips) Power up the water valve for a sec and see if water comes out.
Posted on Feb 20, 2009
I have a Matag MSD2458GE refrigerator. Water dispenser on the door works but, the ice maker doesn't work at all. Seems no water reaching it. Needs new filter, but no ice before replace filter light.
According to your user's manual, "If water flow to the ice maker or dispenser decidedly decreases or if an objectionable taste or
odor returns,change the filter sooner than
recommended."
"Leave the refrigerator door open while removing and installing filters or plugs; this will prevent water
from flowing through the system and running into
the fresh food compartment.
• A newly installed water filter cartridge may cause
water to temporarily spurt from the dispenser"
Automatic ice maker not operating
the stop arm in OFF (up) position
•the water supply turned off
•the water pressure too low
•the freezer too warm
Ice dispenser not operating
ice jam in the dispenser
•ice maker not operating
• lock switch on (see page 11)
Water dispenser not operating
• water pressure too low
• lock switch on (see pg. 11
To locate an authorized service company in your area,contact the Maytag dealer from whom your appliance was purchased; or call Maytag
Appliances Sales Company,Maytag Customer Assistance at the number listed below. Should you not receive satisfactory warranty service,please
call or write:
Maytag Appliances Sales Company
Attn:CAIR
Center
P.O. Box 2370
Cleveland,TN 37320-2370
U.S.
1-800-688-9900
CANADA
1-800-688-2002
U.S. customers using TTY for deaf,hearing impaired or speech impaired,call 1-800-688-2080.
Feb 24, 2017 | Refrigerators
Ge gss22 where is the ice maker supply valve
Pull the refrigerator out and follow the water line to the back. It will go to a double valve solenoid. One half is for your water dispenser, the other for the ice maker. It is possible that this solenoid has failed. You can order the part online and replace it pretty cheaply. Just remember to turn off the water supply (usually under the sink) and unplug the refrigerator before hand and have a towel ready to catch water that will drain from the lines.
To order the new part get the full model number of your refrigerator and go to the GE website and look up their replacement parts page. You should be able to search for that model and all of its related replacement parts there.
Mar 08, 2012 | GE GSS25WSTSS 25.4 Cu. Ft. Side-by-Side...
Ice maker water line comes loose when water turns on
Sounds like your terminal connections on the water valve have gotten reversed. Try switching them..Also you may need new water valve..
Aug 03, 2017 | Refrigerators
Ice maker works but not water dispenser
Here are the steps I took to fix thi:. First, if you tapped into a copper line near your sink, turn off the off the tap completely and turn it back on again. Why? Occasionally, calcium deposits will build there and cut down your water pressure. You may have enough pressure to run your ice maker, but not enough to push the ice out of the line (I'll talk about this later). Turning the tap on and off breaks up the calcium. This will also fix an ice maker that's slow to make ice or makes hollow cubes.
Next, I just kept running my water pump (about sixty seconds or more at a time) until the water finally started to come through. When it did, a few inch-long pieces of of ice came through -- telling me that the problem was a frozen water line. If running the water pump several times doesn't work (I think it took me six tries), consider turning off your fridge for a while (be sure to remove food and pack in dry ice).
May 05, 2009 | Kenmore Refrigerators
No water flow to ice maker
Two possible answers on this one. The water control valve for the ice maker is defective or the switches inside the front of ice maker are stuck.
Please send the model number listed for your refrigerator so I can help you find the ice maker switches and parts break down for your refrigerator. Below is my website address.
http://servicepartstec.blogspot.com/
Let me know if I can help you more, Thanks Sea Breeze
Mar 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
In door water and ice cube not working
Water dispenser is a simple touch switch in door energizing a solenoid water valve behind ventilation grate above refrigerator. Water tube runs down into and ends at ice dispenser chute. Should hear solenoid click at top of fridge when activate water touch switch. Can unhook discharge side of solenoid valve temporarily to prove water output. If water dispenser tube acts blocked it could be frozen where it ends-look up the hole at the bottom of refrigerator control buttons.
Ice maker is totally different system. No clicking when push ice button but ice in bulk tray may mean the simplest of malfunctions: Ice bin not pushed in the last half inch if ice auger not lined up with drive pegs. There are hidden switches behind ice bin that need to be engaged or nothing will happen in the ice maker: no auger noise, no clicking, no new ice making. Ice bin will be flush with sheet metal if it is in the right spot. Also plastic juice rack won't hang properly if ice bin not pushed in all the way.
Dec 19, 2008 | Sub-Zero 690 Side by Side Refrigerator
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
Take the icemaker out and let it sit in the sink for around 12 hours. Then put it back in. This has worked for me when I have the same problem. I think that the water line is freezing up. I have to do this every month or two.
Mar 20, 2008 | Hotpoint HSM25GFRSA
Whirlpool GD5SHAX Side by Side Refrigerator Logo
127 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
