Question about Kenmore 20092
KENMORE ELITE MODLE 110 20082 992
I own a kenmore elite washer. The panel keeps beeping and won't even allow me to change to another setting. Can you help?
  • AmyLun Jun 15, 2008
    We have a Kenmore Elite, front loading dryer model 11060052990. The front panel keeps beeping and won't allow me to change the settings. The dryer will run for about 2mins (beeping the entire time) and then shut off.
    Can you help me?
  • katrinkagee Sep 02, 2008
    same issue. Washer and dryer both the same model line and the dryer is out, too. I think the electronic controls on both have gone whacko. Beeping, no working. One service tech soldered the board and stated that we were lucky to have him as other techs would just replace the whole board. I felt lucky for about a month until the unit died again. SOMETIMES unplugging the washer and letting it stand for a couple of days helps reboot the board, but no such luck with the drier.
    President:
  • 742 Answers
Ask here, they can get you every Kenmore manual. The service is not for free, but often worthy enough.
Posted on Jul 02, 2012
We have the 11020092991, same washer. Ours has had all kinds of problems. We kept renewing our extended warranty and finally in August 2007, Sears concurred and called it a lemon and gave us credit for a new washer.
Posted on Sep 02, 2007
44921300 elite kenmore owner manuals
http://downloadfreemanuals.com/kenmore-washer-manual/
Apr 25, 2013 | Kenmore Elite 45986 Front Load Washer
Kenmore Evenheat MOD# 110 62056100
okay, kenmore elite have had these problems so often, you need to replaced the touchpad, not the board, jjust the touchpad, it cost around $150.00.
Sep 10, 2009 | Kenmore Dryers
Kenmore Elite Catalyst Washer Keeps beeping and displays 10
I'm not sure if you've solved this already but our Kenmore Elite washer had a similar problem that got worse. It ended up being the whole touch panel had to be replaced. I was able to diagnose and replaced it myself with help from the Tech sheet that is underneath the touch panel. Our Kenmore Elite dryer also had to have this paenl replaced several years ago when it was fairly new. Hope this helps.
Sep 08, 2009 | Kenmore 3.2 cu. ft. Top Load Washer
Kenmore elite washer cycle signal keeps going off an on turing cy
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 04, 2009 | Kenmore Washing Machines
HE3 Washer just keeps beeping at me when I push the start button
Bad motor pump and it's a common problem kenmore elite front load washer so we need to left the washer from the front and get under the washer to get the motor pump replaced
Nov 05, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Oasis Model# 110.27087603
I had a very similar problem with my Oasis He Washer 110.27087603. The machine was randomly cycling through different water temperature indication lights. It would repeatedly beep and not allow a wash cycle to complete. Fixya.com alerted me to the "upgrade" to the electronic control W10112112 to W10189966. My machine was scheduled service and a Sears tech replaced that board. My problem with random cycling continued and the tech stated the touch panel electronics; part # 8564392 would fix the problem. He said one of the microswitches on the panel was probably stuck and not allowing the machine to enter a wash cycle. I found the 8564392 panel at http://www.prosupplyco.com/search.aspx?find=8564392 for a very reasonable price. Realize that Whirlpool parts are Whirlpool parts and Sears doesn't hold the only key to them.
Oct 29, 2008 | Washing Machines
Need diagnostic test for Kenmore Elite Oasis HE top load washer it is making beeping noises and has a mind of its own
pick any button but power or pause (spin works ok) pres and hold 3 sec release 3 sec hold 3 sec release 3 sec hold 3 sec this will put intio diagnostics usually if a fault code is stored this will show first press same button to step through post fault code if any asap and will try to help may to try several times to get into diagnostics
Jun 21, 2008 | Washing Machines
Washing Machines Logo
190 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
