Question about Toshiba 50H72 50" Rear Projection Television
Picture (video) jumps from bright to dim
Picture will be nice and bright, then suddenly it dims, but not completely black. Basically too dim to watch. "Menu" callup presentation not affected - it does not dim when the picture dims. Tried reseating the video boards and connectors with no effect. Turning set on and off sometimes restores the bright picture, sometimes not. Problem occurs regardless of which input is used (cable, front A/V, rear A/V). Continuous watching never seems to restore the bright picture. Trying to analyze it with the Toshiba print is a nightmare.
I figured it out myself. R243 was intermittently open. Replaced it, and now we can watch the Super Bowl.
Posted on Jan 29, 2009
  • Robert Hero Aug 22, 2013
    Where the Hell is R243 ??? Which board ?
Gmc envoy bright lights work dim lights will not work
Your circuit lights may be bright or dim according to how your electrical system was set up. It may dim when lights are off and get bright when lights are on. ------------------------------------------------------------------------------------------
Car Diagnostic Tools
Nov 24, 2012 | Buick LaCrosse Cars & Trucks
Hitachi 32UDX10S picture is dim with brightness at 100%
The led backlights may be failing or the driver circuit isn't working. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get parts and led testers here.
Feb 12, 2018 | Hitachi 32UDX10S 32" TV
Tv dims after turn on
is the auto contrast on? If room is bright it will dim to compensate for brightness.
May 26, 2012 | Panasonic TCP50UT50 Smart Viera 50 Class...
Hitachi 50V710 The picture is dim, then the bulb went out. I replaced the bulb. all works but the picture is still dim. You can barely see the screen durring the day. And can only use it in a dark room...
I've seen this in two scenarios.
First: The housing of the bulb is dirty (the lens the bulb lights onto) and the internal screen is dirty also.
The second: The bulb is wired reversely of the proper way to wire it. This will light the bulb, but will not light as bright as when it is wired correctly!
Thank you and please rate!
Apr 08, 2011 | Hitachi Televison & Video
Dim display on laptop LCD screen
The part you need is called a CCFL Backlight. Basically, there are lights in the screen that back-light/illuminate the display. Over time it burns out and you are left with a dim and completely dull display. These are a pain to replace and expensive when bought from the manufacturer. But this site has a break down with dis-assembly instructions...if you want to try it.
Mar 10, 2010 | HP OmniBook XE3 Notebook
The LCD screen on my Gateway M-6317 is dim. How
Press and hold the 'FN' key and tap the key that has the picture of a sun and an up arrow (or some other similar picture that dictates brightness - there should be two different keys that affect brightness one to increase and the other to decrease). Once you have the brightness set to your liking quit tapping the 'brightness' key and release the 'fn' key
Sep 29, 2009 | Gateway MX6447 Notebook
Toshiba satellite a135 monitor goes black
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S2386 Notebook
The TV brightness dims when the we get a dim scene
This is probably normal and called "Dynamic Contrast". Maybe this company has some other proprietary naming.
Basically, the Backlight (LCD) or Bulb (Projection) will be dimmed during dark scenes to allow the TV to make a deeper black.
Apr 26, 2009 | Televison & Video
Head Lights go dim, instrument panel goes dim when I turn on my Headlights
Does it go completely black or just dim? Most displays dim when you turn the lights on to make the display darker so its not too bright. GPS and other displays do this. Do you have any problems with any other of the car's electronics?
Oct 16, 2008 | 2004 Saturn VUE
Ideal settings for Samsung LN-T 4234H
sure, lcd tvs need to be tweeked depending on the light in the room the darker the worse the picture. so try this
from standard:
picture: 85 to 95 %
brightness: 45% or adjust the black of the video to the black of the pilar bars to equilize them.
color: 32 to 38% or until the flesh tones are not so hot
sharpness: low 10%
tint: always to center
color temp: cool1
back lamp ( if avalible) low when lights are dim, high when lights are bright.
the problem with LCD is they don't look so good with dark sceens. the contast ratio is very low. natively 3000:1 aas compaired to plasma or other direct view TVs. the LCD is back lite and the thin materal of the LCD can not completely block the back light from coming thru. there for the complete "black screen" is illuminated "blue". the best thing is to keep the lights on bright in the room for the best picture.
Feb 22, 2008 | Samsung LNT3242H Television
Toshiba 50H72 50" Rear Projection Television Logo
400 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
