Question about Panasonic NN-T990SA Microwave Oven
I want to defrost a small frozen food item for 2.5 minutes. How do I do this with my Panasonic Genuine Sensor 1300W Microwave? Thanks! Dan
  • Panasonic Master
  • 9,098 Answers
You can download your Panasonic owner's manual here.
Posted on Dec 21, 2008
How set clock on oyster microwave and grill?
Oster Microwave Oven Operating Instructions
  1. Press the "Clock" button once, then the correct number buttons to set the desired 12-hour time. ...
  2. Press "Timer" to set the timer function. ...
  3. Press the number pads to select a cooking time. ...
  4. Press "Defrost by Weight" to defrost a food item by the weight of the item. ...
  5. Select "Speed Defrost" to defrost food quickly.
More items...
Oster Microwave Oven Operating Instructions ' Hunker
https://www.hunker.com/13407971/oster-microwave-oven-operating-instructions
set clock on oyster microwave and grill Google Search
Jun 24, 2018 | Microwave Ovens
Microwave genius sensor 1300w
I don't believe it is possible to change the display angle/tilt on this microwave. The unit ships with a protective film over the display that should be removed to make the display easier to read. However, this model is known to be difficult to read unless looking at straight-on. That and needing a flashlight to look at your food with the door open since the internal light does not stay on when door is opened. Good luck!.
Jun 13, 2014 | Panasonic NN-SN657SMicrowave Oven
On our new microwave there is 2 buttons for defrost. what is the difference? it does not mention defrost in the booklet we got with the unit.the mdl.# is GMH5205XVB
Using the Auto Defrost feature on my microwave oven
How do I use the Auto Defrost feature on my microwave oven?
To use the Auto Defrost feature on your microwave oven, please do the following:
  1. Unwrap food, place on the turntable, and close the door.
  2. Touch Defrost.
  3. Select food by entering 1 for Meat, 2 for Poultry or 3 for Fish, or touch Defrost repeatedly to scroll through the food selections.
  4. Enter the weight in pounds:
    Meats and Poultry can be set from 0.2 to 6.6 lb (90 g to 3 kg).
    Fish can be set from 0.2 to 4.4 lb (90 g to 2 kg).
    Doneness may be adjusted at this time by touching Cook Time.
  5. Touch Start. The display will count down the defrost time. When the cycle ends, "End" will appear in the display, and the end-of-cycle tones will sound, followed by reminder tones.
  6. Touch Cancel Off or open the door to clear the display and/or stop reminder tones.
The Defrost system has 3 categories: Meat, Poultry and Fish. It should not be used for food left outside the freezer more than 20 minutes and frozen ready-made food. Use the following chart as a guide.
Here is your owners manual:
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GMH5205XVQ_Use%20and%20Care_EN.pdf
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | Whirlpool Microwave Ovens
Would like to know how to use the Inverter. Is it for baking & defrosting? Have never used one before and do not have a manual.
Hi ifcope2000,
The inverter in your oven is for defrosting. It works on the basis of weight of the food to be defrost. To use the inverter follow the following steps.
First place the food on the microwave dish and then close the door.
Now press Inverter Turbo Defrost.
Enter the weight of the food using the number pads.
Press Start.Defrosting will start. The time will count down. Larger weight foods will cause a signal
midway through defrosting. If 2 beeps sound, turn over, rearrange foods or shield with aluminum
foil.
Atul
Mar 13, 2011 | Panasonic Microwave Ovens
Where can I find manual for Genius Sensor 1300w
http://service.us.panasonic.com/OPERMANPDF/NNSN657S.PDF
Feb 07, 2011 | Panasonic NN-SN657SMicrowave Oven
GE Spacemaker microwave oven - Sensor error
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic genious sensor inverter 1300w nn-t664sfx displays code "h98" & will not run - what's the problem?
Mine did this once and it was the magnetron. Once replaced, it worked fine. Repair is an option if it is still under warranty or someone will do it on the cheap. Otherwise, just get a new microwave, since this is the main part.
Oct 04, 2009 | Panasonic NN-S960WA Microwave Oven
My Panasonic Microwave Genius 1300W will not heat up the food and the rotate dish spins and the sensor reheat will not heat up the food. Nor cook Pop Corn when pressing the buttons to 2:00 cook time. I...
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 14, 2009 | Panasonic NN-S960WA Microwave Oven
What cause the wattage difference?
Wattage is based upon voltage & current. I would think that on the 1300W unit, either the voltage or the current is higher than that which is used on the 1200W unit.
Perhaps the magnetron in the 1300W unit is being driven harder. Are the fans the same size?, The magnetron in the 1300W could be running harder and they have a larger fan in it.
In any event, if the part numbers are the same, you should have no trouble using one units parts to fix the other.
- Jim
Feb 17, 2008 | Panasonic NN-S561 Microwave Oven
Panasonic NN-T990SA Microwave Oven Logo
131 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
