Question about Whirlpool Refrigerators
My new Whirlpool Refrigerator the water and ice still stink
My new fridge is about 2 months old and we still can't use the ice or water because it has an odor and tastes bad
We have the same problem. Started 2 weeks after purchase. (6 months ago). Tech. replaced fliter, worked for another 2 weeks, then water & ice awful again. Tried to live w/ it - ordered another filter a week ago. Replaced & within 24 hrs. problem was back. Called Whirlpool. Said tech who came to my househad written in his report that tap water & fridge water tasted the same. A lie - he agreed w/ me that the water from fridge was bad, & replaced filter which had a musty odor. Whirlpool basically called me a liar but agreed to send another tech to check it out. I will never buy another Whirlpool product & plan to tak this problem as far as I need to in order to get satisfaction. This is ridiculous!
Posted on Dec 07, 2010
  • Jim Peters
    Jim Peters Apr 20, 2011
    I have an amana which is made by the same people and the reservoir tank is the culprit. After a couple years the polypropylene starts to degrade and gives off a very unpleasing taste. I have quit using the fridge water. Ice is ok as it is not run through the tank. Bad engineering.
The water dispenser is not putting out water and ice maker is not making ice. The fridge frequently cycles like it is trying to send out water.
it's still under warranty for up to 1 year,call whoever you bought it from and it should be repaired free of charge and next time you write send model number.
Dec 08, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Amana green water filter light off
If your machine is only 2 months old and wasn't used when you bought it call the number on the label that has the model and serial number on it that is located either inside the refridgerator on the upper wall somewhere or somewhere on the frame. Being that whirlpool now owns Maytag, which encompasses Amana, you have a one year manufacturer warranty where parts and labor are both covered free of cost.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 27, 2012 | Amana 22.6 cu. ft. Side-By-Side...
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a new Frigidaire whirlpool 3 month old . stop cooling and makes a lot of ice
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 28, 2010 | Frigidaire FRS26R4A Side by Side...
Whirlpool Gold refrigerator is not making ice. Just stopped 3 days ago for no apparent reason. Fridge is 6 months old.
as long as the fridge is working properly the only thing that it could be would be the icemaker...the fridge should still be under factory warranty if it's 6 months old so they should cover it
Oct 03, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Whirlpool Conquest Defrosting
Contact the dealer/Store you got it from, it should be under warranty. Without being flippant, make sure it hasn't been turned off by mistake at the wall.
Oct 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Defrosts/refreezes
IF YOU TAKE THE BACK PANEL OFF INSIDE THE FREEZER YOU WILL FIND A PIECE OF METAL UNDER THE EVAPORATOR COILS IN MIDDLE OF THIS METAL PAN IS A HOLE THAT LEADS THE WATER TO THE BOTTOM OF THE REF FOR EVAPORATION THE HOLE IN THE PAN IS PROBABLY PLUGGED TAKE THE ICE OUT AND CLEAR THER HOLE
Aug 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator Odor
sounds like fungus in the drain tube
unplug fridge p\and pour some bleach in the freezer
it stinks but it will kill the smell
after 10 min or so take fridge to patio and hose her down water will not hurt the fridge it will however clear the drain lines
and it might be a good time to clean the coils and the colection tray under the back of the fridg any way
Aug 06, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Dec 19, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gold ice maker problem
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
577 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
