Question about Black & Decker BDCH100 Ceramic Compact Heater
CAUTION LIGHT only -- no Fan or Heat
My Black & Decker BDCH100 had been used for approximately 20 hours before the present problem. The CAUTION LIGHT comes on and no other response from the heater ...no fan and no heat. I have misplaced the manual and have no reference for a solution. Does this CAUTION LIGHT mean the unit should be reset? If so, how is this done? Any help will be appreciated.
  • 4 more comments
  • kmmast Jan 25, 2009
    I have the same problem! and i cannot figure it out, and i am sitting in my room freezing
  • Anonymous Feb 06, 2009
    My heater only runs for 2 to 10 minutes before the caution light comes on and the heat cuts off. I'd like to use it to heat my bedroom at night but it won't stay on long enough to heat my small bathroom.
  • Clark with Big Toast Dec 11, 2012
    Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That gets dust in it and causes it to trip. Try cleaning it. While you are there, squirt the motor bushings good and dab a drop of synthetic motor oil (just a drop) on EACH motor bushing. Personally, I required this and bypassed all of the safety features.
    Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That gets dust in it and causes it to trip. Try cleaning it. While you are there, squirt the motor bushings good and dab a drop of synthetic motor oil (just a drop) on EACH motor bushing. Personally, I required this and bypassed all of the safety features. You can bypass that sensor with soldering or cutting any wires. All you have to do is unscrew the wires from the holder and then unscrew the tiny nuts and tiny bolts. Then bolt the together and put it back in the holder and fighting the screw to hold it in. This method fixes the issue completely as it removes the sensor from the equation.
    MILKHOUSE HEATER "CAUTION LIGHT" SOLUTION: Unplug the heater. Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That goes bad and causes it to trip. While you are there, squirt the motor bushings good with the brake cleaner and dab a drop of synthetic motor oil (just a drop) on EACH of the two motor bushings. Personally, I rewired this and bypassed all of the safety features. You can bypass that sensor without soldering or cutting any wires. All you have to do is unscrew the wires from the holder and then unscrew the tiny nuts and tiny bolts. Then bolt the together at one end (note the position) and put it back in the holder and tighten the screw to hold it in. This method fixes the issue completely as it removes the sensor from the equation. In fact, I just did that on my third milkhouse heater and it has been running solid for the last 15 minutes. Use your modified heater with caution!
  • Anonymous Mar 17, 2014
    The caution light comes on when it is plugged in and it will not work
    New Friend:
  • 4 Answers
MILKHOUSE HEATER "CAUTION LIGHT" SOLUTION: Before I explain, let me clear this myth up: this is NOT an issue with the pendulum safety switch (some mistake that for a "mercury" switch). To begin, unplug the heater. Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That goes bad and causes it to trip. While you are there, squirt the motor bushings good with the brake cleaner and dab a drop of synthetic motor oil (just a drop) on EACH of the two motor bushings. Personally, I rewired this and bypassed all of the safety features. You can bypass that sensor without soldering or cutting any wires. All you have to do is unscrew the wires from the holder and then unscrew the tiny nuts and tiny bolts. Then bolt the together at one end (note the position) and put it back in the holder and tighten the screw to hold it in. This method fixes the issue completely as it removes the sensor from the equation. In fact, I just did that on my third milkhouse heater and it has been running solid for the last 15 minutes. Use your modified heater with caution! Let the brake cleaner dry before you energize this device!
Posted on Dec 11, 2012
According to the manual, the "Caution Light" means that the unit has overheated. They suggest running on a lesser setting, but you also may want to see if you can return the unit (if it is still under warranty).
Posted on Jan 01, 2008
Black decker problem
This could be a lot of things. One thing to check is the vents on the head. IF they are clogged then it over heats. Another thing is the battery connections and temperature. When it fails take the battery out if you can and see if it is hot.
Jun 26, 2014 | Black & Decker String Trimmer Cordless 12"...
How to turn it on
To switch the appliance on, press the ON/OFF button. It takes approximately 15 seconds for the steam mop to heat up. When the steam mop is first turned on, the water reservoir will glow red. Once the steam mop is ready to use the water reservoir will glow blue.
Jan 29, 2014 | Black and Decker USA BLACK & DECKER SM1620...
My Black and Decker Drill and Hand Saw have brand new battery pack and brand new charger to BE SURE battery is fully charged but still don't work
it is probably the brushes on the motors are wore out or stuck and not making contact. pretty much junk unless you feel confident enough to attempt repair.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Black & Decker Black and Decker 18V...
My 20" Black & Decker
Hi Frank,
If you're lucky there might be just a break in the flex somewhere or a loose connection in the plug.
Have a look at these tips I've written for problems with power tools.
http://www.fixya.com/support/r9189659-power_tools_not_starting_up
Jul 25, 2011 | Black & Decker Garden
Do you sell replacement air filters for the BDCH100-301?
google your heater for local agent who should be able to supply parts
Aug 06, 2010 | Black & Decker BDCH200 Ceramic Compact...
Need charging instructions for black & decker model sl1028 type 1
Hello. Use an ordinary extension cord and plug it into the back of the light and into the wall. Charge it for 20-30 hours, but not more than 30 hours. Here is the downloadable manual for future reference
http://demandware.edgesuite.net/aaea_prd/on/demandware.static/Sites-black-and-decker-Site/Sites-cpo-master-catalog/default/v1269899899597/dw_manuals/black-and-decker/bdknvec157bd/bdknvec157bd_manual.pdf
Mar 29, 2010 | Black & Decker Black And Decker 2 Million...
I have a 12V deep cycle battery for my RockWood Tent trailer. I want to dry camp (no electrical hook up). I am wondering how long my battery will last working my furnace fan/lights etc. (not the fridge). I...
You'll have to figure out the approximate number of hours that you want to use each device (fan, light, etc.) and then find out for each device how much electric it uses (by checking the wattage). Here's a link to a calculator that will tell you how much each device will use.
http://www.alternate-energy.net/batteryamphours03.html
You will also need to know your battery's amp hour rating. In summary, take each device and calculate its run time and then subtract all of them from your batteries total run time.
In practicality, these are all theoretical calculations. If I were you, I would try a simulation of this in my backyard and see how well it works rather than trying this out for the first time in an environment where you have to have these devices. Good luck!
Mar 16, 2010 | Black & Decker Black And Decker 12 Volt...
Power indicatoror
From the manual:
"Attach the barrel tip of the AC Charging Adapter to the AC Charging port of the POWER TO GO® and plug the standard two-prong plug into an appropriate, functioning 120 volt AC outlet. The red Battery Status LED indicator will flash, indicating a proper connection has been made and the unit is charging. The green Battery Status LED indicators will gradually light as the charge level rises. The POWER TO GO® must be charged for approximately 11-17 hours prior to first use. All Battery Status LED indicators will be lit solid (the red indicator will stop flashing) when the unit is fully charged.
Aug 29, 2008 | Black & Decker Power To Go Cordless AC/USB...
Noisy B&D Ceramic Heater
unit uses a sealed "muffin" fan.  you could check out grainger supply for a replacement fan.
Feb 22, 2007 | Black & Decker BDCH100 Ceramic Compact...
Black & Decker BDCH100 Ceramic Compact Heater Logo
831 people viewed this question
Top Black & Decker Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
Are you a Black & Decker Heating and Cooling Expert? Answer questions, earn points and help others
