Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
How do I reconnect the carriage?
I had to manually open my garage door. How do I reconnect the carriage?
  • 118 Answers
Pull straight down on the handle and release the press button on wall until trolley passes through the carriage.
Posted on Jun 16, 2010
  • 74 Answers
With the power back on .. push the remote control.. and engage the garage door troley with the carriage
Posted on Mar 10, 2009
Garage door will not close. I have a Craftsman 3/4 hp chain drive opener on a double door (7x16). The door will open fine. It will not close the door and acts as if the security beam gets broken. It...
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have bad sensors.
Feb 08, 2011 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain sent me a replacement board. I installed it. Now when i open the garage, instead of the carriage pulling the door back to the motor unit, it move forward about 4 inches, stops (because the...
Do you have the users manual of the system with you?Read it and follow the calibration instructions,it may take some trial and error to go through it,buts thats how we do it when we install a new or used garage access system.But of course you have to have some one to work with you cause you might be adjusting some pins or rollers,just an advice.
Feb 02, 2011 | Chamberlain 1/2-HP Whisper Drive Belt...
Why does my genie garage door only go up and not down
Make sure the door sensors are pointed at one another. Tweak them if necessary.
Mar 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener wont switch from manual to electric again
I think what you mean is you pulled the rope to open and close the door manually and now you can't get the two halves of the trolley to reconnect.
If so, pull straight down on the rope and release. Then run the door so the two halves of the trolley connect. You may have to do that last step manually. If this isn't your problem post back.
Jan 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door not working, motor seems fine
I have similar jerkiness problem and have gone through all the nine yards of possible causes. The motor stops at random position and at random time. Even when I unhook the door from the carriage, it still showed this symptom. It started when I had one torsion spring broken. I replaced both torsion springs and adjusted for weight balance. Make sure the two cables windup properly along the thread of the pulley; Checked the photo eye sensors; checked/test capacitor; cleaned rpm sensor; adjusted all possible force settings; make sure limit switch at sound; re-programmed my remote just to check if the logic board somehow still work on this side and it did;
One important observation I have is that when I adjusted the carriage chain, I've noticed that the opener unit turns off and on as if there's a loose connection/contact. This I pursued more. The more I investigate, I spotted a "tiny" spark on one logic board soldering at the transformer footing as I **** the back panel (where the board is mounted) back and forth to simulate the on/off due to the loose contact observed earlier. This one solves everything! All I had to do is take the logic board out and re-solder that failed connection and Hooray - it fixed the problem!
Hope this helps someone with similar issues,
Viewful
Canton, Mi
Apr 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster garage opener just clicks when trying to open''
You probably have the lock enguaged. Press the lock button on the wall control for four seconds to turn lock off
Mar 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door won't open
I don't know about the ground sensors, I do know they are a safety feature so it won't come down on something if the eyes are blocked. Try replacing the bad "eye"
For the buzzing noise, check the capacitor to see if it has blown out and requires replacement. To test this, you should be able to disconnect the door, open it manually, reconnect the door to the carriage assembly, and close the door using the GDO. The capacitor is only used to give the machine enough power to initially lift the door. It does not use the capacitor to close. Other signs to a blown capacitor is white secretion physically coming out of the capacitor. Get the MFD (microfarad) number range off the capacitor and the voltage (usually 220 volts, possiblye 330.) and find a replacement capacitor for the brand of your opener.
Feb 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to reconnect the carriage on garage door opener.
depends on which carraige. try pulling rope straight down and lifting door to open inner troley
Dec 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
176 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
