Question about Technics Audio Players & Recorders
Buzzing problem with Technics Digital Ensemble SX-PR603/M Piano..
I have a Technics Digital Ensemble SX-PR603/M which I purchased in 2001. It's been a great instrument until this past spring when it developed a "fuzzy" or "rasping" quality. When the problem developes I locate a particular note that has this buzz and play the cord of which this note is the root tone. I then play several similar cords at different positions on the key board, while increasing the volume.Eventually there seems to be a "letting loose," with the rasping sound increasing upwards in pitch as if traveling up to the highest reaches of the keyboard itself. By this time the "rasping" may have become a "crackling" sound. This "letting loose" can occur without any warning and it can be startling to the listener.After 2 or 3 minutes of tinkering around in this fashion the istruements's normal clarity usually returns. The sound of the piano then seems to remain clear until the next day.Any idea what might be causing this to happen? And is there anything that can be done to rectify the matter?Thanks,Tom
reddevil6
  • 1673 Answers
SOURCE: NO SOUND
You posted in the wrong section, you will need to repost.
Posted on May 13, 2008
  • 85 Answers
SOURCE: my grado sr 225's have developed a crackling noise
You have damaged the internal drive units,need replacing
Posted on Jan 19, 2009
ladyaudio
  • 22 Answers
SOURCE: midi keyboard sound quality bad
you are likely running it thru a soft synth. Check the help files there is a section in there on "using soft synths" that will explain it more fully. Plus a usb connection can sometimes be problematic (not always). But the tutorial in the help files will tell u how to use the sounds from the piano instead of the MIDI sounds
Posted on Mar 05, 2009
SOURCE: I have a Roland HP2e
Just managed to fix key loudness problem on my sister's HP-2E after talking to the local Roland Service Center. Basically I had to remove all the rubbery strips under the keyboard, clean them and clean all the contacts on the keyboard PCBs with CO contact cleaner. Not a trivial procedure - 80 or so screws to remove and replace and a lot of parts.
It has completely solved the problem (apparently its not unusual on any keyboards). I have posted more details and a couple of pictures on my blog (http://web.me.com/iain_sommerville/Home/IainBlog/Entries/2009/4/20_Piano_Repair_2nd_Attempt.html not sure if that is a permalink - if it doesn't work go to http://sommerville.info and search for HP-2e).
A roland service center can fix this as well however it is pretty time consuming so they will charge you. They can also sell you replacement keyboard contact strips if cleaning them doesn't work. Hope this helps
Posted on Apr 20, 2009
  • 5603 Answers
SOURCE: Our Yamaha clavinova CLP-115 is buzzing, even with
Without power to the unit no sound should be generated. Make sure there are no other connections.
MAYBE you have a wall transformer behind it that is buzzing. MANY wall transformers develop buzz.
Another source is flourescent lights and even some of the low voltage halogens have noisy transformers in the base.
Posted on Nov 18, 2009
I have a Technics PR-305 Digital Piano It was working at the End of October, but around the beginning of November 5 my Technics PR-305 Digital Piano made a loud humming sound, then it quieted down, I
Also, in addition to more info I need; look on p 91 of the online owner's manual linked below. Pay attention to Sounds and Effects, the first section therein. Follow the directions closely, esp., read pp. 26, 83, and 86 which are referenced for detailed help w/ sound issues. TECHNICS SX PR305 Manual Page 91
Nov 26, 2014 | Casio Music
Where would I go to get a back light for a Technics PR-305 Liquid crystal display
It could be the light, or it could be the inverter that powers the backlight. Try asking this guy: http://www.mikebarden.com/technics-electronic-digital-kn-pr-px-piano-keyboard-ensemble-repairs/
Jun 09, 2014 | Universal MCU Extension 4 x 4 16-Key...
I need a manual for a Technics PR 350 Digital Ensemble Piano. Any idea where I can get one?
http://www.manualsonline.com/mdownloads/c1935b11-3977-438d-b81a-17c2101c2a7c.pdf
Aug 03, 2010 | Music
How to open 3 demo pieces of Technics SX-PC10 Digital Piano?
Usually you just select which demo BEFORE starting the demo.
If you are meaning to try to DOWNLOAD via MIDI or other those demo pieces that is USUALLY not possible as the pieces are stored in a ROM which is inaccessible via MIDI or USB.
They OFTEN don''t even send them out on the MIDI port when playing them.
Apr 30, 2010 | Yamaha NP 30 76 Key Lightweight Digital...
NO SOUND
May 11, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
533 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
