Question about Toshiba TP61G90 61" Rear Projection Television
How you hokup sound system to the TV TP6190
In back the T.V how you hookup sound system
  • 67 Answers
On the back of the t/v connect RCA cables to the audio out (right-left) then plug the other end of the RCA cables to the input of your reciever or amp ( t/v input-aux input-vcr input any of the inputs will work but DON"T use the phono input!!
Posted on Dec 19, 2008
Hookup vizio vsb207 soundbar to tv with xfinity cable.what is the wiring connection
You will need to hook the TV sound bar system to the Variable Audio output jack on the back of the TV.
Oct 26, 2016 | Vizio Televison & Video
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
Hi I just buy a 47 lg google tv series g2 the only problem I have is that I dnt have full sourround sound every time im watching tv the sound of the tv just stop for 1 second every 15 minutes and this is...
There is a problem with the tv, I don,t have a LG tv, But the tv i got use,s a optical jack for the audio hookup to a Amp or Reciever, I just have one optical cord hookup to my preamp end it works perfectly,
Dec 05, 2012 | Audio Players & Recorders
My super nintendo has no sound and I replaced the sound module and still no sound please help !!
Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
Check your system connections to ensure they are firm and correct.
Remove and reload the Game Pak, pressing firmly to ensure it is locked in place.
Many Game Paks have an option that controls one or more volume variables. These may have been set to maximum volume during the manufacturing or testing process. Consult the game manual for directions on how to adjust the settings. You can usually get to them by going into the Options screen.
Remove the AV cables and reinsert them with a slight twisting motion. Make sure the Video Cable (the yellow plug) is in the video input. Plugging it into an audio input will cause buzzing. Also, make sure none of your audio (red) cables, are plugged into a phono jack on your stereo, which can also cause buzzing. Finally, make sure the Stereo AV Cable is plugged into input ports, not output ports. For a detailed review of the hookup, please check our hookup instructions.
Some TVs or VCRs may have special Audio Inputs that don't allow the volume to be controlled by the TV. They are intended to be controlled by a different device, such as a home theater amplifier. Check your manual for the TV or VCR to see if this is the case for your unit.
Some TV and VCRs have a small switch, usually found near the AV inputs, that is used to allow components to send sound out to the TV speakers. Check your manual for the TV or VCR to see if this is the case for your unit.
If you are using the Stereo AV cable for your hookup, remove the plugs and reinsert them with a slight twisting motion. Make sure that you are plugging the yellow cable into the video input, and that the audio cables (red and/or white) are plugged into the audio input jacks on your TV or VCR.
If you only have one audio input, and one plug is hanging, that will result in a loss of sound. Either purchase a Y-adapter or access the game's option menu, and when available, set the game sound option to Mono.
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
Click here if the troubleshooting doesn't help
RF Hookups
Try switching both the TV and RF Modulator to a different channel (3 or 4). Try adjusting the Fine Tuning control on your TV to see if it clears up the sound. A particularly strong TV station (or cable TV) signal may be broadcasting on Channel 3 or 4 in the area, causing interference. For a detailed review of the hookup, please check our hookup instructions.
Try disconnecting the antenna/cable wire from the RF Switch. (You will have to reconnect it again for regular TV viewing.) If this option works, an AB Box may be needed. These can be purchased at various home electronic stores.
Dec 03, 2010 | Nintendo Super NES Console
Sound only works in VID mode with audio/video hookups either through a DVD player or video game consoles. Sound does not work with just cable hookup with coax cable.
Just adust the system reception to auto mode in your tv and retry. You can do it through remote control menu, going to sound options. Check tha sound system to auto. If the Tv has only PAL and SECAM system; NTSC signals do not output sound. If the tv is multi system compactable, making system reception mode to auto may help you.
Oct 13, 2010 | RCA 35V432T 35" TV
No sound when the tv is on
There's just not enough information to help yet.
Is the TV just by itself getting a signal off air?
Is it hooked up to a cable system where audio goes to a surround sound system or does a cable box just have a single cable that goes to the back of the TV?
Can you provide a bit more detail about exactly what the general hookups are?
Sep 13, 2009 | RCA Televison & Video
Surround sound hookup
Hook your satelite receiver to your TV. Then run from your TV audio out to your surround sound system. This should make your surround sound system work with anything your TV is playing.
Jan 04, 2009 | JVC TH-S5 System
Malata DVP 892 hookup problems
I had the similar problem at first. You need to use another disc before you can configure the video output. Make sure you enable the HDMI output.
Apr 21, 2008 | Wanlida Group Wanlida/Malata Combination...
How to hookup surround sound to my tv
connect audio out left and right from your tv to aux in or line in in your durabrand ht-400
Apr 03, 2008 | Audio Players & Recorders
AM/FM Stereo Hookup problems
Make sure your audio outputs are turned on.Also try a connection from the tv straight to the stereo to see if you have sound !! If so then the problem is somewhere in between!! Check the settings for audio on these devices as well !! Good Luck !!1 Swampratt200 AAAAAAAAAAAAAAEEEEEEEEEE!!!!
Nov 03, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
52 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
